A wire from a bra is stuck in the inner drum.It is a smeg front loader.
  • 240 Answers
Probably lodged by the heater, on most models that can be accessed from the front, frigidaire, some whirlpool in rear. loosed nut in middle and slide out.
Posted on Jun 03, 2008
  • 3 Answers
Put baby oil around item and slowly slip out
Posted on Jun 04, 2008
MY zanussi, ZWI1125, FRONT LOADER, now makes such a noice on washing and spinning. the plumber has relevelled it but it still makes a noice esp on spinning. Why?
This could be something stuck in the drum ie ,A bra wire or could be bearing trouble an engineer could tell you within seconds.
Oct 30, 2013 | Zanussi Washing Machines
I have a broken bra wire stuck behind drum of LG turbo drum washing machine, how do I get the drum out??
You don't say if it's a front or top loader. I managed to get one out with a strong magnet inside the drum just moving it about until it appeared near one of the holes in the drum without taking the machine apart. But it was a front loader and is probably easier than a top loader.
Jan 26, 2012 | Washing Machines
Bra wire stuck between drum and casing, how can I remove?
our is a Bosch nexxt front loader, we removed a heating element. Were able to get access the area of drum unit where the wire was.
Jun 19, 2010 | Electrolux Washing Machines
Bra wire stuck between inner and outer drum how to remove Hotpoint WMF760
Depends where it is stuck. If near the very front you can sometimes get them by removing the door seal to gain a small access between drums. Other ways is remove the outlet pipe from the bottom of the drum or easiest and most probable area where it stuck is remove heating element. Provides a better view and bra wires normally get stuck on them.
Jan 24, 2010 | Washing Machines
BRA WIRE STUCK BETWEEN DRUM AND HOUSING
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to Applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Neff V4380X0 Front Load Washer / Dryer
Bra wire's trapped between inner and outer drum,
If you cant pull wire out from inner drum with long nose pliers, Remove heating element and use torch to inspect bottom of washer. Most of the time the obstruction makes its way to the bottom. Use whatever tool necessary to remove spring.
Sep 25, 2009 | Hoover AAA160 Front Load Washer
Bra wire stuck somewhere in machine
You will not see it as it is trapped between the inner and outer drum, what you need to do is remove rear panel and the large hose from the pump to the bottom of the drum,
Then reach in with your fingers and see if you can feel it , if you can't then short of removing the drum (not recommended) ther is not a lot you can do, hopefully it will find it's way into the filter, where it wiil not be a problem
Plz rate this solution.
Dec 15, 2008 | Washing Machines
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Bosch Classixx 1200 Express - metal got under the drum
This video will show you how to get into the drum through the heating element and remove the bra wire on this Bosch front loader washing machine
we have all bosch repairs in our channel
Apr 01, 2008 | Washing Machines
Bra wire has between drums
you will need to call in an on site tech.but from my exp.the tub assembly would need to be replaced if you want to solve this problem.
Jun 23, 2007 | Hotpoint WMA54 Front Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
