Question about Home
The grout in my shower floor is crazed, do I need to dig it all out or can I just cover it
  • 10,865 Answers
Remove any loose material and then use fresh grout to level it all. Joe
4 thumbs up please.
Posted on Oct 12, 2010
How to Grout ceramic tile to shower base
Don't use grout! Instead use silicone caulk that matches your grout color as close as possible. Never grout where tile meets at a 90 degree angle it will crack.
Jul 13, 2014 | Building Materials
How do i seal a crack in the grout on the shower floor using wet area silicone? Is this suitable and what do we do?
problem usually happens when grout is not fully cured and sealed when water penetrates it so... remove old grout using grout removal tool (you can pick up from any where that sells flooring(tile) pick up some new sanded grout to match and sealer apply then seal 24 hrs cure time is req. before sealer wait 2 hrs then re-apply sealer 7_2_2014_6_45_58_am.jpg
Aug 31, 2013 | Home
Glass Shower Door
If you don't plan replacing the shower door, fill the holes with tile colour grout or other fillers you can buy from hardware stores. I am saying grout because if you have coloured tiles, the filled holes won't show prominently, otherwise fillers are ok.
Jul 10, 2013 | Home
I had a shower total replacement less than two years ago. Company out of business now. Shower grout has cracked bad at base and in corner all the way down. I need to re-grout. Problem is the gap in corner...
Use a good quality bath and tub caulk applied to the deeper parts of the gap. Do not fill all the way out to the top of the gap with the caulk. When the caulk is dry, then apply the same color grout over the caulk.
Jan 21, 2013 | Home
Walk-in shower floor problem
They probably use wrong adhesive that is not hard yet and have tenedency under pressure to squeze out between grout lines. Yes they need to address the problem immediately.
Jan 14, 2010 | Home
Shower leak
this may not be a grout problem . I want you to run the shower and check the shower arm behind the wall plate and the toe tester(spout ) for water leaking behind the wall.If you dont find a leak than their could be a problem with the rubber membrane under your tiles.
Feb 01, 2009 | Home
Home Logo
105 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
