Question about Coleman Mach III Air Conditioner
Replacing a Coleman with a Duotherm, can the same thermostat and controls be used?
    President:
  • 1,515 Answers
Hi, yes you can use the same thermostat if you are replacing the unit that has the same sequence of operation. What I mean is, if the old unit is a gas fired furnace and outdoor condenser split system for the a/c you can use the same controls, or if its a package unit. Now, if you are installing a heat-pump unit in place of a gas fired central unit, you will need to pull more stat wire and buy a heat-pump thermostat to make it run.
Shastalaker7
A/C, Heating Contractor
Posted on Oct 21, 2010
Wiring from coleman rv ac unit has 6 wires and duotherm rv ac unit has 10--what do you do with other wires
you need a wiring diagram of each to see what they are for. heat pump, auxillary heat, inside sensor, outside sensor, electric heat, gas heat there are many different applications.
Aug 20, 2015 | Coleman Heating & Cooling
We are replacing a coleman air condiotoner with a duo therm unit and we are not sure if the wiring is the same
some of the wires from duotherm unit not used may be for external sensors not on the coleman unit. have to look at wiring diagrams to know
I have a Dometic DuoTherm ac/furnace unit in an rv. The thermostat got knocked off the wall and now the ac nor the furnace will work. Fan works in manual position only. What could be wrong?
When the thermostat was knocked off it may have damaged the wiring. I would start by checking continuity of all wires from thermostat to unit.
Feb 15, 2015 | Dometic Rooftop RV Air Conditioner
I have a Dometic DuoTherm AC/furnace in my RV. Thermostat got knocked off the wall. Now only thing that will work is the fan in the Manual mode. Heat nor air will come on. What could this be.
If you have properly re-attached all the wires to the old or newly installed thermostat, then I would suspect that one or more of the control wires to the heat pump have either been severed or pulled loose from the heat pump.
How do i bypass the furnace and still use the duotherm 57915.531
Do you have the digital thermostat? You can tell the thermostat you have no furnace. You should be able to disconnect power at the furnace, but the 12v power for the circuit board is provided by the furnace circuit on some systems so make sure you disconnect the wire going to the furnace and leave the wire feeding the circuit board.
Oct 06, 2014 | Coleman Dometic Duotherm Rv Air...
Does the fan shut off on dometic ceiling cover control model
that would depend on the fan setting of your thermostat
Jun 18, 2014 | Dometic Rooftop RV Air Conditioner
Just purchased a coleman popup with a Dometic
look on the compressor and give me the model of the compressor and i can tell how many btus it puts out
Apr 02, 2010 | Dometic Rooftop RV Air Conditioner
Furnace won't turn on, off, with or without remote
We hotwired the thermostat wires and the furnace started. That told us that the problem was with the thermostat. We took our remote control to another camper like ours and our remote worked their furnace. That told us that the problem was in the ceiling control for the furnace/ac. But the man who owned the other camper told us that he had a problem, too, and was told to unplug all the electric including the battery, wait 2 minutes, and hook up again. This might reprogram the circuitboard, and voila! It worked.
Feb 08, 2009 | Dometic Rooftop RV Air Conditioner
DuoTherm Model 59516.331 needs heat strip added
MODEL SERIES: 579XX, 590XX & 59516 (60XXXX, 61XXXX ON PAGE 2) ALL MODELS ARE PREWIRED WITH A POWER RECEPTACLE IN THE ELECTRIC BOX FOR EAS Y INSTALLATION
USE PN 3101121.030 HEAT STRIP,FOR NON-DUCTED MODELS
Dec 12, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach III Air Conditioner Logo
188 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
