Question about KitchenAid Dryers
My dryer stopped heating is it the thrmostate or heating element?
  • KitchenAid Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 17, 2010
2 Suggested Answers
  • 7 Answers
SOURCE: Maytag dryer heating element does not turn off when tumbling stop
your timer is bad,the cost of a timer is close to a new dryer.
Posted on Jan 21, 2009
Dryer won't dry clothes in one cycle
Make sure a heating cycle is selected. Air and Fluff cycles do not use heat.
Make sure that both phases of 120 volt power are energized (total of 240 volts between the 2 phases).
Most likely the heating element is damaged, which usually means there is no heat at all. A dryer with 2 heating elements will have some heat, but not have enough, when 1 heating element stops working. A dryer with 1 heating element can partially fail and have partial heat, too.
Apr 03, 2017 | Dryers
KENMORE DRYER JUST STOPPED HEATING UP WHAT CAN I DO TO REPAIR IT?
Replace the Heating Element. The heating element is usually located behind a panel on the back. To replace you will need to remove the back cover of the dryer, then locate the heating element. The heating element is screwed into place and is easy to unscrew and replace. Be sure to have the dryer unplugged while doing this.
Here is the part for it:
http://www.repairclinic.com/Kenmore-Dryer-Model-11060602990-ID-501912-Heating-Element-Parts
Mar 13, 2013 | Dryers
Whirlpool dryer model geq8858jq1.had a slight burning smell.cleaned the vent hose all the way outside and inside unit.smell decreased but then lost heat.found thermal cutoff opened.replaced and ran for...
Yes Thrmostat is bad "stuck" closed circuit will not open to stay at safe temperature. This can be dangerous. I never run my own machine at home unattended or while asleep. For fear something like this could happen and cause a fire had a recent problem with a Whirlpool. Replaced it after finding the "correct" one. I would bring the bad one with you when you go and get a new one.
Please leave a good feedback for me on here.
as i am trying to help people on here for free.
Jan 06, 2011 | Whirlpool Dryers
Stopped heating. Did thorough cleaning of lint trap and ventilation hose. Did heating element burn out? or other problem?
take off the back at the heating element there are twoo wires undo at least one of them and check the contnuity [before you do this unplug the dryer] if you have a reading on you maeter it isnt the element check the thrmostat, i hope i helped.
Dec 30, 2009 | Dryers
Dryer is occasionally leaving rusty looking smudge marks on clothing.
don't open door (stop dryer) until cool-down and dryer stops. many times the heating element is still hot and when you stop the dryer in the middle of the cycle, the rear of the dryer where the heating element is, will scorch your clothes.
Nov 29, 2009 | Frigidaire FGQ332ES Gas Dryer
Will run but will not heat up
Most likely a bad heating element and or bad thrmostats. you'll need to check these by ohming out after removing the rear panel to your dryer.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
Oct 26, 2009 | Whirlpool Dryers
No heat in dryer model # 96591420
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 31, 2009 | Kenmore Dryers
T|he heating element won't stop heating
Hi, The element has broke and shorted out against the metal on the dryer. You will need to replace the element. If this is a rear access panel dryer, here is how to get to the ele UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jul 15, 2009 | Kenmore 62602 Electric Dryer
Jan 21, 2009 | Dryers
Dryers Logo
29 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
