Question about KitchenAid Refrigerators
NEED TO REMOVE THE DOORS - KitchenAid Refrigerators
  • 828 Answers
Normally doors on refrigerators are removed beginning with or at the top. There may be a cover over the top hinge which can be popped off to expose the screws or hex head bolts that hold it in place. Once the top hinge is removed the top door can be lifted up and removed. Next remove the top hinge of the bottom door, lift the door to remove. Finally remove the bottom hinge. Place all parts in a secure place so they do not become lost. Re-assembly is in the reverse order.
Posted on Jun 02, 2008
Broken door locks
Then you'll be needing to remove the inside door panel. There should be a clip on the lock mechanism and a rod attached to it. What I'd do is go down to a u-pull it lot and find a similar model and remove the door panel and see what you're up against. Then you can decide if you want to get into it yourself or have it done by a mechanic or a locksmith, whichever is cheaper. Goog luck.
Mar 29, 2014 | 1996 Toyota Hilux
Glass fell 99 olds 2 door left side...regulator needs to be replaced in Riverside CA area
glass fell down in door bolt to equalizer arm to regulator fell out of place missing or window regulator broken.you have to remove door trim panel. you need a haynes repair manual to show you how to remove door trim panel. and door panel screws location to door handle.you need see screws location to remove power windows and door lock control.you will need door panel trim removal tool.
Jun 06, 2011 | 1999 Oldsmobile Alero
How do u remove the drivers side door panel to fix the window
YOU NEED CLIP REMOVAL TOOL TO REMOVE WINDOW CRANK HANDLE.YOU NEED DOOR PANEL FLAT TOOL REMOVE DOOR PANEL HATE TO SAY DOOR PANEL HAS AT LEAST 8 CLIPS LOCATIONS 4 CLIPS AT THE BOTTOM PANEL 2 CLIPS ON BOTH SIDES DOOR PANEL. YOU HAVE TO REMOVE 2 SCREWS HOLDING DOOR PULL CUP.YOU HAVE RELEASE CLIP BEHIND DOOR HANDLE USING TRIM TOOL.IF YOU HAVE TROUBLE GETTING DOOR PANEL OFF.HAYNES REPAIR MANUAL CAN HELP.
Oct 07, 2010 | 2004 Chevrolet Cobalt
To replace window switch for driver window, must I remove the whole inside door panel on drivers door ? Are there diagrams available online to remove the interior panel ?
YOU DONT HAVE TO REMOVE DOOR PANEL.ALL HOLDING SWITCH A SCREW THAT GOES THROUGH SWITCH INTO DOOR HANDLE.REMOVE THE SCREW PRY AND PULL UP THE SWITCH.
Jun 04, 2010 | 1995 Chevrolet Lumina
I alero need to remove the driver door panel on a
YOU NEED A DOOR TRIM TOOL AND IF YOU GOT MANUAL WINDOWS YOU NEED THE DOOR HANDLE TOOL.ALSO NEED A MANUAL TO SHOW YOU SCREWS LOCATION TO REMOVE DOOR PANEL.
Aug 29, 2009 | 1999 Oldsmobile Alero
Actuator removal
please rate as solved if this is what you need. You will need to borrow a heavy duty riveter from autozone or wherever you buy the lock cylinder from.
Removal
  1. NOTE: The rear door window glass must be completely raised.
    Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  1. Remove the rear door trim panel. For additional information, refer to Section 501-05 .
Trim Panel —Rear Door, Expedition Removal
  1. Remove the power window switchplate (14524).
  1. Disconnect the electrical connector.
  1. Remove the rear door handle trim cover.
  1. Remove the rear inside door handle.
    • Remove the door handle bolt.
  1. Remove the rear door trim panel screws at bottom of panel.
  1. s2j~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the rear door trim panel, do not pull directly outward.
    Lift upward and then outward to remove the rear door trim panel (27406).
  1. Remove the rear door watershield.
  1. Disconnect the power door lock actuator electrical connector.
  1. Drill out the power door lock actuator rivet.
  1. Remove and discard the screws.
  1. Remove the power door lock actuator.
    • Disconnect the power door lock actuator rod.
Installation
  1. NOTE: Use new screws when installing the rear door latch.
    To install, reverse the removal procedure.
    • Use Heavy Duty Riveter to install the new rivet.
Jun 14, 2009 | 2002 Ford Expedition
Remove door panel on a Ford Van
For a 1999 Ford Econoline 150 (assume the same or very similar), remove triangular plastic cover over mirror assembly by prying straight out, remove plastic door handle cover by prying up from the front side, remove electronic door switches by prying up from back side, remove round plastic cover at bottom rear of door panel. Four screws are now revealed, remove them. Lift door panel straight up, clips are hooks (not snap in). Work door switch assembly out of door panel. Set door panel aside. Reassemble in reverse order.
May 09, 2009 | 2000 Ford Econoline
Rear door actuator is making a noise, needs replacing
Snap out two door pull strap retainer screw covers. Remove screws.
Remove one screw from lower rear door panel.
Remove screw retaining rear inside door handle cup . Remove rear door inside handle cup.
Using a Trim Pad Removing Tool pry trim panel retaining clips from rear door inner panel.
Feb 12, 2009 | 1995 Mercury Grand Marquis
I need to remove the drivers internal door panel
Remove plastic studs from door closer. Unscrew three retaining screws. remove grab.
Unhook window winder retaining clip. Best done with small long-nose pliers. window winder retaining clip located inside plastic winder handle section. Will need to prise away winder handle from door slightly to expose clip. locate and gently pull clip from winder shaft.
unscrew door opener / lock assembly retaining screw.
gently prise lower trim retaining press studs from door. remove lower trim.
gently , from rear of door, pull upper trim from door and similtaniously prise upper trim press studs from door.
gently giggle door opener / lock assembly through upper trim . remove trim
gently with flat blade, peel off plastic dust sheeting.
access to inside off door is now possible.
Reassembly reverse of above
Cheers !
ozzy11
Feb 04, 2009 | 2001 Suzuki Swift
Door panel
Depends on what door trim you are trying to replace. If you are trying to replace the door trim on the front doors you need to remove two screws from behind the casing around the door handle and then remove a screw from the bottom left of the door and then there will be a screw on the left of the door as high as the arm rest on the door. Finally pull up on the door panel and out to remove the panel. Remove the harnesses and you are complete.
If you are trying to remove the rear doors you need to remove a screw from the bottom of the door again near the left side then remove the screw from behind the casing that surrounds the door handle. Finally pull up on the door panel and out to remove the panel. Remove the harnesses and you are complete.
Oct 27, 2008 | 2001 Ford Crown Victoria
Refrigerators Logo
253 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
