I have a excelstor gp1080, ut is a 80gb hdd, when i install it in my computer the bios says its only 41 gb, can you pls help me with my problem? tnx in advance
shaky120
  • 310 Answers
SOURCE: Can't See HDD in Windows Explorer
Afraid Excelstors hard drive repair tool requires the drive to get wiped to fix the errors not like seagate or western digitals, only thing worth trying is put in a windows xp disc and boot off the disc, Press R on the first screen to do a repair in like dos mode. it will take you into a black screen with a dos prompt, type this in CHKDSK C: /R then press enter it will take about 30min-1hr but has a good chance of getting the drive to read.. once complete take out xp disc and restart pc all the best John
Posted on Mar 03, 2007
  • 90 Answers
SOURCE: internal 80gb harddrive excelstor j880
Was this 80GB cloned (copied) from an old 30GB disk?
Open Computer Management window doing this:
Start button - settings - control panel - administrative tools - computer management.
In the window that open, on the left hand side pane, expand Storage and click Disk Management. On the left hand side window, lower pane you should see a list of disks. See Disk 0,Basic <disk size>, Online. Do you see the 80GB as disk size? To the right you would see a series of boxes. Probably you see (C:) 30GB NTFS Healthy (system). Do you see to the right of it a box with 50GB (unknown partition)?
If so, you do have a 80GB disk, but only 30GB is a recognized partition by Windows. You can still use the the unknown partition. Post back here if you need instructions.
Posted on Dec 31, 2007
  • 1019 Answers
SOURCE: SP0812N HDD 80Gb
this mainly depends on The Operating system, if your using Windows 2000 or above it should,nt be an issue.
sometimes there are limitations on 2 hard-drives sharing the same IDE channel on the mainboard.
Try putting the second hard-drive on the secondary motherboard slot, with it,s own individual cable.
If non of the above works, it,s possibly not formatting correctly.
you,ll need a program that zeros then formats the drive.
Hope this helps.
Mike @ Compurepair.
Posted on Feb 22, 2008
SOURCE: excelstor j8160 hdd
right click on the 'My Computer' icon, go to 'Manage', then click on 'Disk Management', and see if you need to either format the drive, assign a drive letter, or if it's recognized correctly. Most of the time, you'll find the drive in here just needs to be formatted, or it needs to be assigned a specific drive letter.
Posted on Aug 21, 2008
ardmax
  • 155 Answers
SOURCE: BIOS PROBLEM
I don't think you have a problem with the BIOS version but more likely with the settings.
Please enter in the BIOS and be sure that under: main menu, ide configuration, Parallel ATA IDE controller is set up as Primary. Then you go under advance menu, Serial ATA IDE controller and be sure you don't have RAID.
Copy of the manual can be find here http://dlsvr.asus.com/pub/ASUS/mb/sock754/k8v_vm_ultra/e2476_k8v-vm_ultra.pdf
Let's start with this checks and then let me know.
Posted on Oct 02, 2008
Hdd
Hello here is the mainbords homepage:
http://ee.gigabyte.com/products/page/mb/ga-8knxp_1x/download/
You have to open the bios first, and select to boot from the dvd drive.
If any doubt how to do this, download the manual from the home page.
Or watch this video:
http://www.youtube.com/watch?v=Oy2R3Tl9rIE
Good luck
Jul 19, 2013 | Gigabyte GA-8KNXP Motherboard
How to format excelstor hardisk?
For your specific operating system, assuming that Windows is running, locate Admistrative Tools -> Disk management.
You should see Disk 0 or Disk 1 with your Excelstor 80GB drive: if you do not have a partition, create one or more partition, assign drive letter(s) and then format using the context menu.
If you do not see the drive in the Disk Management screen, then your Bios has not been setup properly or your drive is not connected properly.
Hope it helps.
Sep 27, 2010 | Excelstor Technology J880 Hard Drive
I am connecting my 40gb PATA HDD, but my PC doesn't start. There is no problem when i connect my 80gb PATA HDD in same PC. My 40gb HDD had detected once but it gave symbol S@ in the BIOS setup. Can U...
You did not indicate that the 40 Gb hard drive had Windows installed on it and whether it was the original hard disk for this computer.
There is a possibility the 40Gb hard drive is faulty.
Try installing the 40Gb hard drive as a slave drive with the 80Gb drive as the master drive (don't forget to set the jumper on the 40Gb hard drive as Slave. Check the BIOS to see if it detects the 40Gb hard drive, and when the computer boots up, if it can see the 40Gb hard drive and opens the various folders and files, then the hard drive is OK.
Sep 19, 2010 | Computers & Internet
I have Intel 810e PIII 1 GHz 512 Mb Ram 20 GB HDD. OS Win ME I want to add secondary HDD. Which one should I preferr 80GB / 120GB / 160GB. and will install new OS say Win XP or linux in Secondary Hdd....
160gb - but ensure the bios is up to date and check the motherboard manual as that will or should explain about maximum capacity of hard drives but am sure it should be fine.
If it is not and does not detect all of it you can partition the partitions into smaller amounts ie 80 gb partitions each ?
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
HI i m posting the same problem onceagain with the trouble shooti
You could try flashing to the latest bios and disabling SATA RAID, disabling IDEs including bus master if u dont use any.
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
I have a 2000 1100 series computer with a 37 GB hard drive thats out of space. I ordered a 80 GB and installed it but it still only shows the 37 when i go the my computer icon how do i clone the 80 GB to...
jjfsrm,
to clone ur 80gb,u must have a cloning software..
and if u wanted that the 80gb is ur first drive,u should install ur operating system on ur 80gb..and of corz the jumper on ur 80gb hdd must be on primary position,and for d 37 should be a slave..
ur 37gb is the first boot thats why it is on the primary,but if u put ur 80gb into primary,ur computer will not function well coz it does not have the o.s..
Apr 07, 2008 | Computers & Internet
Internal 80gb harddrive excelstor j880
Dec 31, 2007 | Excelstor Technology J880 Hard Drive
Sep 18, 2006 | Excelstor Technology J840 Hard Drive
Computers & Internet Logo
David Payne
David Payne
