Question about Carlon Home Products Electrical Supplies
Wireless 3 way switch has short range. Any ideas? Got new battery.
    Novelist:
  • 107 Answers
Nothing simple unfortuantely. With wireless technology, your only options are to either (a) imcrease the power of the transmitter (which, since you already tried using fresh batteries - is out), (b) improve the antennae of the receiver (which, I doubt you have access to in the product - so that's out). There are technologies available to put an RF-repeater to extend the range of a device, but by that stage you're putting in so much time and effort that I don't know if its worth the trouble.
Since you know the range is an issue, I would measure it, compare it to the spec of the system, and look to another manufacturer that has more history with RF. I recommend these:
http://www.lutron.com/Products/Components/PicoWirelessController/Pages/Models.aspx
Posted on Oct 18, 2010
Non runner on 2013 Eclispe Mobilioty Scooter, red light flashing.
U HAVE TO PUT +61 IN FRONT OF NUMBER TRY THIS NUMBER IN STAFFORDSHIRE 01543 570341 THEY M HELP IGHTI just rang this number & it rang 0249624007.Found this scooter repair in Newcastle contact Peter walz,02 4962 4007 Hi again ring this number they can help u with youre problem 0403 666 613..…,or 1800 726 000. good luck. check all connections between motor & controller 2 flashes,,3 flashes motor has a short circuit to a battery connection contact service center,..,.cheers
Sep 12, 2016 | Health & Beauty
Tip
Detroit Diesel Fault Codes
Code Description DDEC V Circuit
11 P 187 4 Chain PTO. Short circuit in the power
11 P 187 7 control system PTO wrong answers
12 P 187 3 Chain PTO. Short circuit in the ground
13 P 111 4-level circuit antifreeze. Short circuit in the ground
13 P 111 6 second-level circuit antifreeze. Short circuit in the ground
14 P 52 3 circuit coolant temperature intercooler. Short circuit in the power
14 P 110 3 circuit temperature antifreeze. Short circuit in the power
14 P 175 3 Chain oil temperature. Short circuit in the power
15 P 52 4 circuit coolant temperature intercooler. Short circuit in the ground
15 P 110 4 circuit temperature antifreeze. Short circuit in the ground
15 P 175 4 Chain oil temperature. Short circuit in the ground
16 P 111 3-level circuit antifreeze. Short circuit in the power
16 P 111 5 second circuit level antifreeze. Short circuit in the power
17 P 51 3 Throttle position circuit failed high
17 P 72 3 Bypass position circuit failed high
17 P 3 354 Relative humidity sensor circuit failed high
18 P 51 4 Throttle position circuit failed low
18 P 72 4 Bypass position circuit failed low
18 P 354 4 Relative humidity sensor circuit failed low
21 P 91 3 TPS circuit failed high
22 P 91 4 TPS circuit failed low
23 s 65 3 Oxygen content circuit failed high
23 P 174 3 Chain fuel temperature. Short circuit in the power
24 s 65 4 Oxygen content circuit failed low
24 p 174 4 Chain fuel temperature. Short circuit in the ground
25 no codes
26 s 25 November Aux. shutdown # 1 active
26 S 61 11 Aux. shutdown # 2 active (Incorrect SID. subject to change)
27, p 105 3 circuit temperature in the reservoir. Short circuit in the power
27 p 171 3 Ambient air temp circuit failed high
27 p 172 3 Air temp, circuit failed high
28, p 105 to 4 Chain manifold temperature. Short circuit in the ground
28 p 171 4 Ambient air temp circuit failed low
28 p 172 4 Air temp, circuit failed low
29 p 404 4 TCO temperature circuit failed low
29 p 351 4 TCI Temperature circuit failed low
31 S 51 3 Aux. Output # 3 open circuit (high side) S3
31 S 51 4 Aux. Output # 3 short to ground (high side) S3
31 S 51 7 Aux. Output # 3 mech. system fail S3
31 s 52 3 Aux. Output # 4 open circuit (high side) T3
31 s 52 4 Aux. Output # 4 short to ground (high side) T3
31 s 52 7 Aux. Output # 4 mech. system fail T3
32 S 238 3 SEL short to battery B1
32 S 238 4 SEL open circuit B1
32 s 239 3 CEL short to battery B2
32 s 239 4 CEL open circuit B2
33 p 102 3 Boost pressure circuit failed high
34 p 102 4 Boost pressure circuit failed low
35 p 19 March Ext range oil pressure circuit failed high
35 p 100 3 Chain oil pressure. Short circuit in the power
36 P 19 April Ext range oil pressure circuit failed low
36 P 100 4 Chain oil pressure. Short circuit in the ground
37 P 18 March Ext range fuel pressure circuit failed high
37 P 94 3 Chain fuel pressure. Short circuit in the power
37 P 95 3 Fuel Filter Restriction circuit failed high
38 P 18 April Ext range fuel pressure circuit failed low
38 P 94 4 Chain fuel pressure. Short circuit in the ground
