Question about Lenovo IdeaPad Y510 Notebook
My battery backup goes very low what to do - Lenovo IdeaPad Y510 Notebook
  • 6,826 Answers
If the Uninterruptible Power Supply or UPS is not holding its charge, the batteries are getting old and the unit will have to be replaced.
Posted on Oct 12, 2010
My garage door opener beeps frequently but operating well. What is the issue & how can i resolve?
Sounds to me like your backup batteries are low. The back up batteries are there for use should you use power. You can try this -
  1. Unplug the garage door opener.
  2. Get into the back up battery compartment.
  3. Now unplug the connector to the battery pack and replug it in. This might help but if you continue to have this beeping then you will have to replace the backup batteries. You will not suffer any mechanical problems unless your electricity goes out.
Regards, Tony
Apr 14, 2011 | Chamberlain Powerdrive PD422D 1/2 HP...
My smoke/carbon monoxide detector keeps saying "low battery". I have replaced the batteries in all (5) detectors. They are hardwired. The one downstairs goes off continually and now the one...
My Smotec 3786A indicates not to install it in above 85% humidity.
One of my three seems to go off annually or so and this is what
recently put it down to. I was making an espresso coffee on the
stove and it generates a lot of steam and off goes the fire alarm.
I did change the battery to no avail.
Mar 28, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
Unit only works off battery, not AC.
there may high voltage or low voltage, ups goes on battery when high voltage and also goes on battery when low voltage acceptable range of window is 90vac to 130vac for 110v i/p
Mar 06, 2010 | CyberPower OR1500LCDRM2U UPS System
Orange 4 times then green, then black screen
This is telling you that the battery is low, replace the battery.
Mark
Dec 19, 2009 | Dell Latitude C610 Notebook
Comet 5-30KVA Battery problems when power goes off the battery no backup and the system shut down and error displays to battery
How old is the UPS? Have the batteries ever been changed? Sounds like you have open battery string(s), which would cause the UPS to lose power to load on loss of utility power. The batteries are your backup to the critical load. It only takes one bad battery in a string to compromise the entire string and render your UPS nothing more than a line conditioner.
Jun 30, 2009 | MGE Computers & Internet
HOW TO CHANGE OR CHARGE THE BACKUP BATTERY?
y hp6365 keeps telling me that i my backup battery is low..i keep charging my phone but the only the main battery is charging..how do i charge or change the backup battery?
Feb 17, 2009 | HP iPAQ h6315/h6365 Pocket PC
Error message "Backup Battery Very Low"
The MobilePro 900 back up battery is low and should be replaced. The battery is a CR2032 coin-cell battery, which is very common and can be purchased at most department and drug stores. Refer to section 1-7 of the "MobilePro 900 Handheld PC's User's Guide" for detailed replacement instructions.
Sep 14, 2005 | NEC MobilePro 900 Handheld
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
NEC has identified an issue where the system can erroneously generate the "Backup Battery Very Low" message. There are two possible solutions that will eliminate this erroneous low battery warning message (the first method is the preferred solution, the second method can be used if the update file is not available). Solution I. Install a new version of the driver that controls the battery monitoring circuit. 1. Download the Low battery warning fix to your desktop. 2. Using ActiveSync or a compact Flash Card, copy FixBatt_HPC2K.EXE to the MobilePro internal disk. 3. On the MobilePro, double click the FixBatt_HPC2K icon. 4. When the message "Low Backup Battery Issue" is displayed, tap the "Patch it" button 5. When prompted turn unit over and momentarily depress the Reset button using the stylus. Solution II. Change the default power management configuration. Configure your MobilePro 900 to suspend when the LCD lid is closed on battery power and AC power. To ensure that the device suspends whenever the lid is closed, please make the following changes and perform a soft reset: 1. Go to Control Panel. 2. Open MobilePro Settings. 3. Go to the LCD Suspend/Resume tab. 4. Place a check next to "Enable suspend while on External Power." 5. Click the "Advanced" button and place a check next to "Enable suspend while on External power. 6. Click OK to close the Advanced Setting window and click OK to close the MobilePro Settings. 7. Turn unit over and momentarily depress the Reset button using the stylus. NOTE: Both the software update and power management settings are cleared on a hard reset and must be re-applied.
Lenovo IdeaPad Y510 Notebook Logo
56 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
