Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have a Lift-Master 1265 and the wire from the sensor came out. Can the sensor be opened and reattached?
    President:
  • 3,197 Answers
You might be able to very carefully cut the case open. Never tried it though.
Posted on Oct 12, 2010
Www chamberlain diy com
wrong site this is fixya we dont sell products
Apr 19, 2017 | Building Materials
Lift master remote not working
It seems that the reciever part is defective, likely to surge or lighting, you have to have that module replaced.
Tony
Apr 16, 2014 | Master Heaters Lift-master Sears Craftsman...
I have 2 lift master garage door openers that are producing errors when you hit the buttons to open 2 different doors. 1. I get error code 11 (sensor blocked or miswired)-there is nothing blocking...
If your garage door is up, and you break the beam (by walking through it, for example), you will get the "SENSOR WIRING INTERMITTENT CONNECTION ERROR CODE 1-4 SEE USER MANUAL". This is normal. Both of my Liftmaster 8550 openers do this. It's misleading, but this is what I've found to cause this error.
Oct 29, 2013 | liftmaster Lift Master 377LM 376LM 315 MHz...
Lift-master 1265 Garage Door opener clicks but nothing happens
CHECK ON THE OPENER FOR A RESET BUTTON, IT MAY HAVE JUST POPPED.
Apr 10, 2013 | Sears Craftsman LiftMaster Chamberlain...
Lift master cablesi removed the cables and doors sectional doors to fix .how do i set the tension. and the roller brackets is there a diagram to tell how to install,there a two holes and i can't...
Please do not attempt to set the tension your self. Call a garage door service Co. Broken arms and fingers result. It is not worth the attempt. Those tension spring do all the lifting of the door and have to much torque to mess with.
Jul 21, 2011 | liftmaster Garage Door 1/2 Hp
My EFX elliptical provides an error 44? and shuts down in the middle of my work out. I notice this is only an issue when choose a course that is weight loss when the EFX has to incline and decline. When...
Precor Error 44, Un-commanded Lift Motion Probable Cause 1. Intermittent or bad connection in the lift position sensor(potentiometer).
2. Lift position sensor (potentiometer) is bad.
3. Lower PCA is bad.
Corrective Action
  1. Bad or intermittent connection of the lift position sensor (potentiometer) is the most common cause of the error 44. Inspect all wiring and connections related to the lift position sensor (potentiometer). Repair or replace wiring connections as necessary.
  2. Monitor the lift position number displayed while operating the lift in diagnostics mode. If the reading makes large changes or is erratic, the lift position sensor (potentiometer) is likely bad. Replace the lift position sensor (potentiometer) or lift motor if the lift position sensor (potentiometer) is internal to the lift motor.
  3. If the lift moves without any command entered either manually or through a program, replace the lower PCA.
Precor Error Code 44
Jan 21, 2011 | Precor EFX 546i Elliptical Version 4
I have a Chamberlain 1265 Lift-Master Professional. Does that model still exist or if not, what has replaced it. Also who carries it
I know that that is a lift-master opener. chamberlain owns lift-master. but if its a new opener your looking for try the lift-master 3800 jack shaft opener. it features a low profile design that mounts next to the door instead of on the ceiling above the door, and also incorporates a battery backup so that you will never be locked out again.
Oct 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1265 garage door opener, tried to
On the side of the motor unit you will find the 'down limit control'. Using a small screwdriver turn this control in the same direction as the arrow printed on the cover. Some tweaking may be necessary to get it just right.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Open case, & see if white shavings from gear stripped out are laying on bottom of case.
Dec 15, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
115 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
