Question about Acer Aspire 5520-5579 Notebook
Windows has encountered a problem communicating with a device connected to your computer. This error can be cuased by unplugging a removable storage device such as an external USB drive while the device is in use, or by faulty hardware such as a hard drive or CD-ROM drive that is failing. Make sure any removable storage is properly connected and then restart your computer. If you continue to receive this error message, contact the hardware manufacturer. File: BootBCK Status: 0xc00000e9 Info: AN unexpected I/O error has occurred." how can i fix this i dont have a disk drive?
Hello, Im having a problem with my Dell INSPIRON 1750.
it's possible your hard drive has gone bad, that's what it sounds like
Aug 02, 2012 | Dell Inspiron Computers & Internet
Windows Boot Manager message: Windows encountered a problem communicating w/a device connected to your computer. Error may be caused by unplugging a removable storage device such as an external USB Drive...
Make sure there is nothing attached to the laptop,remove all devices like keyboard,mouse, flash drives and retry. If still having same error flip the laptop over and remove the battery and open up the 2 other compartments that have a screw holding them. One holds the memory modules and the other the hard drive, check and re seat all connections, then try again. If you still have the same error your hard drive is most likely failing,
Thanks for using FixYa
Jul 23, 2011 | HEWLETT-PACKARD Compaq Presario CQ60-615DX...
Dropped laptop off of couch onto floor apprx 18in. Computer locked up. unplugged and removed battery for five to ten minutes. started to boot and gives me "Windows has encountered a problem...
If your hard drive was running at the time you dropped it, your hard drive might have crashed. Sorry to tell you this buy you most probably need to replace the hard drive.
Apr 11, 2011 | Computers & Internet
When I powered down and rebooted I got Windows Boot Manager Windows encountered a problem communicating with a device connected to your computer. This error can be caused by unplugging a removable storage...
hmm seems a lil odd it appears that maybe your internal computer hard drive is failing or that its not properly connected if its happened recently with no internal computer changes then its definitely the hard drive failing on you
Apr 22, 2017 | HP Compaq Presario SR1110NX PC Desktop
Need a system recovery? Tried the F8 method--doesn't work! Help!
Just unplug the hard drive cable and plug it again. otherwise if problematic replace the cable.
Apr 24, 2009 | Gateway GT5404 PC Desktop
Open Questions:
Acer Aspire 5520-5579 Notebook Logo
259 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
