Question about Fujitsu Siemens Computers & Internet
My Amilo Pi 3540 is shutting down after 20 - 30 minutes. CPU usage looks fine but for no reason it goes up to 60-70 and causing my machine to crash. How do I check if the fan is running correctly or what could cause this. thanks for your advise. Peter
hmlee
  • 9 Answers
SOURCE: DVD BURNING : TAKES TOO MUCH TIME AND CPU USAGE GOES TO 60%
Based on the laptop model you have listed, I am afraid to say that there is not much that you can do about the time it takes to burn DVDs. Computers often come with re-writeable (RW) drives that have different speeds. Thus, on older laptops or desktops, the drives are very often slow and will take a large amount of time to burn a full DVD. As for the CPU usage, writing data from a hard drive to a DVD or a CD is a very memory and performance heavy task, especially on older computers. You can attempt to free up resources by closing as many non-essential programs as possible prior to burning a DVD... but that will not dramatically increase the speed. Not using the laptop for other purposes while it is burning a disc may also speed up the process.
Posted on Nov 09, 2007
TampaNative
  • 778 Answers
SOURCE: Crash!!
Could be Heat, sounds like the system is shutting down to protect the processor. Let it sit shut down over night and see if it runs longer when it's cooled down. Is the fan running?
Posted on Sep 05, 2008
  • 13433 Answers
SOURCE: How to reduce the cpu usage ?
user process explorer to see what programs are using the cpu
http://technet.microsoft.com/en-us/sysinternals/bb896653.aspx
Turn off extra programs, you can see what program is using the cpu and you can turn it off.
Posted on Feb 16, 2009
  • 5 Answers
SOURCE: Acer Laptop 7720G is getting crashes and auto restart
Try Advanced system care . You can download a free version that works well . I would also recommend you download Malaware Anti-Malwarebytes
Posted on Apr 12, 2009
  • 597 Answers
SOURCE: Overheating Dell D600?
Get a can of compressed air for cleaning computers. Turn the laptop over and locate the vents to the fan inside. Blow the compressed gas through the machine to clean out excess dirt and lint. Then turn on the laptop and see if you can observe the fan running. If you can see the fan running you might notice how fast it is running. If it is running slow or not at all then you need to get that replaced.
Posted on Jun 01, 2009
Repair manual for fujitsu amilo pi 3560 pc laptop
Computer repair manuals are not available for several reasons, including that components may change and that manufacturers do not want the liability involved in unskilled people working with electronics. As it is several years old it is out of warranty, so first Google amilo pi 3560 technical specifications to discover what you can about exact components. Then Google the repair procedure you wish to perform, along with the make/model, for example replace hard drive amilo pi 3560.
May 08, 2016 | Fujitsu Computers & Internet
Web cam amilo pi 3540
1st You download Webcam Driver.
Web cam amilo After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Ezonics Camera Drivers for Windows XP Vista Windows 7
Feb 17, 2014 | Ezonics EZCam Webcam
Overheating amilo
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Jan 26, 2013 | Fujitsu AMILO Li 2727 Notebook
Amilo Pi 3540 VGA webcam drivers windows 7
Sometimes the most up-to-date device drivers aren't the most compatible. Downgrade your driver to an older version.
Mar 15, 2012 | Fujitsu Computers & Internet
Why pc is not shut down after clicking on shut diwn option
There are many things that might cause your PC or any application in your PC like outlook express to run slowly or freeze or even restart at time and then. It could be a fragmented disk, fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; caused by an infection.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good virus scanners that you can run to check your PC:
So here is the best solution that I can suggest for you is to scan your
PC with a very strong antivirus, here is the link to get it.Its very good.
http://f1226ed7g6j0vsm6nlwdh440fx.hop.clickbank.net/?tid=DMWDH6W3
To clean up registry there is another very good application which will keep your PC registry out of trouble caused from spywares.
http://6d099feff2g50wdmmpgh0brrf1.hop.clickbank.net/?tid=DMWDH6W3
Nov 22, 2011 | Microsoft Windows XP Home Edition
My laptop is a Toshiba Satellite. It shuts down on its own after few minutes of usage even if it is plugged in, what is wrong?
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Jun 12, 2011 | Computers & Internet
I am not really sure if this caused by the fan performance, but I can confirm that my laptop dell inspiron 1420 is very hot after running about 1 hours.. and often my CPU usage reach 100% when I use Vista...
First, I appreciate the details provided in your question. Thanks!
The specification of your laptop are fine and enough to run and support Vista. It is true that greater number of processes and CPU usage causes, but normally the machine can handle it well if it gets proper ventilation.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink. I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Nov 25, 2010 | Computers & Internet
Acer aspire 5630 laptop keeps shutting down
It sounds like someone has suggested that overheating may have caused the random shutdowns (which is quite plausible). There are a few tools that can diagnose what is happening:
  • Temperature: I use SpeedFan (http://www.filehippo.com/download_speedfan/) to discover the temperature of my cpu. My Acer 5630 is usually doing 50 to 60 degrees. Anything higher than that could cause the random shutdowns (I've seen it happen on other laptops). If you download this program, don't muck around with the settings (as it would advise you not to anyway), just look at the temperature readings (eg. core 1 core 2)
  • I keep a cpu usage meter on my sidebar (http://gallery.live.com/liveItemDetail.aspx?li=587ef54f-e121-418b-b258-e583e105a0d6). It keeps an eye on the CPU usage so if i see it say 100% cpu usage then I suspect some software is inappropriately consuming resources.
Treatment of overheating would be to find the offending software and manage it or remove it. If it is not software at fault, then it may be that there is too much dust covering the ventilation (Your acer may be old and you may hear your fan increasing speed and the performance struggle sometimes). I opened up my one and found dust build up from the radiator all the way to the fan! (it was like around 1cm thick in some places, i wish i took a picture)
Another reason for random shutdowns is the integrity of the power switch or the lid sensor. My computer got rained on once and randomly shut down. It took a while of cleaning it with Circuit board cleaner from Repco (I had to open the panel that covered the power button and spray it). It got better everytime I cleaned it and now it reliably stays on (actually it randomly turns on now haha)
Jan 02, 2010 | Acer Aspire 5630 Notebook
Compaq Presario R3150US shuts down with IE7, cpu usage goes up
Have you inatalled the latest service pack before you upgraded to IE7?
If not, suggest you un-install IE7, install the service pack, reboot computer and then upgrade to IE7.
If IE7 causes you problems the revert back to IE6.
Nov 30, 2008 | Compaq Presario R3000 Notebook
Computers & Internet Logo
204 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