38 P 95 4 Fuel Filter Restriction circuit failed low
39 S 146 2 Mechanical error EGR valve
39 S 146 12 Mechanical error EGR valve
39 S 146 return valve 7 does not meet the exhaust
39 S 147 2 turbocharger control mechanism does not respond
39 s 147 12 turbocharger control mechanism does not respond
39 s 14 147 current returns exhaust gases enough
39 S 147 11 turbocharger control mechanism does not respond
39 S 147 7 turbocharger control mechanism does not respond
41 S 21 0 Too many SRS (missing TRS)
42 S 21 January Too few SRS (missing SRS)
43 p 111 1 Low coolant level
44 p 52 0 ntercooler coolant temp, high
44 p 105 0 temperature in the reservoir above the norm
44 p 110 0 antifreeze temperature above normal
44 p 172 0 Air inlet temp, high
44 p 175 0 Oil temperature above normal
45 p 19 January Ext range oil pressure low
45 p 100 1 Oil pressure below normal
46 p 168 1 Low voltage batteries
46 S 214 1 RTC Backup Battery Voltage Low
46 S 232 1 Sensor Supply Voltage Low A3 & W1
P 0 47 18 Ext range fuel pressure high
P 47 94 0 The fuel pressure above normal
47 p 0 102 Turbo boost press high
47 p 106 0 Air inlet pressure high or TCBV diff press high
47 p 164 0 Injection control pressure high
48 p 18 January Ext range fuel pressure low
48 p 94 1 fuel pressure below normal
48 p 106 1 Air inlet pressure low
48 p 164 1 Injection control pressure low
48 p 351 1 TCI Temperature below range
48 p 404 1 TCO Temperature below range
48 p 411 1 EGR Delta pressure low
48 p 412 1 EGR Temperature low
49 p 351 0 TCI Temperature above range
49 p 404 0 TCO Temperature above range
More Fault Codes here Detroit Disel DTC
on Dec 20, 2016 | Cars & Trucks
Remote control has very short range
1. make sure battery is inserted correctly.
2. Do you have 2 remotes? Are they both exhibiting short range? Maybe bad remote if 1 is OK and the other is not.
3. Try this to extend range: hold remote under your chin and touching your chin while pressing the button. Your head acts as an antenna to extend the range.
Dec 03, 2014 | Cars & Trucks
Harley engine codes
P0107 Map Sensor Open/Low
P0108 Map Sensor High
P0117 ET Sensor Low
P0118 ET Sensor High
P0112I AT Voltage Low
P0113I AT Voltage Open/High
P0120 TPS1 Range Error
P0220 TPS2 Range Error
P0122 TPS1 Low
P0123 TPS2 High/Open
P0131 Front Oxygen Sensor Low
P0132 Front Oxygen Sensor High
P0151 Rear Oxygen Sensor Low
P0152 Rear Oxygen Sensor High
P0154 Rear Oxygen Sensor Inactive.
P0222 TPS2 Low
P0223 TPS2 High/Open
P0261 Front Injector Open/Low
P0263 Rear Injector Open/Low
P0262 Front Injector High
P0264 Rear Injector High
P0373 CKP Sensor Intermittent
P0374 CKP Sensor Synch Error
P0444 Purge Solenoid Open/Low
P0445 Purge Solenoid High
P0562 Battery Voltage Low
P0563 Battery Voltage High
P0501 VSS Sensor Low
P0502 VSS Sensor High/Open
P0572 Brake Switch Low
P0577 Cruise Control Input High
P0603 ECM EEPROM Memory Error
P0605 ECM FLASH Memory Error
P06415 V+Vref 1 Out Of Range
P06515 V+Vref 2 Out Of Range
P1001 System Relay Coil Open/Low
P1002 System Relay Coil High/Shorted
P1003 System relay contacts open
P1004 System Relay Contacts Closed
P1009 Incorrect Password
P1010 Missing Password
P1270 TGS Validation Error
P1351 Front Ignition Coil Driver Open/Low
P1352 Front Ignition Coil Driver High/Shorted
P1353 Front Cylinder No Combustion
P1354 Rear Ignition Coil Driver Open/Low
P1355 Rear Ignition Coil Driver High/Shorted
P1356 Rear Cylinder No Combustion
P1357 Front Cylinder Combustion Intermittent
P1358 Rear Cylinder Combustion Intermittent
P1475 Exhaust Actuation Position Error
P1477 Exhaust Actuator Open/Low
P1478 Exhaust Actuator Shorted/High
P1501 Jiffy Stand Sensor Low
P1502 Jiffy Stand Sensor High P1510 EFI Limited
Performance Mode
P1511 EFI Power Management Mode
P1512 EFI Forced Idle Mode
P1514 Air Flow Fault
P1600 EFI Module Processor Internal Error
P2100 EFI Motor Circuit Open
P2101 EFI Motor Circuit Range Performance (Actuation
Error)
P2102 EFI Motor Circuit Low
P2103 EFI Motor Circuit High
P2105 EFI Forced engine shutdown
P2107 EFI Module Processor Internal Fault
P2119 EFI Motor Throttle Body Range Performance
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
P2135 TPS Correlation Error
P2138 TGS Correlation Error (Twist grip sensor)
P2176 EFI Closed Position Not Learned
U Codes
U1016 Loss of ECM ****** Data
U1064 Loss of TSM/FSFM ****** Data to ECM
U1097 Loss of Speedometer ****** Data to ECM
U1255 ****** Data Error
U1300 ****** Data Low
U1301 ****** Data High
Harley Davidson 2008 DTC Code Reading (draft)
Harley Davidson DTC Codes - Unofficial Guide Page 3
B Codes
B0563 Battery Voltage High.
