Question about Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400. I get 4 or 5 paper jams for every successful print. The error message indicates the jam is under the 'imaging units' but invariably it is beneath the component beneath the imaging units. I don't know the name of this component but it carries the ink before printing on the paper which gets jammed to the right of this component. This can be raised by a only a small amount making it difficult to clear. the paper is at room temp and humidity and without defects
  • 2072 Answers
SOURCE: xerox phaser 7400
Remove the tray, first look for a piece of paper that has come out of the tray inside the tray area.
Make sure the rolllers are snapped into place. The easiest way to verify that is to remove another tray and compare them.
Look to see if all the switches and actuators are in place.
Make sure you hear the tray up motor running when you close the tray.
Also inspect the paper tray itself for broken items. Compare it to another tray.
Posted on Feb 04, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 7400
That is caused 99 percent of the time by the fuser.
There is a solid aluminum roll and a silicon rubber ( pressure) roller in the fuser. The pressure roller either developes some flat spots from park ( non running) time and over time heat and use cause it to deform and become out of round. What then happens is when the paper enters the fuser it does so with a slight twist, and the pressure of the fuser, for lack of a better term, Irons in that crease during the fusing process.
Gave the explaination so you would understand what is happening.
Posted on Mar 07, 2008
SOURCE: Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Posted on Jul 18, 2008
SOURCE: PRINTER ERROR
There is a tiny little magnet that falls off and/or has reportedly been put on backwards (fell off is what happened to me) on the auger assembly. It's near the black auger chute on the end of a shaft. It's tiny--a little bigger than a grain of rice. I had to replace the auger shaft assembly but if you can find the magnet, you can super glue it back on.
Posted on Jan 17, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 850. Unexpected repeat printing
If I remember correctly, disconnect the print cable, then reboot the machine.
I saw that problem once and its been a while, but I do believe thats how I finally got it to stop.
Then clear out the print queue.
Posted on Mar 31, 2009
Can my transfer unit malfunction in less than a year?
check tansfer unit bias contact or reinsert hvt machine will be ready
Mar 29, 2014 | Xerox Phaser 7400/N Printer
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400 U28 error message
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
May 20, 2012 | Xerox Phaser 7400/N Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
08,045.43:5458 power outage happened, when power
This error indicates that the paper path motor stalled. Clear the paper jam, power off the printer for 30 seconds and then turn it back on.
Here's how to clear a paper jam from Xerox website, depending on the location of the paper jam: http://www.support.xerox.com/support/phaser-8560mfp/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 19, 2011 | Xerox Phaser 8560MFP Laser Printer
FUSER GETTING OVER HEATED IN XEROX PHASER 7400.SOMETIMES A4 PAPER GETTING JAMMED IN FUSER ,WITH A3 PAPER THERE IS NO PAPER JAMMING PROBLEM.
try to clean paper feeding rollers and chek fuser paper sensor, maybe paper comming too late...chek this just to be sure all its OK whit paper path and fuser.
...or replace fuser module!
Aug 23, 2010 | Xerox Phaser 7400DN Laser Printer
Printing
The Phaser 7400 starts at $2,799. see models and prices see cost per print Color: up to 36 ppm Black: up to 40 ppm First-page-out time as fast as 12 seconds 800 MHz PowerPC processor Maximum paper size: 12" x 18" All models come standard with 10/100Base-TX Ethernet connectivity Standard paper input capacity: 800 sheets Maximum paper input capacity: 3,000 sheets Finisher/stacker/stapler/hole puncher capable of handling up to 1,000 sheets Maximum duty cycle up to 150,000 pages per month What comes in the box show/hide contents Color toner cartridges (capacity: 9,000 pages each 1 ) Black toner cartridge (capacity: 15,000 pages 1 ) Imaging units (capacity: 30,000 pages per color 2 ) Waste cartridge (capacity: 30,000 pages 2 ) Fuser (capacity: 100,000 pages 2 ) Transfer unit (capacity: 100,000 pages 2 ) Finisher ships with 5,000 staples Power cord Software and documentation.
Aug 13, 2009 | Xerox Phaser 7400/N Printer
Jam at registration roller?
I can tell you "exactly" where your jam is !
If you open the top cover and remove the imaging unit. Look straight down, and you will see a black rubber roller about 8 inches long. this is the registration roller. If you remove the four screws (two on the left side, one in the middle, and one on the right) and gently lift up your wrinkled paper will be right there. Since your are not replacing the registration assembly you do not need to remove the two connectors that attach to the main board from the registration assembly. Just remove the paper, reseat unit, and put back screws. There is a test to see if your unit has the fix that gives the drive assembly a little more power to aviod jams in the future. This is a software fix.
I believe it's available on the xerox website as a postscript snippet. xx.ps
Mar 17, 2009 | Xerox Phaser 6250 Laser Printer
Xerox Phaser 7400DN Laser Printer Logo
125 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
