Question about Craftsman Garden
Craftsman lawn mower running bad with Tecumseh carburetor, Need a diagram to clean or rebuild
  • 755 Answers
    New Friend:
  • 12 Answers
You should go to kiddie boutiques on ebay. They sell lawnmower gaskets and they have a diagram of the engine
Posted on Sep 27, 2014
Engine will start after priming but stops quickly (actually runs only very slowly and then stops).
Rheupel, Check that you have good fuel flow in gas line from tank. It sounds like a carburetor issue still, one of the ports are still plugged or float level is not set properly. Did you remove and clean emulsion tube in carb. If your carburetor is of diaphragm type, replace the diaphragm. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Small Engine Carburetor Rebuild Briggs Stratton FAQ
Commom Tecumseh Carburetor detailed rebuild from Toro Lawn mower lawnmower...
Lawn Mower That Starts then Stalls
LAWNMOWER REPAIR honda carburetor repair
May 19, 2016 | Garden
Has id leaking from my tecumseh carburetor not from the bowl or gasket bit through the throttle hole on the outer hosing side
Your float is stuck. Need to remove carburetor and rebuild. Not just clean it but rebuild it.
Aug 28, 2013 | Garden
8 hp tecumseh on coleman generator not running at a constant rpm (galloping)
The carburetor is hunting for the right balance because it is dirty. You will have to remove it to clean it thoroughly. That is the proper way to resolve it, but if you may want to try to add a carburetor fuel injector fuel additive to the tank and run it out. It may help to stabilize the hunting when the engine is under load. The only way to see is to try it, if you are not ready to tackle a carburetor. I have seen this trick work on my lawn mower engine. It greatly minimized the problem on my engine. Keep in mind the ultimate fix is the rebuild of the carburetor.
I hope this helps.
Aug 05, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I mixed up one spring and the mower idles low on craftsman eager-1 5.0 22 inch cut
I think that model may use the Tecumseh engine and carburetor application. Here is a diagram of what your machine (carb/choke and governor) should look like.
http://www.angelfire.com/mb2/visitme/mower/tecumseh.html
May 14, 2011 | Craftsman Garden
Toro recycler 20017 is very hard to start. it has to be primed many times. after it run a while it starts on one pull.
The carburetor may need to be serviced. You need to find a parts shop that handles Tecumseh parts. You will most likely need a rebuild kit for the carburetor. The carburetor part number is 640303. The rebuild kit is 632809. The Tecumseh engine company shut its' doors 3 years ago. Finding parts is becoming harder and harder. I've heard that someone has bought Tecumseh over the winter but it is unknown when the new parts will hit the market. Best of luck to you.
Apr 03, 2011 | Toro Power Lawn Mower
Engine starts but stops after a minute or on a hill or slope
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 15, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
Craftsman briggs and stratton 6.50 190cc lawn mower- wont start unless i pump the bulb. I have a new gas, new air filter, new oil, and new spark plug.any other suggestions?
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 25, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Tecumseh TC200-2026C carburetor
Rule of thumb for high speed is turn in til tight and back off 1.5 turns
May 29, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
1,134 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
