Question about Intel D101GGC Motherboard
Need help disableing onboard video, and installing PCIe video card.
Hi I need help disableing the onboard video, and installing a PCIe video card. I don't know what configuration to go to and I don't know what it's supposed to look like at the end.So far Video configuration looks like this:
Onboard video memory size [64mb]
PCI/VGA palette snoop [disabled]
Primary display adapter [PCI]...what can I do, someone please help, and by the way onboard video ati radeon X200.
I'm trying to install ati radeon X800.
I would appreciate all help. thanks.
    President:
  • 2,351 Answers
Hi rebelel1271, I do have the manual for you're Intel motherboard. You can have it as well. Click on the link below to download you're manual. document.write("D101GGC Product Documentation & Manuals") D101GGC Product Documentation & Manuals
Intel states you do not need to make any bios changes when you add a PCI-Express video card. See this on page 17, PCI and PCI Express Auto Configuration. Before installing you're PCI-E video card, open windows controll panel. Than open add/remove programs. Look for the driver software for you're onboard ATI Radeon X200. Uninstall that software. (If listed). Close all opened windows & shut down windows. Unplug the power cord from the PC. Open the case. Install you're new ATI Radeon X800 PCI-E video card. Double check all internal connections, (In case you may have bumped loose any cables). You're X800 may also have a 3-pin or 4-pin male power connector built on the card. If so, plug power to the X800.
Intel D101GGC driver page.
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21#DOC
ATI's web site for the latest driver's.
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
A little information. Once you're PCI-E has been installed. You're system memory will increase.
Good Luck!
If I can help you further, feel free to post here.
Mike
Posted on Jun 01, 2008
    Sergeant:
  • 226 Answers
Have you attempted using the information available on the Intel website to become better acquainted with your motherboard. The website has bios and driver updates plus manuals to help you locate components and jumpers, and configure your board depending on if you are using onboard video or a video adapter??
http://downloadcenter.intel.com/Filter_Results.aspx?strOSs=All&strTypes=All&ProductID=2229&lang=eng&OSFullName=All%20Operating%20Systems
  • Ravel Lively
    Ravel Lively Jun 01, 2008
    Excellent answer Map9966!!!!!!!!
Abit I-nv37
In most cases the mainboard chipset will detect the new card and automatically activate it....there is no need nor setting in CMOS to disable the onboard video.
Nov 11, 2013 | Computers & Internet
Hi I have a supermicro x8sti Server Board inside
Basically you have two choices for installation of video card:
1. To purchase small form factor PCIe card suitable for installation on 1U server chasis or
2. Purchase PCI express riser card and to install most full-sized PCI Express cards (Check this link for PCI Riser )
Oct 04, 2013 | SUPERMICRO COMPUTER Supermicro X8STi-F...
Hi ,i just wanted to know if the intel g41rq motherboard is compatible with the gts250 nvidia graphic card? since the system is kicking me out from most of the games such as call of duty etc...
Yes, it will work, just at the rated speed of the PCI-e 16x slot.
And as long as you have a power supply capable of using the card.
Capacity Per lane:
PCIe v1.x (your motherboard ): 250 MB/s
PCIe v2.x:(nvidia gts250 card): 500 MB/s
And keep in mind:
- the onboard graphic card will be disabled when installing a pcie card.
- the onboard cared uses a vga connector and gtx250 uses dvi
Dec 31, 2010 | Intel Computers & Internet
I am trying to install a pcie-x1 video card on a ibm eserver x206m i salvaged from work. I am running windows 7 64bit . I have tried to turn off on board graphics so that it takes the video card i just...
I know this is really old, but I had the same problem on my 206m 8584 with a pci-e x1 video card. I had to upgrade bios first, but nothing seemed to change, bios only showed onboard video as option and windows perfectly recognized the exta card. I went to windows video settings, it showed both video, onboard as main and active and extra as inactive, changed the second video to main and active and switched the plug to finally see my enhanced video. Only problem is that bios screen won't show up on pci-e card, so I start seeing something only after one minute :) Hopes this saves someone else some time.
Nov 03, 2010 | IBM eServer xSeries x206m
I got a problem with installing a pciex16 video card... i installed the card set the PCIE in the bios and nothing happens, when i unplug the video kaart the system starts up with the onboard even when i...
The system recognizes both. You can do either of these two:
1. Disable the internal video card via the BIOS. It will start using the add-on.
=== or ===
2. Right-click on your desktop and select [Properties] [Settings]
You will see two monitors #1 & #2.
Click [Identify] so that you know which is which.
Click on the monitor attached to the new video adapter and "checkmark" the box [Extend my Windows desktop onto this monitor]
At this point, don't select [Use this device as the primary monitor] until the above steps are successful in accessing the new monitor.
Hope this helps!
Sep 18, 2009 | ASUS P5VD2-VM SE/BULK Motherboard
Dell Optiplex GX620 not recognizing PCIe video cards
One of two things could be doing this:
1: Bad Video Cards
2: Bad PCIe slot(s)
If avaliable, I would test the video cards on a PC with a PCIe slot to verirfy if the cards are good/bad. If they work, your PCIe slot is bad and need to have the motherboard replace to correct.
Good Luck
C2Solutions
Aug 27, 2009 | Dell OptiPlex GX260 PC Desktop
How to disable onboard (Nivida 6100) video on a Acer Aspire E380 so I can install a EVGA 8800GTS and 650w PS.
Shane,
First Connect your Monitor cable to the onboard connector.
Then boot your PC
After the Acer logo disappears press <Delete> on your keyboard to enter BIOS
From there you should be able to find the option to change the default Videocard to PCIE
press <F10> to save and exit
Shutdown PC
Switch Cable to Nvidia 8800GT and reboot
You should now be able to finish installing your new Vid Card
Hope this helps
Dave
Nov 07, 2008 | Acer Computers & Internet
Video Card Chnage
Hi Rick, you need to disable the onboard video from within you're bios. Please go to page 28 in you're manual. This will show you how to enter the bios menu. Once there go to page 26, where you will find. Onboard GPU (Enable If No Ext GPU) set this to Disable. Save & exit you're bios. You're system will auto restart. Once windows has finished loading, install the driver software for you're PCIE card. Suggest you check for updated driver software for you're PCIE video card.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 24, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
My pc doesn't boot up
Did you have onboard video before? What is the video card? AGP8x, AGP4x, PCIe? If you had onboard video, you'll need to change the settings in the BIOS and disable the onboard video. You'll have to plug in at the onboard to access the BIOS.
Jul 23, 2007 | EliteGroup P4VMM2 Motherboard
Intel D101GGC Motherboard Logo
382 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
