Question about Maytag MER5765RAS Stainless Steel Electric Kitchen Range
OurMaytag MER5765RAS oven only heats to about 235 degrees and that's it
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Oven turns on, but w2ill only heat up to about 120 degrees, you can reset and increase temp, but will only go to 150 degrees. Broiler works, but oven anf d oven clean do not work
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 18, 2011 | Amana Ovens
Kenmore Elite Electric Rnage 2 years old model 790.9662. If you set oven to 350...never gets there or takes forever. I gave up after 35 minutes abd it was only at 235. HELP! PLEASE!
the gas valve on the back isnt on... the valve doesnt stop the stovetop from working, only the oven. You are seeing the ignition element heating up and thats slowing heating the oven.
Jan 11, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
It takes 28 minutes for the oven to reach temperature of 375 degrees. The ready buzzer goes off in about 15 minutes. The temperature is 300 degrees. Is there any adjustments to be made.
what is your oven if is gas or electric, if is gas easy to preheat by using lower heating element, if electric? that your unit have convection? or not? coz some probelm of the oven is, 1 if the oven is no convection or your oven is single heating in upper element,if your oven have a timer and cut off in 15minute? dont use timer,use a manual timer by it your self,if you want to reach the degrees that you want check your oven if der a lower and upper heating element with convection function,that the one is the most easy way to reach the degree that you want to reach.
Dec 17, 2010 | Ovens
My oven will only heat up to 250 degrees
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 12, 2010 | KitchenAid KERC507 Electric Kitchen Range
Max 160 degrees celcius
heatman101
May 05, 2010 | Lofra MXD96MFEPI Dual Fuel (Electric and...
Maytag oven is not working
sounds like one of the elements may have blown.I would call manfacturer and give them year and model no.and tell them your problem they should be able to help you also any good appliance repair and parts store as well
Dec 27, 2009 | Maytag MER5765RAS Stainless Steel Electric...
Oven won't light, but if I tap on the box with wires connected to it that is behind the bottom drawer, it will light.
Kitchenaid slide -in-range gas oven KGST307HBS4 will not heat beyond 235 degrees slight smell of gas
Dec 18, 2009 | Frigidaire PLGS389EC Stainless Steel Gas...
Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Jun 27, 2009 | Ovens
Maytag MER5765RAS Stainless Steel Electric Kitchen Range Logo
77 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
