Question about Sport & Outdoor - Others
I have a Nordic Track recumbent bike sl720 and the display will not work after pedalling. It has sat stil for almost a year. I have adjusted the reed switch but no success. Any advice? thanks
SOURCE: operating manual for cx1050 nordic track ellpitical
http://www.iconservice.com/pdf/NEL12940.pdf
I just downloaded a copy. It's 32 pages.
Posted on Feb 19, 2009
  • 19 Answers
SOURCE: Exercise bike is not displaying correct feedback
What do you mean it s not displying correctly?
Posted on May 14, 2010
  • 5370 Answers
SOURCE: I need assistance on replacing
Its fitted with bolts,you need right tool to remove the crank.Disassembling the bike's covers and parts to get to the bad assembly required a pair of snap-ring pliers and a gear puller for the crank arms. Replacement is a few minute job with the proper tools; without them you'll be going back to Sears to buy them, or waiting for their "home service." crank assembly.The assembly uses three sets of roller bearings, with the middle set in a "carrier" that causes them to lock against the shaft and the outer casing when turned in one direction, while freely turning in the other. This is how the "freewheel" capability is achieved. The outside end of this assembly rides on a roller bearing (supporting the pedal arm on the right side), and there are two more roller bearings in the frame supporting the remainder of the shaft to the other side (where the other pedal arm connects.) .
------------ To get parts.Please click the link below:---
http://www.iconservice.com/CustomerService/partsPartsList.do?model=28314&modelName=NORDIC+TRACK+SL700&version=0&company=11 ----------------
Keep updated.This will help.Thanks.Helpmech.
Posted on Feb 11, 2011
SOURCE: My "Edge 491r" recumbant bike
Same as above, have an Edge 491 with E1 and need to fix it
Posted on Feb 20, 2011
loriwadle
SOURCE: nordic track exp 1000 treadmill console
Hii sumazone, was just wondering if you ever found out what was wrong?? I am havng same problem. thank you
Posted on Nov 16, 2012
Where to get user manual for schwinn 230
Do you mean the Schwinn 230 recumbent bike? Then Schwinn has the manual for two models (released in different years) on their product manuals page: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . Expand the section on Recumbent Bikes and scroll through the list. The direct link to the owner's manual for the 2007 version is http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_130-230_OM_RevB_web.pdf . The 2013 version is here: http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.230-Journey2.0.AM.OM.WARR.EN.pdf . The newer model has a USB port for a flash drive, among other differences.
I hope this helps.
Jan 20, 2016 | Nordic Track Nordictrack Apex 4100i...
Can't remove right pedal shield
The shield will not come off unless you remove the entire crank, not just the pedal. to do this, you need to buy a CRANK ARM PULLER TOOL available for around $15.oo at any bicycle shop. Make sure to get one for a square tapered bottom bracket. Just used one, the crank came right off and the shield simply lifted away. here is a link to a YouTube Video showing the tool and explaining the process: https://www.youtube.com/watch?v=N63ofGcRCYQ
Jan 28, 2014 | Nordic Track NordicTrack GX 5.0 Pro...
I have a Nordic track C2050 treadmill one day everything was working great the next day the only the #1 and #7 speed button worked decline up and down stopped working plus all program buttons not work
replace the old batteries ( if your system has batteries, clean the spring contacts from oxide, corrosion, etc with contacts cleaners) put a new batteries.
2) tight and clean the ribbon cables from display board
3) tight and clean the uppers and lower connector very well.
4) adjust the REED switch, tight the connector, clean it, and test the reed for open or faulty. see the diagram attached.
Oct 25, 2013 | Nordic Track Nordictrack C2050 Treadmill...
No tension on pedals for nordic track trl 625 recumbent bike
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
God bless you
Apr 01, 2013 | Exercise & Fitness
Nordictrack gx 5.0 pro will not turn on
Did you ever find a solution to the dashboard of your Nortictrack 5.0?
Jan 20, 2013 | Nordic Track NordicTrack GX 5.0 Pro...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
I have a Nordic Track Viewpoint 3000, the display quit working although the incline and speed seem to be working just fine. Anything I could try to fix?
Dear Sir:
Please see the attached diagram for adjusting the reed switch, clean very well, and tigh the connector wires.
sincerely. God bless you
Apr 21, 2012 | Nordic Track Exercise & Fitness
Nordic track commercial 1300 manual
It sounds like reed switch inside the side panel located on the frame by the large pulley either needs to be adjusted or replaced. Try adjusting the switch first the clearance between the switch and large pulley magnet will be 1/8" if you have the same result then replace the switch.
Jun 12, 2010 | Nordic Track Exercise & Fitness
Sport & Outdoor - Others Logo
198 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
