Question about Audio Technica AT-PL120 Turntable
I just set up my audio technica AT-PL120 for the first time, and I can't stop the tonearm from drifting back to the rest. I can't get the stylus to stay straight unless I add more on to the counterweight, which is not going to be good for my records. My anti-skate is set at 0 and the turntable is on a level surface. What should I do?
    Problem Solver:
  • 9 Answers
KEEP THE ANTI SKATE AT 0 FOR NOW,then you need 2 balance the tonearm with the rear counterweight so it just hovers at around the height of the platter.now you need to zero the gauge on the rear counterweight being carefull not to turn the counterweight,then check again that the tonearm still hovers.then screw counterweight inwards untill the dial on counterweight reads between 1.5- 2 grams dependin on tracking weight of cartridge.then adjust antiskate 2 whatever u set the tracking weight to.i would also double check with a spirit level ur level surface
Posted on Oct 13, 2010
Where can I purchase a replace tonearm locking clip for an Audio Technica AT-PL120?
Audio technica will send you a replacement clip free of charge. Just send their service department an email asking for one.
Feb 21, 2012 | Audio Technica AT-PL120 Turntable
I'm trying to figure out what type of cartridge the ATP-2 is which came with my Audio Technica AT-PL120 Turntable. Is it "Moving Magnet" or "Moving Coil" or something else?
These are the specs for your cartridge - it is of the moving magnet variety. Vector-Aligned Dual Magnet design and A-T's exclusive Paratoroidal signal generator. This unique signal-generating system is composed of a unified, laminated coil core wound with a single piece of wire. Internal mechanical and electrical connections are eliminated, minimizing magnetic losses and assuring better signal transfer. PCOCC wire
Cartridge Specifications (ATP-2)
Frequency Response 15-22,000 Hz
Channel Separation 23/17 (dB at 1 kHz/10 kHz)
Vertical Tracking Force 3.0 - 5.0 grams
Stylus Construction Bonded round shank
Output 5.3 mV at 1 kHz, 5 cm/sec
Channel Balance 1.5 dB
Stylus Shape 0.4 x 0.7 mil elliptical
Cantilever Alloy tube
Jun 14, 2011 | Audio Technica AT-PL120 Turntable
My PL120 turntable purchase new skips often and will hardly work with music played at a loud volume
The first problem could be the stylus needs cleaning. Please shine some light on the stylus ( needle ) and see if it has picked up dirt from the record groove. This will prevent the stylus from tracking the song properly. Clean using a fine brush in the direction in which the stylus passes the record groove i.e from back of the pick up arm to front- NEVER SIDEWAYS.
Next check the counterweight adjustment at the back of the Pick up arm. The tracking force should be between 1.5 to 3 grams depending on the brand of the cartridge. What ever be the chosen weight the antiskating knob should also be set to the same number.
The skipping can also be because of heavy bass vibration traveling up the body of the Turntable.Good turntables have a floating suspension to prevent this. The tuntable platter will be suspended on springs.You can place it on a rubber Matt or move it away from the speakers ,esp: sub woofers.
Apr 06, 2011 | Audio Technica AT-PL120 Turntable
I bought an Audio Technica USB AT LP 120 Turntable last June. It worked fine as a turntable, but I was never able to get good recordings of vinyl without distortion. But now I have another problem: when...
Sorry it could be the cartridge! They can fail at anytime, only the stylus will wear with time. However it could be the amplifer's magnetic cartridge pre-amp. If you look inside your amp and trace back from the phono socket you should find the pre-amp. If it is distorting on both channels it's probably an IC that has failed.
Dec 05, 2010 | Audio Technica USB Turntable
How do you replace the tone arm rest (plastic holder/lock) on a Audio Technica AT-PL120
Hi, there is a screw that fits up underneath the clip that needs to be undone to remove the tonearm rest clip. styluscity@gmail.com
Sep 13, 2010 | Audio Technica AT-PL120 Turntable
Brand new audio technica at-pl120 turntable not powering on; cant get turntable to spin
HELLO!
I don't know which country you are from, but if the mains plug has a fuse in it then replace it with the same type. If that does not do the trick take it back back where you bought it and get a refund or a replacement! There may well be an INTERNAL fuse inside the unit on the power supply unit which may be at fault. If it is under warranty don't open the turntable yourself - take it back - I WOULD!
All the best!
Jul 12, 2009 | Audio Technica AT-PL120 Turntable
45 and 33 sound slow
Here's a procedure for setting the tonearm...
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable and place it on a perfectly level surface.
Set the Tracking Force and AntiSkating to 0.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter Clockwise a few turns to disengage any cueing mechanisms.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
If you don't have a Stylus Tracking Force Gauge. Dial in the prescribed tracking force and a corresponding anti-skate reading. Play records.
May 04, 2009 | Audio Players & Recorders
Audio-technica atp-2 cartridge with a atp-n2 stylus
Make sure the cart is connected properly, and check the manufacter's instruction with that cart. sometimes tonearm height and weights need to be adjusted for proper torque and sound.
Oct 26, 2007 | Audio Technica AT-PL120 Turntable
Audio Technica AT-PL120 Turntable Logo
916 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
