Question about Optoma HD70 DLP Projector
Display problem after bulb change
Everything was working fine when I changed my lamp. After replacement I turned it back on and the display was cut in half my a largeblack vertical line. THe top part of the screen was displayed at the bottomand the bottomof the screen started half way up. It reminds me of when the vertical is out on an old TV and the screen is slowly scrolling up. I hope that makes sense. I have tried evverything and have been searching for an answer for hours.
  • 796 Answers
The vertical display IC must have gone..
you need to replace it
Posted on Jun 01, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Replacing front turn signal on 2002 Hyundai Elantrs
Push down & turn to the right- clockwise to install
Jul 23, 2013 | Hyundai Motor 2002 Elantra
When you trun on my panasonic PT-61LCX65 tv it makes no sounds the light blinks green. and then red and turns off. what is wrong. i have looked at the buble and it looks fine.
does the TV bring out sound even as the screen display is dark?
How long have you been using this TV and have you ever changed the lamp/bulb? Problem should be from the TV lamp/bulb.
Have the lamp replaced and hopefully, your screen should be perfect as before.
Let me know if you need directions in replacing the lamp, even though it is very simple replace.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Panasonic PT-61LCX65 61" Rear Projection...
How do I replace backlight on my bc895xlt
Greetings,
The bulbs can be replaced,
Remove covers taking care of the speaker wire. Remove screw for the green wire on disp. board and then the two screws holding the display board in place. Carefully remove the metal shield can with the four locking tabs. there are four grain of wheat lamps, two on each side of the display 12v/60mA DC. lamp # 7219 and radio shack sell them They are located in the white rubber holders on each side of the dissplay. unsolder the wires, pull up rubber white holder, remove bulbs, remove rubber light covers and put these on new lamps, slide lamp wires into rubber holders and then holders back to display pcb. Solder wires into place and repeat on other side of display. Usual common sence applies, be carefull, ect...,.
Apr 10, 2010 | Uniden BC895XLT Base Scanner
How do I change the bulb for the radio station display?
I'm assuming this is an LCD back lit display. To replace the lamps (usualy more than one) you will need to unsolder all the contacts on the LCD display. Usualy 20 or more contacts. The lamps are soldered through the circuit board and are usualy grain of wheat leaded types. Some lamps are wired in series so if one goes out they both go out. Others are wired in parallel in wich case one fails and the dimmer display is ignored until the other one fails. Usualy two 6v lamps for series or two 12v lamps for parallel. If in doubt try measuring the supply voltage to the lamps before removing the display.
Mar 28, 2010 | Harman Kardon Audio Players & Recorders
Still getting "Projection lamp is nearing end of life"
KDF46E2000 - Change Lamp Warning - Reset
Bulb is most likely OK. Original bulb in Sony TV is Philips, label on bulb usually says Philips. Sony don't make bulbs. Sony Cost is usually 1.5 times other sources. Many shopping cart operations sell condemned, reject or poor quality electronic service items because cost of return and fooling with them is excessive. This is obvious and widespread with convergence ICs and other parts.
Lamp timer needs reset. This is usually an automatic function. TV detects Increased lamp current from previous failed bulb or weak bulb condition and resets automatically. TV must be unplugged for lamp replacement for this to work. Occasionally it must be reset manually, as below:
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a
second of each other:
DISPLAY Channel 5 Volume + POWER .1. Access Service Adjustment Mode and select the Service Menu that
contains the Category with the Adjustment Item you want to change.
2. To change the Category, press 2 or 5 on the Remote Commander.
Note: Pressing 2 or 5 only changes the categories within the
Service Menu displayed. To change a Category on one of the other
Service Menus, press the JUMP button until the correct Service
Menu is displayed.
3. To change the Adjustment Item, press 1 or 4 on the Remote
Commander.
4. To change the Data Value, press 3 or 6 on the Remote
Commander.
Note: To go back to the last saved Data Value, press 0 then ENT
on the Remote Commander to read the memory.
5. To save the changes, press MUTING then ENT to write into
memory.
6. To exit service mode, turn the power off by pressing POWER .
Wait 2 minutes before restarting the set to allow the fans to
completely shut down or the Service Menu will appear on the screen.
easyab
ConvergenceRepair.com
__________________
Feb 27, 2010 | Sony KDF46E2000 46" Projection HDTV
I just replaced the DLP Lamp and housing on a 50' Samsung DLP tv.
CK your Fans make sure they are running or set will not come on.also if you can solder resolder power supply board.
Apr 02, 2009 | Samsung 50" Slim-Depth DLP HDTV
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
C20x lamp error
This is due to thermistor problem. Near to the lamp one thermistor will be there please check connectivity. if it is failed please change the same.
Regards,
prakasam
Mar 05, 2008 | Sharp (BQCPGC20X1) Projector Lamp for...
Optoma HD70 DLP Projector Logo
238 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
