Question about Dell 2335dn Multifunction Laser Printer
Scanner bed makes grinding and crunching noise when scanning or sopying a document (only happens on the flat-bedpart, not the ADF). It sounds like the scanner is locked and trying to run anyway, but it isn't locked.
kehalim
  • 55 Answers
SOURCE: ADF Document Jammed
Have you tried manually rotating the ADF wheel back and forth, sometimes the sensors are OK but the rotators lose grip.
Posted on Oct 23, 2007
SOURCE: Scaning . . . Scanning. . .. not scanned
Not sure if this is the correct way around, but it worked.  Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
From here, you can determine and change your scan settings as needed;  then click "scan now" (thus by-passing the button on the actual AIO machine).  This scanned photos into my picture program so I could email to all the grandparents!
Posted on Oct 31, 2007
map9966
  • 2351 Answers
SOURCE: Hit scan and nothing happens...
Chat with a Dell tech for free. Click the link below.
http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_us_options?c=us&cs=19&l=en&s=dhs&~tab=1
Posted on Jan 31, 2008
MsMitch
  • 41 Answers
SOURCE: Scanning function doesn't work
If it copies fine, then it IS scanning. If you are trying to scan to your computer then you will need to open the program and follow the instructions.
Posted on May 28, 2008
SOURCE: Dell scanner has a line on document when using ADF
Clean the small glass, even the slightest dot, it will interpet as a line.
Posted on Aug 05, 2008
Scanner grinds when powers on
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Dec 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
Why do I have a black line down the side of my scanned documents?
If you are using the ADF (Automatic Document Feeder) there is likely debris in that section of the scanning glass. The ADF parks the scanner in place and moves the paper over it, if something is on the scanner it will show up as a line. Check the thin section of glass at whichever end of the scanning deck for dust and clean it with a dry towel. If this is happening with documents on the scanner bed the debris is likely in the scanner and will likely need professional servicing.
Jun 09, 2010 | Office Equipment & Supplies
ADF intake issue
if you mean the paper still on the adf "jam" try clean the roller " fedroller" in the begining of the druge paper in the adf
basher66
Nov 29, 2009 | Brother MFC 420CN All-In-One InkJet...
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Adf not listed in the drop down menu
The ADF has a minimum paper size. If you have set a size below A8 it may lock out the ADF option. Try setting the paper size to Letter. If this doesn't help, try swapping the scanners to see if the problem moves to the other PC. If so, it's a scanner hardware error. If it stays with the original PC, remove & reinstall the driver & the scanning application.
Mar 28, 2009 | Fujitsu fi-5750C Flatbed Scanner
ADF not working
Open the document feeder and look for an obstruction.
Clean the roller and pad with isopropyl alcohol.
Also look for a switch actuator trapped down or knocked off.
Dec 20, 2008 | Brother MFC-8840D All-In-One Laser Printer
HP Scanjet 5590 scans inmage on other side of paper on ADF Ok on flat bed
Really strange! May be the brightness is not controlled in the ADF mode, too bright to scan data on the backside also. Try reinstallig the software.
S. Mohan
Aug 18, 2008 | HP Scanjet 5590 Flatbed Scanner
Document Feeder
This sounds like a sensor failure - is it under warranty?
God bless,
Barrie Brown
Dec 07, 2007 | HP Scanjet 8250 Flatbed Scanner
ADF Document Jammed
Oct 23, 2007 | Brother MFC-8440 All-In-One Laser Printer
Dell 2335dn Multifunction Laser Printer Logo
193 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
