Question about Microwave Ovens
Frigidaire over the range micro wave, smoking coming out of it Was cooking a baked potato using the sensor, smoke came pouring out from the top of the cavity where there is a light. Smoke filled the cavity. I opened microwave door to let out the smoke. There was no visible fire. Smell of electrical burning and smoke filled apartment. 1. What happened? Is it worth repairing? 2. When I opened door I assume microwave automatically shut off?? or was there some danger of microwave radiation? 3. Is it safe to just leave the microwave installed where it is, unplugged, and use as a cabinet shelf or is there any microwave danger? 4. Is this something I can take out myself or do I need microwave repair tech to remove from under the cabinet. Thanks for you help.
  • seinfeldians Oct 12, 2010
    Thanks very much 1kbron.
    My main concern was whether there was radiation during the smoke or now, because there is still a smell there and I think I get a buzz/faint feeling. So you're saying that's just from the smoke/burnt part but not any radiation.
    I've called around and you're right about prices. I assume if I ever were to remove it, i'd have to hire microwave tech to do as from my readings there are electric dangers of uninstalling?
    Are you suggesting to plug it in again t use the light or vent? There is an automatic fan to air it out?
    I was thinking safest to never even plug it in again?
    again thanks
  • seinfeldians Oct 13, 2010
    Thanks very much. The reason I was asking about removing microwave myself (and probably not installing anything there-you're right about the costs so I'm getting a countertop microwave) was that this online manual of microwave repairs http://repairfaq.ece.drexel.edu/sam/micf... which has lots of warnings about the high voltage capacitor and being sure it's discharged, etc. Wasn't sure if by removing the over the range microwave from its cabinet position and unhooking whatever electric cord there is, I come in contact with the high voltage capacitor.
    If I leave microwave where it is, it does have that awful burn smell. Is it okay to spray air freshner in the cavity?
    Thanks again.
    Thanks very much. The reason I was asking about removing microwave myself (and probably not installing anything there-you're right about the costs so I'm getting a countertop microwave) was that this online manual of microwave repairs http://repairfaq.ece.drexel.edu/sam/micfaq.htm which has lots of warnings about the high voltage capacitor and being sure it's discharged, etc. Wasn't sure if by removing the over the range microwave from its cabinet position and unhooking whatever electric cord there is, I come in contact with the high voltage capacitor.
    Thanks again.
    President:
  • 1,796 Answers
Hi!!
Your microwave's wiring insulation probably overheated and started to melt, this could be due to defective magnetron or worn electrical connection, if you saw smoke, must likely, a wire harness plus defective parts have to be replaced, you are looking about $200 in parts + labor, not wort fixing if you ask me. The microwave is designed to shut off as soon as the door is opened, so don't worry about radiation. It is safe to leave the microwave use it as cabinet shelf although you may want to leave the door open until the smoke smell is gone, and check if you can use the light and filter accessories underneath the unit, No need to remove the unit if it can be used as a shelf, light and filter, besides, the holding hardware that is bolted into wall will be exposed.
I hope this answers all of your questions! Good day. Thank you for using FixYa!
Posted on Oct 12, 2010
  • Rene J Solis Oct 12, 2010
    If you don't feel comfortable with the microwave anymore, then you should replace it with a similar model. You don't need a Tech to install it, when you get the new one, it comes with installation instructions but you are not going to perform any installation, just swap ovens, two people can do it easier by unplugging from wall outlet, lifting it straight up about one inch and then away from wall. Installation will be reversal.
  • Rene J Solis Oct 13, 2010
    To get shocked by a capacitor you actually need to touch the terminals. The capacitor is inside the unit, so don't worry about getting shocked. The power cord is plugged in an outlet located inside the cabinet above the microwave, just need to disconnect the cord from the power outlet. Burnt smells are very hard to remove, specially if they are located in enclosed spaces. If you want to use the oven as a cabinet, click on the following link for tips to remove the odor.
    You may want to use clear tape to cover the openings inside the oven to keep odors out.
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
SET TIMER FOR 20 MINUTES FOR BAKED POTATOE.. CAME BACK AND FOUND POTATOES CHARCOALED. SMOKE AND SINGED INSIDE. MICROWAVE WILL NOT COME ON. CHECKED CIRCUIT BREAKER. POWER TO UNIT.
That was a very long duration to have set for potatoes. It would have made the magnetron burnt by exeeding the limit and findinf there was no conductive medium by moisture , it has ended up burning the magnetron.
First of all clean up the inside and clean up the point of the magnetron beam.Now confirm on the inside to be totally dry.
Disconnect power and check inside for break of fuse to the magnetron.If the microwave does not heat on testing with a cup of water , then it is possible that the magnetron is cooked.
Confirm the cost for the unit to decide on replacement.
Hope this helps.
Aug 21, 2010 | LG LMV1630 Convection/Microwave Oven
No power to control panel
There's a safety thermostat attached to the cooking cavity in most ovens to detect when something overheats. Once they operate they cut off power to the rest of the oven. These are usually non-resettable, and need to be replaced to repair the oven. If there wasn't any damage done to the interior of the oven you can see about having the repair made.
Mar 26, 2010 | GE JVM1650 1000 Watts Microwave Oven
Frigidaire PLMV169DC (SS) 1000 Watt Microwave Oven/ Not working
REMOVE THE CABINET AND IT SHOULD BE CLOSE TO THE POWER INLET ON THE MOTHERBOARD IT LOOKS LIKE THE OLD GLASS TYE FUSE BUT MADE OF CERAMIC. GO TO www.repairclinic.com ENTER MODEL NUMBER, SCROLL ALL THE WAY DOWN N CLICK THE RED 100. FROM THERE LOOK FOR PART 634759 1055598 634750 1055589 1469078 ONE OR MORE OF THESE COULD BE THE CULPRIT START WITH THE LINE FUSE.
Apr 17, 2009 | Frigidaire PLMV169DC Microwave Oven
Fire in Microwave Using Sensor Control for Potato
Please contact your home insurance to have the problem logged as a failure of the microwave. The insurance company will most likely help you with the smoke damage to the house and will contact the manufacturer to get their money back... there might be an issue with the manufacturing of these appliances.
Jan 04, 2008 | Amana ACO1860 Microwave Oven
Up in smoke
yes there is hope have a tech check your set or buy a magnetron to replace the existing one make sure you discharge the high voltage cap it store letal voltage.be careful if you are going to do it yourself.
Apr 03, 2007 | GE JES1358 Microwave Oven
Microwave Dead after burning up potato
Chances are the magnetron overheated and blew the thermostat / thermal cutout that monitors it. The magnetron itself may be bad, too. If Sears Service might consider this still under magnetron warranty, then they may replace the mag with no part costs (or just the thermal cutout part cost), but likely would charge labor. You can contact customer service or repair via http://www.sears.com Otherwise, if you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com or likely cheaper here: http://tinyurl.com/gv383
Feb 06, 2007 | Kenmore 60659 Microwave Oven
Microwave Ovens Logo
119 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
