Question about Panasonic NV-GS35 Mini DV Digital Camcorder
My gs 35 monitor (lcd) is blank and some black and white lines are coming instead of picture / video. how can i rectify this problem
    Genius:
  • 1,812 Answers
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Posted on Oct 12, 2010
Screen is white with black vertical lines upon booting up. I can't get beyond this screen.
The video card (built-in on the motherboard) maybe faulty or the LCD screen is faulty.
Connect an external monitor to the video port of your laptop, power up the monitor first then boot up your laptop. If the video card id OK then the laptop will automatically divert the video to the external monitor. Then the problem is a faulty LCD screen.
If the external monitor also displays black vertical lines then you have a faulty video card and since it is part of the motherboard it is impossible to fix.
Feb 11, 2012 | Acer Aspire One Netbook 8.9" Notebook
Monitor is blank ,in the begining its white a.nd no picture after a while it becomes darker and daker
If the screen was white at all then this is a video board issue, now that its black, it means either something else went out,or the video board quit working
Jan 18, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Monitor picture comes on for only 1 second and then it is blank (black) Color bars appear to be OK (for that second) when running the Self-diagnosis function.
timothy henr, Do you understand how the new screw-in, curlie-Q, energy efficient, CFL light bulbs generate white light?? You will when you find out just what makes the WHITE fixya background on this web page you are looking at!!! Black screen of death can strike at any time!! Do a reply when finished with your research of repair video clips at YOUTUBE. Your search terms are: "lcd monitor disassembly" and "lcd monitor repair." That should get you started. Your unit could have a "switch-mode-power-supply" that detects a problem with itself or another circuit and goes into "full" or "partial" shutdown mode. You should be able to tell the difference if you shine a bright flashlight 1 inch from screen when it goes black!! Partial=still see win-desktop. Full shutdown=no see desktop!!! What wil you do??? Fix or just trade up for new display?? 12fixlouie
Oct 15, 2010 | Sony SDM-HX73 17" Flat Panel LCD Monitor
Screen went blank
cslkkent, Your description of problem fits the common "black" or "blank n black" lcd screen symptom. Because 98 percent of all desktop cold cathode fluorescent lamp back-lit lcd monitors use the same basic lighting technology, it will be in your best interest to view some video clips of CCFL back-lit lcd monitor repair on YOUTUBE just for info on typical causes of black or blank n black screen symptoms and how some owners do repair on the cheap! Yes, your unit may have BAD capacitors on the power supply printed circuit board or one "thermally intermittant" component solder joint which will need to be resoldered. Just do some research first. Read fixya profiles of "buddymc" , "budmrtn" and my own files. Good luck on your quest. 12fixlouie
Jun 09, 2010 | LG Flatron L1919S LCD Monitor
The sceen is black but wen u press the power
Stefieanne, The long, thin, "cold-cathode-fluorescent-lamps" are not staying lit anymore. Unit's "switch-mode-power-supply/CCFL inverter supply will need REFURBISHMENT to restore proper operation. SOFTWARE WON"T HELP YOU!!!!! Visit all links you find while doing some reading in my fixya profile to help you in the big decision you will need to make on what you will do with this "black" or "blank n black" screen ccfl back-lit lcd monitor. Do you have soldering pencil of about 35 watts and some solder and pliers and screwdrivers and even a digital voltmeter. Contract out the work $35 to $90 Tell us what your intentions are. 12fixlouie
Mar 21, 2010 | Neovo AG E-17A 17'' LCD Monitor
Lg 37le2r will only show black and white picture. Checked antenna ok.
I've encountered that experience before it needs some technical knowledge because the raster for rgb on your lcd is going bad and the video signal out put cable is mis aligned get someone to re align the raster and your video signal output cable
Jan 09, 2010 | LG 37LE2R 37 in. LCD TV
Va912b first cuts on with mostly blank but with broken strips of lines from top to bottom and have some together and some with blank seperation between them. then goes blank
joaye, First place to look would be the monitor's "switch-mode-power-supply" and /or the INVERTER circuit. When strange things start to occur with LCD monitor's w/CCFL backlighting, the first place to look would be the internal or external SMPS for the unit. You should be careful in your third use of the word "BLANK". Some monitors will be BLACK and not BLANK! Some will be both BLACK and BLANK. Read more Black screen stuff in my profile and you will understand WHY your unit is behaving like it is and some useful options you and other's like you have. Also visit www.ccl-la.com/badcaps.htm and www.lcdparts.com or YOUTUBE for videos on lcd repair or lcd monitor disassembly FYI DIY type stuff. I'm 12fixlouie on fixya.
Dec 05, 2009 | ViewSonic Computers & Internet
Moniter
Check the inverter board.
Sep 10, 2007 | BenQ T701 TFT 17" LCD Monitor
Panasonic NV-GS35 Mini DV Digital Camcorder Logo
149 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
