Question about Denon AVR-4308CI Receiver
Denon 4308 Hi I have the Denon 4308 connected vis HDMI 1.3 Cables to my Denon Dvd 1740 DVD player and another HDMI cable connected to my Sony PS-3 . I have connected the 4308 to my Pioneer 508 Plasma television from the 4308's monitor out 1 HDMI connector . I am not using the 4308 to power or drive any other zone in the house . Finally i have connected the 4308 to B&W 683 ( bi-amped with the 4308 as the front ) the LCR 61 for the centre and the 685 for the rears as a 5 channel setup . My problem is that while everything is working great , i.e - the sound is output to the speakers absolutely correctly - As Long as my Pioneer Plasma Tv is also turned on . The moment i turn off my Plasma TV the sound goes off . So lets say i just want to listen to a CD via my Denon dvd player - do i have to keep the TV on ??? Also when i switch to listening to the FM tuner which is inbuilt into the 4308 it works as long as the Plasma monitor is on the moment i switch that off the radio sound starts going on and off . What am i doing wrong ? Basically all i want to do is that in case i want to listen to a CD or the tuner i dont want to have to turn on my Pioneer Plasma . Thanks in advance . Regards - Vishal.
  • 1,224 Answers
Ok sounds simple you ran the lines threw the tv instead all lines should be ran threw the sterio
see once you turn tv off this cuts the outputs out so now no sound will happen
your sterio should be equipted to take inputs of tv
you want everything to be inputed threw receiver thats why they call it a receiver the outputs on tv goto inputs on receiver
you need to redo your wireing so that this which i described is correct again
Posted on Jun 02, 2008
I have connected to my 2311: HDMI 1: Oppo BDP 83 HDMI 2: Denon DVD 1740 HDMI 3: Apple Mac Mini Issue: The Mac Mini works fine and I have audio and video through the receiver, but for the BD and DVD only...
You have to check the digital audio assignment of you AVR for HDMI 1 and HDMI 2. There is three options for the digital audio for HDMI 1 and HDMI 2. You can set it as optical ,coaxil, or the HDMI itself. In you receiver the assignment may be in optical input or in coaxial input for the two HDMI inputs.
1. Go to the system setup
2. Select input setup
3.Select input assignment.
4. Select all the three input ,you are using as HDMI
Apr 11, 2011 | Denon AVR-2311 Receiver
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
Hello I need firmware for denon 1740 Dvd. Cant not faind self.Thx
Go to the Denon Global Website and select Europe, once on the Europe site go to downloads the 1740 will show up in the model drop down menu. You'll need the unit Serial Number, good luck on that, I couldn't find one anywhere on my unit.
Next step? Buy a Sony.
Jul 16, 2009 | Denon DVD-1740 DVD Player
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Denon DVD-1740 component video to RGB cable
Jun 02, 2008 | Denon DVD-1740 DVD Player
HDMI connection???
Hi Greg,
Again, if you have a high definition dish box with HDMI output,and a dvd player with HDMI output,please connect them both directly to your TV HDMI inputs.
When watching TV(dishnetwork box).remember to switch the HDMI video inputs.
Same as your DVD player,you need to switch it under your TV video input.
May 28, 2008 | Denon AVR-2807 Receiver
Grainy Picture Denon 1740 DVD and Samsung 1080P LA40M81BD
Firstly, you should alter the picture settings on the TV. Most TVs have independant settings for tuner, scart and HDMI, so you may need to do this several times. Once for each.
Excessive contrast and/or sharpness on an LCD causes graininess, particularly around the edges of moving objects.
Check and adjust the following on the TV:
  • Contrast - about 65% max
  • Sharpness - 20%
These settings are a % of maximum, so you may need to work out a value if max is not 100.
Also turn off any contrast enhancements - (Contrast + / Digital
Contrast etc.) dependant on make.
I assume that you are using the upscaling facility of the Denon 1740 via an HDMI lead. If so, disconnect any other connections between the DVD and TV, particularly scart. If the scart is connected the TV will auto-switch to the scart input when you use the DVD, and you will not get the benefit of the high def connection.
This is probably obvious, but make sure the DVD is set to 1080p scaling, and you will need to manually select the HDMI input on the TV.
May 08, 2008 | Televison & Video
Help with audio sound
Had the same problem - have a 3-yr old Sony DVD without hdmi - used RGB for video (hooked it up directly to tv) and optical cable for audio (connected to OPT-2 in receiver) and problem solved. the standard red/wht audio cables also worked.
Jan 10, 2008 | Denon AVR588 Receiver
Denon Avr-588 setup
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
Jan 03, 2008 | Denon AVR588 Receiver
Denon AVR-4308CI Receiver Logo
388 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
