Question about Audiovox PPC 6700
Ppc acts weird some times
i just got this phone i just wanted to know why it is that this phone does that white screen specially after i charged it. will that keep coming up or it usually goes away after i did a reset or am i gonna have to reset it every time i charge it?
  • 4 Answers
I had the same problem, I bought a new battery and it quit. Don't know if this helps, but seemed to fix mine.
Posted on Oct 03, 2008
Hi, I have a sony ericson w900i, i press the on button and the phone just comes up with a white screen and whatever i do apart from turn it off the screen remains the same, just white? please help...
hi
the problem relates to either the information not getting to the screen usually due to the phone getting dropped or banged around as sometimes the screen conection comes lose and stops the info getting to the screen the other problem could be that the screen itself has a problem and replacing it would solve both of these problems.
Their is nothing you can do or press to solve this problem its a case of replacing the screen witch isnt easy to do as youll need special tools and also get the parts can be a problem
Mar 18, 2008 | Lands Phones
Blackberry screen keeps turning white but is alright when i charge it
It sounds like you're having problems with your processor. I would take it into a repair shop
Nov 24, 2017 | RIM BlackBerry Curve 8520 Smartphone
The front and inside screen of my phone is all white. I can still send and receive calls but cant get to my contacts or check my texts, or see who's calling me, how can i fix this, or do i need a new...
Hi this is a very common problem with all flip and slide phones this problem also affects laptops and netbooks and the problem is the same solution with all of these.
now the problem you are having is with the date ribbon that keeps the screen connected to the circuit board in the bottom of the phone, this is connected by a thin data ribbon, now inside this ribbon is several single strand copper wires and over time and use these copper wires break and this then gives you the white screen.
now their is nothing wrong with your phone and it is working you have just lost the connection with the screen.
now as this is such a common fault then this make the part (the screen data ribbon) cheap to buy and it is really cheap to get fitted.
the problem is you will need to take it into a phone shop to have the work done as you need special tools to take the phone apart and fit the new part.
if you take the phone to a small independent phone shop then these will charge a lot less and should fix it whilst you wait if you take it to a big branded shop then you will have to let them send you phone off and this will take a couple of weeks and they will charge you for this service so taking it to a small phone shop will be your cheapest and quickest option.
i do a lot of these repairs myself so know its not a big job to do.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 31, 2010 | LG VX5500 Cell Phone
White screen - how do I fix that
Hi i must answer at least 10 of these a day with the white screen problem,
first of all this is a very common problem with all flip and slide phones and even laptops and netbooks.
now the problem is to do with the data ribbon that connects the screen to the circuit board this data ribbon is a thin ribbon that has several single strand copper wires running through it now when you open and close your phone this ribbon bends so as it keeps the connection with the screen.
over time these copper wires become brittle and break and this is what giving you the white screen
the only way to solve the problem is to get this ribbon replaced now as its such a common fault then this makes the part cheap to buy and cheap to get fitted, how ever its not something you can do yourself as you need special tools to remove and refit the ribbon.
your best and cheapest option is to take your phone to a small phone shop and ask them to replace this screen ribbon for you its such a common fault and that makes it a cheap part to get replaced.
so if you want to keep using the phone then it means your going to need to get this part replaced once you have got this part replaced you will have no problems using your phone.
Aug 29, 2010 | Motorola Mobility RAZR V3
I cracked my screen and i have another phone with a good screen that wont charge and i want to take out the good screen and put it in my phone. I would like some instruction on how to go about doing this....
It's pretty easy, but you need special tools usually, you need a mini Torx driver for a start. There are screws in the battery compartment to be undone, then the phone sort of clips apart, you use a special plastic thin egged tool that slides in between the case halves and gently twist and they snap open... If you look on eBay you will see screen replacement set's, that often come with the tools to do the job, have a look at those to know what you need. After the phone is apart, it all simply clipping cables into sockets etc. It all just very fiddly,and be delicate.
Feb 17, 2010 | Casio G'zOne Boulder Cell Phone
K700i Wont turn on or charge
your problem is a firmware which would mean you would have to get your firmware reset to factory sorry mate
Jan 11, 2008 | Cell Phones
Phone keeps freezing at sony ericsson screen
Try taking and leaving out the battery overnight. If that doesn't help, then try flashing your phone with the Sony Ericsson Update Service.
Dec 30, 2007 | Sony Ericsson W200i Cellular Phone
My cell keeps shutting down when i try to turn it on
i have a razor vx3 that was doing this every time i would get a phone call. I returned it for a new phone thought att.
Dec 03, 2007 | Motorola Mobility RAZR V3x Cellular Phone
White scren flashes when trying to switch on
hi a work in a phone shop the problem if the phone is where the pcb bord is there is a flex and it might of come lose.
Jan 01, 2007 | Sony Ericsson K750
Audiovox PPC 6700 Logo
Top Audiovox Computers & Internet Experts
Mohammad Abumuailek
Mohammad Abumuailek
Martin Murray
Starnley Johnwells
Starnley Johnwells
Are you an Audiovox Computer and Internet Expert? Answer questions, earn points and help others
