Question about Bakers Pride Y800 Pizza Deck Oven 44 in x 66 in Deck Heavy DutyChoose Gas Type
Need part number and size of oven door - Bakers Pride Y800 Pizza Deck Oven 44 in x 66 in Deck Heavy DutyChoose Gas Type
  • 905 Answers
Page 3 of the manual for part number, no reference to size of the door itself though.
http://www.bakerspride.com/pdfs/PartList/Y-800%20Parts%20List%20U6052A%208-08.pdf
Posted on Oct 12, 2010
The glass in the oven door exploded. I need a replacement door. Can you advise where to get one.
Contact the manufacturer's service and parts department to get the correct part number. They may also be able to supply it to you directly, but if you have the part number you can generally find it online, or locally if you are in a fair size city. Make sure to note what finish it is as the part number will differ for different finishes.
Dec 31, 2015 | Ovens
Need to remove the door, but my hinge doesn't look like the illustration in the manual
Open door alittle push down and pull out and up to remove door.. You may have to wiggle it a bit.
Hopes this helps Mike
May 23, 2015 | Thermador Ovens
Oven door keeps open ay ideas about the fault cheers
make this test and fix it. GOD BLESS YOU
Door Hinge
An oven door repair may be needed if the door hinge breaks or is bent out of shape. Oven doors have two door hinges, a left and right. On some ovens the same hinge is used, on other ovens the right hinge and left hinge have different part numbers. The door hinge sometimes is sold with all necessary parts and springs, other times the parts need to be ordered separately. An oven door repair for a door hinge is a relatively easy repair for a do-it-yourselfer.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Outer Door Glass
If the outer door glass is broken, it can be replaced. This oven door repair requires that the oven door be removed from the oven and layed down on a sturdy flat surface. The outer door glass is made of tempered glass. Use eye and hand protection when performing this oven door repair.
Nov 04, 2013 | Kitchen Ranges
The door handle is broken where it screws to the oven door. The threads are stripped. How can the problem be fixed?
there are a number of ways...first, if you have enough room, you can try to drill and rethread the next screw size....if you dont have the room, then there is a kit called a helithread...it consists of different drill sizes and little inserts that allow you to repair the threads that have stripped out...these kits are available at auto parts stores....if you wish to drill and re-tap the threads, then your local hardware store should be able to help you with the drill and tap sizes for the next screw size
Dec 08, 2010 | Ovens
Oven door falls open and will not close tight on my Jenn-air Single oven Model #SVE47100w
The hinges and receivers would need to be replaced on this. The hinges are part number 71003351 you need 2, they go inside the door, so the door would need disassembled.
The receivers (hinge receptacles)are part number 71002206 you need 2 also, these go on the side of the oven. You will need to pull the oven out a few inches to gain access to these
Jul 24, 2010 | Jenn-Air Electric Single Oven
Kelvinator F36 oven door glass measurements
you have to get high temp glass or it will shatter
May 24, 2010 | Ovens
Door Face needed (Glass broke, model discontinued, can't get part)
Linda, if you can't find a replacement door at local used appliance repair shops - check the Yellow Pages - look to see how the door comes apart.  It is probably held together with 6 or 8 Philips screws.  Get the door apart and take out the broken glass.  Call around to see if an appliance repair store has an oven they are discarding that has the same size glass or larger.  If the glass is too big, phone a few glass shops to see if they can 'cut' it down for you.  Some tempered glasses can be cut and sanded down to the precise size you need. Take your old broken glass to the shop to be used as a template. You should be able to get away with this type of repair for $50 if you compare prices. Cheers, Pavel
Oct 21, 2008 | Amana AOCS3040 Electric Single Oven
Gas oven door chrome facia
Hello jagereghty
You asked, How do I reattach the chrome facing on the outside of the oven door? Where do the screws go and what size are they?
Why is the front off the door? This means that the seal is now broken?????????????????
Sep 16, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Need glass replacement, what is part number or size
Glass tray or door glass? You should be able to get either part via Tritronics at http://www.wehaveparts.com
Aug 31, 2007 | Sharp R-303CW Convection / Microwave Oven
Bakers Pride Y800 Pizza Deck Oven 44 in x 66 in Deck Heavy DutyChoose Gas Type Logo
88 people viewed this question
Top Bakers Pride Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bakers Pride Kitchen Appliances - Other Expert? Answer questions, earn points and help others
