Question about Tecnik 24 in. TKD795/3 Built-in Dishwasher
No water from top and bottom arm
I have a Tecnik dishwasher, it has water going to it but when the door is shut and the program is started both the top and bottom arm do not rotat and no water comes from them. I have taken them off and made sure they are clean and they are.
  • havon Jan 27, 2009
    the arms of My dishwasher do not seem to rotate. The water comes to the dishwashe but it does not make the arms to rotate.
  • 833 Answers
I'm not familiar with that exact unit. However, all dishwashers use a solenoid valve and pump to either send the water to the drain or to the arms. If the water drains, the pump is good. Check the solenoid valve. It may be jammed (toothpicks and food particles are wonderful) or burned out. If the valve is good and working, your timer is a suspect.
Posted on Jun 02, 2008
Tecnik Integrated 795/2
Unfortunately you may have lost the controller or if you are lucky just a loose wire. You can get to all of this by taking the door cover off. If it is not a loose wire the control would be my next best guess. Sometimes they just go.
Sep 06, 2012 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Hi, We have Tecnik Dishwasher TKD 795/3 it wont seem to drain the water, we have tried to clear the pipes but they seem to be clear, Can you give us any tips on how to sort this problem out? Thank you
Hi, if the water doesn't drain from your dishwasher, check the drain line and pump..
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Jun 25, 2011 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
My dishwasher does not clean all of the equipment within, i have noticed that the top and bottom water rotary spray arms do not spin when machine is on.
Check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it.
Mar 01, 2011 | Tecnik Dishwashers
I have a bosch dishwasher silence , when it finishs wash i open the door and find the tablet falling on the bottom or hanging on the container of the tablet part, which did not use at all..please advise,...
Check top basket is straight and moves back fully, remove top spray arm and check holes are not blocked. The water pressure from the top arm is deminished if they are blocked and once the dispenser door opens it is the top spray arm water that propels the tab into the tank. Also, check that when your tallest item is in the bottom basket it does not obstruct the rotation of the top one.
Hope this helps to give you a starting point to remedy fault.
Jul 22, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My frigidaire dishwasher does not wash on the top
Insufficient water can cause your symptoms
Nov 02, 2017 | Frigidaire Dishwashers
Tecnik built in dishwasher
These arms spin based on water pressure generated from the washer itself.
Run the washer. As soon as the washer is full of water and the wash cycle starts, open the door and verify that you have at least a couple inches of water in the machine. If there is not enough water in the machine, the pump will not be able to provide pressure. If this is the case, the filling sensor is malfunctioning and will need to be checked.
There's a pump that provides water pressure. It's at the bottom of the machine beneath the lower rotating arm, probably beneath additional plastics. Remove these two items and verify that there is no debris blocking water from reaching the pump as if this is the case, water pressure cannot be generated.
Good luck... let me know what happens, and please rate accordingly.
Nov 11, 2007 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
Oct 29, 2007 | Tecnik TDW2677 Built-in Dishwasher
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Tecnik integrated dishwasher 795/2
make sure all filters are clean.make sure the wash arms are not cracked at the seam.if all that checks good you could have an obstruction to the pump.also check to see if you lose any water when running a cycle because the drain valve may be stuck open.the other possibility is that the impeller on the pump is worn or broke.
Aug 27, 2007 | Frigidaire 25 in. FDP750RC Free-standing...
Tecnik 24 in. TKD795/3 Built-in Dishwasher Logo
216 people viewed this question
Top Tecnik Dishwashers Experts
Renee Knafel-Bullock
 Mikey
Mikey
Are you a Tecnik Dishwasher Expert? Answer questions, earn points and help others
