Question about Lexmark E360DN BUNDLE - QTY 4 - LMB OFFER Laser Printer
Printer has error that says - "900.00 Firmware Error"?
    Genius:
  • 1,018 Answers
900 errors are usually associated with fuser temperature issues.
Please call a service technician.
Posted on Oct 12, 2010
  • LexTech2011 Mar 15, 2011
    900 errors have nothing to do with the fuser, If it was a fuser temp issue it would give you a fuser error. 900 error are generally firmware conflicts on the system card. the only thing you could do is download and try to update the firmware and if that doesnt work then the system card needs to be replaced.
Printtech
  • 1087 Answers
SOURCE: x204n lexmark,900 firmware error to
The 900 error usually indicates a software or communications problem. The first thing to check is the base printer.
Turn off the printer and disconnect every cable, except for the power cord.
Turn on the printer and see if the error returns.
If the error does not return, try to print a test page from the Test Menu.
If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
Posted on Jul 29, 2011
SOURCE: 900 Service RIP software error
a 900 rip error is the engine card. located behind the system board (formatter) if you can get the printer to a ready state you can phone 1800lexmark and get a pin code from them costs about 15 bucks. if this flash does not work you will likley need a new engine card.
Posted on May 04, 2009
SOURCE: "900 firmware error"
"900 firmware error" on our Lexmark X204n printer. how do we fix it?
Posted on Sep 07, 2010
SOURCE: 900 service error with lexmark printer
LEXMARK 900 ERROR GENERALLY REFERS TO A BAD CONTROLLER BOARD.
Posted on Dec 13, 2007
Semi-Driver
  • 434 Answers
SOURCE: 900 Firmware error
The following link has Lexmark support and troubleshooting steps regarding "Error 900" for X54x:
Lexmark X544 Error 900
I hope this information is helpful.
Posted on Jan 17, 2010
Error code b0605
Hi Ekera
Code bo605 Firmware error B0605 on HP LaserJet P2055dn (Printer Troubleshooting)Firmware error B0605 on HP LaserJet P2055dn A common error message on the HP LaserJet P2055dn series is the B0605 Firmware Error. This error basically means the printer's firmware (controlling software) ...Download firmware from HP site & reload basic or updated firmware.
Cheers
Trevor
Jul 13, 2014 | HP Laserjet P2055dn Printer
Why is my kodak 5250 showing error code 3807?
Error: "System status failed" (3807) Published 08/25/2010 11:38 AM ' Updated 08/28/2012 05:23 PM ' Answer ID 1249
How do I resolve the error message "System status failed" (error code 3807)?
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary
If the error continues:
  1. Open the printer access door.
  2. Remove and install the printhead two times.
  3. Close the printer access door.
  4. Wait until the printer is ready to use.
If the error is resolved, upgrade your printer firmware:
  1. Locate and select the firmware for your printer.
  2. Follow the on-screen instructions to install the firmware.
If the error is not resolved, contact us.
Jul 01, 2014 | Kodak ESP 5250 All-in-One Printer
What kind of error is 49.0665
This is a firmware error, that may be caused by corrupt printjobs or network issues. Try to see if you can narrow down the problem to a specific application and also check the URL below for any firmware updates. The problem can also be caused by faulty firmware dimms, memory dimms, or a faulty formatter board, but the message normally persist when this is the case.
Go to htpp://www.hp.com/
support/LJ4200 or htpp://
www.hp.com/support/
LJ4300. Select Download
Drivers and Software. Check
for the latest firmware image
version at the bottom of the
page. If this firmware image
is newer than the one
installed on your printer and
your printer can receive a
firmware update, download
the newer firmware upgrade.
Not all HP LaseJet 4200/
4300 printers can receive
firmware upgrades.
Jan 14, 2013 | HP LaserJet 2420 Printer
I have a designjet 800ps 42" and send me the 79:04 error code, after this happen i change the belt and all the printheads, but it still send me the same error, it said Error Code:79:04 ...
Who told you to change the belt? 79:04 is a Firmware error.
Switch the Printer Off and wait a few minutes. Switch the Printer On again and check if the Error Code has disappeared. If the Error Code reappears, check for a new Firmware release. If the new Firmware release does not solve the problem, or if new Firmware release was not available, then contact the HP Response Center supplying the following information: - Model and Serial Number of the Printer. - Firmware release of the Printer
- The complete Error Code information, including the linefeed where the error occurred
Aug 19, 2011 | HP DesignJet 500ps (42 in.) InkJet Printer
HP Color LaserJet 3800 dtn printer. Error message says 49.4C06 Service Error
49.XXXXX ERROR A critical firmware error has occurred.
If the message persists with different programs and print jobs, turn the printer off.
Remove all memory DIMMs or thirdparty DIMMs from the printer. (Do not remove the firmware DIMM in the lower slot J1).
Remove the printer EIO card.
Turn the printer on.
If the error does not persist, install each DIMM and EIO device one at a time.
Turn the printer off and then on again after installing each device.
Replace DIMMs and EIO devices as necessary.
If the error persists, replace the firmware DIMM.
If the error persists, replace the formatter and calibrate the printer.
Jun 16, 2011 | Office Equipment & Supplies
I have code error 6202
To resolve this error:
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer: the firmware for your printer.
Install the firmware from the products site.
If the error continues and you cannot upgrade the firmware, contact the product company.
Hope this help.
If u find this solution please rate me.
Jun 11, 2011 | Office Equipment & Supplies
Error code 6202
Thank you for contacting FixYa printer support. Error: "Printer error" (6202) Published 08/25/2010 11:38 AM ' Updated 05/20/2011 09:04 AM ' Answer ID 1247
How do I resolve the error message "Printer error" (error code 6202)?
  2. Follow the instructions to install the firmware.
If the error continues and you cannot upgrade the firmware, contact Kodak Technical Support.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
I have a HP CLJ 4700dn printer which keeps on giving 49.2FCC
That error is a firmware error, you might try again to download and install the update, or try a new memory stick if you have additional memory installed.
Jun 22, 2009 | HP LaserJet 5550DN Printer
HP DJ 1050C Error 08B003007A0462
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Mar 12, 2009 | HP DesignJet 1050c InkJet Printer
Lexmark E360DN BUNDLE - QTY 4 - LMB OFFER Laser Printer Logo
2,762 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
