Question about Bunn Dual SH DBC
How many ounces or cups of ground coffee is standard for a Bunn dual dbc to make a 1/2 gallon of brewed coffee?
  • 35 Answers
For a half gallon of brewed coffee you should start with a "volume" measure of 10 oz. The reason I recommend a volume measure is because the weight could be completely different using light roast or dark roast coffees. Brewing by volume you can have consistency throughout. The main object is to have the same surface area of grounds for your brewing. The 10 oz. volume should equal between 3.75 and 4.25 ounces by weight. Adjust by taste to your palette but don't sway too low in amount of grounds, otherwise you will stand to "over-extract" and your coffee will taste bitter and will have no body or mouth-feel.
Posted on Oct 13, 2010
Only brewing half of decanter
Remove and clean the spray head above the filter basket. If it still under fills, there could be a problem with the dispense solenoid valve.
Apr 22, 2014 | Bunn Dual SH DBC
Tip
How to calibrate a Bunn CWTF commercial coffee brewer
1. you need a 64 ounce graduated measuring cup or bucket
2. make sure the brewer is heated up to temp and the green light on the front is lit
3. open the front panel of the brewer
4. put the microswitch on the circuit board to "unlock" position
5. make sure the sprayhead is cleaned and open, the brew basket is on, and the measuring cup is in place to catch the water
6. press and hold the brew switch until the inlet solenoid clicks 3 times, then release
7. once the water level is at about 40 ounces, turn the main red switch off and let the rest of the water come out
8. if it brews short, press and hold the brew switch again until the 3 clicks, then press and release the brew switch for 2 more second of brew time (up to 5 times per brew)
9. if it brews too much, press and release the brew switch for two less seconds of brew time (up to 5 times), then press and hold the brew switch until the 3 clicks then release
10. once you get to 64 ounces, put the switch on the circuit board to lock and replace the panel
11. enjoy!
on Jan 15, 2015 | Bunn CWTF 15-APS Coffee Maker
Dual00000000 serial brew wise
Change the membrane. ..bad membrane..
Apr 15, 2013 | Bunn Dual SH DBC
45 cup coffee urn How much water and how much coffee?
20 cups of coffee needs 2 cups of coffee grounds
30 cups of coffee needs 2 1/2 cups if grounds
40 cups of coffee needs 3 cups of grounds
45 cups of coffee needs 3 1/2 cups of grounds
1 cup brewed coffee = 5 fluid ounces
* use standard measuring cups
Oct 22, 2010 | Salton Melitta MEU45 Stainless Steel -...
How many tablespoons of ground coffee are needed per cup of water in the Smart Brew coffee maker?
For ground coffee, use 1-1/2 (one and one-half) tablespoons of beans per 6 ounces of water.
For whole bean coffee, use two tablespoons of beans per 6 ounces of water.
Coffee strength is a very personal preference, so use these numbers as a guideline for middle-of-the-road coffee, and adjust to make the coffee that you like to drink.
Sep 30, 2010 | Black & Decker DLX900 12-Cup Coffee Maker
When I put in, 6 cups of water, if the 10 cup Bunn coffee maker after it has sat overnight, it only expels about 4 - 4.5 cups. I don't think it can all be evaporating or being absorbed in the grounds can...
look for water leaks around pot. Otherwise do a daytime brew to compare your difference between the amount poured in and what comes out. Please note that less water should mean using less ground coffee. Suggest 1 heaping table spoon per brewed cup.
Feb 10, 2010 | Bunn 10 Cup Home Coffee Brewer
Coffee grounds in bottom of commercail size coffee maker
If you will call 800-286-6070 we can help you with this.
Nov 01, 2009 | Bunn 10 Cup Home Coffee Brewer
Can set at 1/2, 1, or 1 1/2 gallon and get only 2
There is a set lock on the timer board, if you've tried that already then check solenoid valve, make sure it works, if yes then problem is timer board.
Mar 25, 2009 | Bunn SINGLE, includes One 1 Gallon Server
Amount of coffee to use
This is from the FAQ section of West Bend's website at www.focuselectrics.com:
As a guideline, use the following amounts of ground coffee for the number of cups being prepared. Use standard measuring cups ( as used to measure flour, sugar, etc.) to measure the coffee. The amounts of coffee below will brew mild to medium strength coffee which most people prefer. The amount of coffee can be adjusted to suit personal preference. As a guide, there are about 5 cups of coffee to a pound (16 ounces).
  • 12 - 18 Cups Coffee = 1 - 1 1/4 Cups Grounds
  • 20 - 25 Cups Coffee = 1 1/4 - 1 1/2 Cups Grounds
  • 28 - 36 Cups Coffee = 1 1/2 - 2 Cups Grounds
  • 40 - 45 Cups Coffee = 2 - 2 1/2 Cups Grounds
  • 50 - 60 Cups Coffee = 3 - 4 Cups Grounds
  • 70 - 80 Cups Coffee = 4 1/2 - 5 Cups Grounds
  • 90 - 100 Cups Coffee = 5 1/2 - 6 1/4 Cups Grounds
  • Hope this helps. You might also be able to download the manual from there if you look for your model.
    Sep 23, 2008 | West Bend 13500 Coffee Maker
    Bunn Dual SH DBC Logo
    226 people viewed this question
    Top Bunn Coffee Makers & Espresso Machines Experts
    Kelley Hopper
    Jim Y
    Jim Y
    pawnpower
    Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
