Question about Dishwashers
I have a hotpoint aquarius df23 dishwasher. when i turn it on for a wash there is no water coming into the dishwasher. i have put water in with a bowl and it works as normal until it drains the water out. my washing machine is plumbed in to the same pipework and it is working fine. does the dishawasher have a water pump that may need replacing????
Most likely you have an air lock in the dishwasher.
1. Refill the salt compartment.
2. Turn of the water supply at the mains.
3. Disconnect the diswashers water hose from the mains supply.
4. Lower the water hose and allow any water in it to drain from it.
5. Reconnect it and turn on your mains supply again.
Good luck.
Posted on Oct 07, 2008
    Scholar:
  • 110 Answers
Sound like a bad water inlet vavle, also make sure the water on off vavle under the sink is turned on I am saying this not to be funny but if you have had plumbing issues lately the plumber may have not turned the water back on.
Posted on Jun 01, 2008
Our Hotpoint Aquarius dishwasher initially had the Eco & Prewash lights flashing & standing water inside. We then turned it on in the hope that the standing water would drain, which it did. It then...
Is it a dishwasher a washing machine or a drier? Washing machines don't have rotating arms and you said "I've managed to get the drier to drain"
I will assume it is a dishwasher in which case it sounds like your pump has failed.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 25, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint aqarius dc26 dishwasher has stopped
this may be caused by a leak your dishwasher as a build in anti flood switch which stops water from entering when it leaks into the base of dishwasher . You may be able to check this for yourself by unplugging your dishwasher and slowly pulling it out and lean it back if water runs on to your floor you have had a leak .if at this point you turn it back on it might start to fill again .if it does start to fill turn it off again . it will need further examination to see why it leaking .if you feel you can't do this call your local engineer .
Feb 11, 2010 | Dishwashers
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Poor cleaning with Hotpoint NDA300Y 73BA dishwasher
be sure rinse aid dispenser is full ..also ck water level after fill should be almost to bottom of float
Nov 01, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint DF23: Wont go through full cycle
Sounds like you may have to replace the cycle timer.
Oct 28, 2008 | Kenmore 24 in. 16539 Built-in Dishwasher
Hotpoint aquarius dwf30 dishwasher
you can plumb into hot but there are some snags
first hot water pressure is often a lot lower than cold so the machine may take a long time to fill
second if the water is too hot it will destroy the resin of the water softener and you will see brown marks on the crockery.
third it a bit uneconomical as you will use a lot of hot water
May 18, 2008 | Hotpoint 24 in. DWF32P Free-standing...
No water comeing into dishwasher
WHAT YOU WONT TO DO FIRST IS CHECK THE WATER PRESSURE LISTEN TO HEAR THE WATER VALVE HUMMING ALSO LISTEN TO THE DISHWASHER DOOR LOCKING INTO POSITION
Apr 13, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius Dishwasher DWF31
MY DISHWASHER TASTES OF SALT AFTER EVERY WASH .I HAVE RINSED IT THREW AND IT STILL THE SAME
Jan 03, 2007 | Hotpoint 24 in. DWF32P Free-standing...
Dishwashers Logo
436 people viewed this question
Top Dishwashers Experts