B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
B1123(HFSM) Left Turn Output Short to Ground
B1124(HFSM) Right Turn Output Short to Ground
B1125(HFSM) Left Turn Output Short to Battery
B1126(HFSM) Right Turn Output Short to Battery
B1131(HFSM) Alarm Output Low
B1132(HFSM) Alarm Output High
B1134 Starter Output High
B1135 Accelerometer Failed
B1136(HFSM) Accelerometer Tip Test Error
B1141(TSM) Ignition Switch Low/Open
B1141(HFSM) Ignition Switch Low/Open
B1142 Smart Security System Internal Fault
B1143(HFSM) Security Antenna Short to Ground
B1144(HFSM) Security Antenna Short to Battery
B1145(HFSM) Security Antenna Open
B1151 Bank Angle Sensor(BAS) Short to Ground
B1152 Bank Angle Sensor(BAS) Short to Battery
B1153 Bank Angle Sensor(BAS) High
B1154 Clutch Switch Input Short to Ground
B1155 Neutral Switch Input Short to Battery
Apr 11, 2014 | 2007 Harley Davidson FLHRC Road King...
2008 Harley Davidson DTC codes
P0117 ET Sensor Low
P0122 TPS1 Low
P0222 TPS2 Low
Performance Mode
Error)
P2122 TGS1 Low/Open
P2123 TGS1 High
P2127 TGS2 Low/Open
P2128 TGS2 High
U Codes
U1016 Loss of ECM Serial Data
U1064 Loss of TSM/FSFM Serial Data to ECM
U1097 Loss of Speedometer Serial Data to ECM
U1255 Serial Data Error
U1300 Serial Data Low
U1301 Serial Data High
B Codes
Jan 07, 2012 | Harley Davidson FLHX Street Glide...
I use it and it doesn't move were I want and I changed the batteries and reconnetcted it but it dousn't work.
I think you are speaking about a wireless mouse. If so, try to get the mouse and the wireless receiver in the PC as close as possible. They have a really short range and if they get more than 3 or 4 feet away will cause these kinds of issues.
The other possibility is some other device like a hands free phone in the house interfering with the signal. Try a wired mouse to see how that goes then you'll have a btter idea what the main cause is.
Feb 03, 2011 | Computers & Internet
My Craftsman remote won't close my garage door
If the remote opens and closes while inside the garage but not outside , there are a few things it could be. Assuming it was working fine before..
1. weak battery in remote.
2. remote itself could be bad. (unless you have more than 1 remote acting the same)
3. Logic board in opener is going bad causing limited range.Is the wire that hangs down from the opener straightened out? That is your remote antenna.Some people have coiled or even cut it off..reducing range.
4. Less likely but this can happen- interference from another electronic device, wireless routers, cell phone, new appliances etc.. can reduce remote range. Any new electronics recently purchased?
Jan 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener remote range limitted
Yes the receiver can go bad over time and lose range. Most likely the receiver cost plus the labor will cost as much or more than a new unit...depending on who does the repair. FYI another cause of reduced remote range can be signal interference from other sources which would be a little harder to track down unfortunately. Wireless routers, new appliances anything with electronics are a possible source of trouble.If you or a neighbor bought any new gadgets there's a small possibility of thatbeing the issue. But based on the age of the unit that's my first guess.
Rustym62
Apr 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a psp 3000 and it will not get a connection for the internet anywhere can u help?
please ensure that you have the wifi button in the enabled position. Your PSP will detect any wireless wireless network within its range as long as the wireless
adapter is switched on. The switch for this is on the left end of the PSP, near the analogue
thumbstick. If the switch is in the down position, the wireless network adapter is off; push the
switch into the up position and it'll turn it on. If you're not going to be using wireless
networking it's a good idea to keep it turned off as it'll make your batteries last longer.
Apr 13, 2009 | Sony PlayStation Portable (PSP) Slim...
Comm problem between range extender and BT home hub
make sure the SSID, channel & wireless key on router & all extenders are the same, also the default gateway on the extender has to be the IP address of the router.
Nov 27, 2007 | D-Link AirPlus G Wireless Range Extender...
Electrical Supplies Logo
53 people viewed this question
Top Carlon Home Products Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Carlon Home Products Electrical Supply Expert? Answer questions, earn points and help others
