Question about Vacuums
I have a cooling fan on my wine cooler that burnt out, I need a replacement. I need a Heng Shan Fan model no# FS92252M 12v 0.2 amp
  • jzapoli Dec 05, 2010
    where do i buy a fan motor for my wine cooler
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: my wine cooler wil not
If the compressor is running, but no frost on the evaporator, you have system problems for a pro to look at.
First, see if the fan is actually blowing anything out of it. You may have an obstruction. If not that, generally, there are three reasons that you won't get cooling:
  • The condenser radiating fins on the unit are dirty which won't allow cooling air flow to liquify refrigerant. Clean them.
  • The unit is frozen up inside because of excessive humidity. Defrost the unit by leaving it off and open for a day.
  • The unit is low on refrigerant. Check this by leaving the unit off for one hour. Locate the pipes coming out of the compressor. Turn the unit on. If the larger pipe stays frosted up for more than 15 minutes, you need to get the unit charged.
Keep us updated.
Posted on Dec 28, 2010
No power to Dyson pure cool fan
Check the fans cord. There might be damage to it. Try another outlet it could be the outlet the fan is plugged into. If you see no physical problems with fan. I would enter the serial number in dyson support and see if they will replace the fan. Here is dyson's support page to get started. http://www.dyson.com/support.aspx
Jul 22, 2016 | Dyson DC40 Animal Upright Vacuum -...
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
How do I change the fan in my riccar vacummn?
It depends on which model you have. Most models have a fan that will never need replaced. Tandem air and Supralight models have a fan that could be damaged on older models but is unlikely on newer models as fan are now made from a flexible material. Remove the motor assembly and disassemble to get to the fan. Remove the nut from. The shaft and remove the fan. Install new fan and put back together in reverse order as it was taken apart.
Feb 28, 2015 | Riccar Vacuums
Hi, I have a older model Sunbeam water cooler that hasn't been used for a while ..Need to know how to clean and sanitize it? got any ideas
Vinegar might help. Run a bunch through the water cooler and it can help clean out the unit (and will give you some disinfection as well) without damaging it. I have used vinegar in my coffee pots with much success over the years. Once you are done, you will want to run a LOT of water through it to get the vinegar taste out of the system, though. If you are not a fan of the idea of vinegar in your water cooler, you can try coffee-pot cleaner ... it is more expensive, but is designed for the same basic use.
Jun 07, 2011 | Vacuums
Wine cooler has error code on bottom half "E4". What are the possible problems?
Sound like a problem with the fan unit; the connectors to the fans get moisture in them and corrode.
Just stripping the wires and hard connecting them, only tool needed is a phillips screwdriver. There are 3 connectors on the side to remove the control panel shelf. Its a pretty simple job.
If this not solve it, need to replace the fan.
Hope helps.
Mar 31, 2011 | Vacuums
Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Rainbow 2e Overheats... its the Electric Motor cooler fan......
It is pressed on, that is why you have a splined shaft. If you use a socket or nut driver, you can knock it ino place with a hammer. But don't hit too hard. you don't want to damage the end.
May 29, 2008 | Vacuums
Fan kit kirby g4 vacuum cleaner
I'm assuming you mean the fan impeller and not the fan that cools the motor...
you can find detailed instructions at this site
http://reviews.ebay.com/KIRBY-VACUUM-REPAIR-HOW-TO-REPLACE-THE-FAN-IMPELLER_W0QQugidZ10000000003711302?ssPageName=BUYGD:CAT:-1:LISTINGS:3
hope this helps!
Jan 13, 2008 | Kirby G4 Bagged Upright Vacuum
Vacuums Logo
717 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
