Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
Samsung 40" LCD turns itself off and on
My samsung LNR408D lcd tv turns itself on and off multiple times when it is first powered up, and seems to stop when used for more than 30 mins. It has done this since 3 months after purchase, it went in for repair and the PSU was replaced. After a few months it did it again, and this time the PSU and PCB were replaced. Now 8 months later it is doing it again, and is out of warranty. Can anyone help please?!!! I have the same problem, i thought it might be dust so i gave the tv a blast with the wifes hairdryer and it made no differance, so i tried knocking it gently in various places when the problem occured and you guessed right it doesn't make a scrap of differance. the problem happens a lot when the tv is first turned on but after an hour it doesn't seem to happen or if it does it's only once an hour, the annoying thing is that i am about 6 months out of warranty & the tv cost over a thousand pounds
  • davidsuther Jun 30, 2008
    My TV behaves in the same way( except I have not left it for>30 mnutes) I had ther retailer and his engineer out, but they seemed unsure of the problem and have taken the TV away.
  • Anonymous Mar 21, 2009
    I have the same problem! Every morning when I first turn the tv on, it makes repeated clicking noises like it's trying to come on but this continues for up to 10 minutes until finally it comes on. Sometimes when it finally comes on, the screen has nothing but multi colored lines and then I have to start the whole process over again. However, once it does come on with a normal picture, it usually works fine the rest of the day unitl I turn it on again the next morning.
Try to tighten all screw around the power Supply to make a better ground ...
Posted on Jun 02, 2008
Problem with Samsung LNR408D 40 in. HDTV LCD Television Broken HDMI port HDMI port in rear of TV seems to be no longer connected to board. How much would that cost to get fixed and/or how easy is it to...
After you are sure you have hooked up the receiver to the TV properly and with the proper setting in the menu, if you are still having problems then you need to change the main board (the one with all the jacks on it). You will have to take the back from off the set. You will have to get the number from off the board itself and it should start with BN94-. Do a search on ebay with the part number or go to shop jimmy.com for price and availability. Also try to google search. The board is easy to change just unplug and unscrew from the panel.
Nov 07, 2011 | Samsung LN-R408D 40 in. LCD HDTV
I have a samsung lnr408d that has an issue. I
I'm curious, what were your TV's symptoms before you swapped power boards?
Does you're TV have an "a/v board"? that is, an integrated controller for both the LCD and the speakers that is separate from the motherboard? I've never seen them integrated like that, but if so, you might try replacing it because it sounds like a cheap solution.
The most likely problem however is the motherboard, which as you probably know can be pricey to replace.
Mar 19, 2010 | Samsung LN-R408D 40 in. LCD HDTV
My Samsung LNR408D TV is having color problems...
I would replace the main board (Audio/Video Board).
Nov 08, 2009 | Samsung LN-R408D 40 in. LCD HDTV
Sounds like a backlight going bad or possibly the inverter. Check each backlight first for dark discoloration on the ends. If that checks out good then it's the inverter.
Mar 17, 2008 | Samsung LN-R408D 40 in. LCD HDTV
Samsung lcd tv le32r8
perchè quando collego il computer al televisore l' audio è assente?
Oct 15, 2007 | Samsung LN-R409D 40 in. LCD Television
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
205 people viewed this question
Henry  Thomas
Henry Thomas
