Question about Samsung Cell Phones
L760 mobile phone, mp3 ringtone starts quiet for about 2 seconds before starting at normal volume, i have the phone set to melody and not ascending, can i fix this. thanks, Paul.
  • 94 Answers
Basically its softwear is desine like this their is no problem with ur phone.
Posted on Jun 02, 2008
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
Tip
CUSTOMIZING YOUR PHONE SOUNDS
the samsung sync is a pretty good phone with many options of customization available. problem is, most are hidden. heres how to access them:
1. open phone, and push the side key under the memory card slot. [alternatively, just get to the PROFILE option. in that case, skip 2]
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options.
i will map them out for you too lazy to look through everything:
1.    INCOMING CALL
Call Alert Type:
                [Melody]
                [Increasing Melody]
                [Vibration]
                [Vibration Then Melody]
                [Vibration & Melody]
                [Vibration And Increasing Melody]
                [Mute]
Voice Call Ringtone
                [Takes you to My Stuff, where you can choose a .mmf file to use.]
Ringtone Volume
                [1-7]
Auto Reply
                [Activation OFF/ON]
                [IF ON, THEN REPLY TO SEND]
2.   New Messages
Message Alert Type
                [Melody]
                [Vibtarion]
                [Mute]
Message Alert Tone
                [OPTIONS:
                   [1. USE EFFECT TONE]
                   [2. USE MY ALERT TONE]
                [Once]
                [Periodic]
Alert Tone Volume
                [1-7]
3. PHONE SOUNDS
Keypad Tone
                [Beep]
                [Clean]
                [Mute]
Power On Type
                [Melody]
                [Vibration]
                [Mute]
Power Off Type
                [Melody]
                [Vibration]
                [Mute]
Folder Open/Close Tone
                [Melody 1]
                [Melody 2]
                [Melody 3]
                [Mute]
Volume, Phone Sounds
                [1-7]
if i missed anything, leave me a message, or email me:  mannyftw [AT] aim [DOT] com
on Oct 27, 2007 | Samsung SYNC SGH-A707 Cellular Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Delay in my mobile ringing time.
go to profile settings,,,
select ringing tipe: ringing,,,, not ascending,,,,
hope it will work,,,,,,,,
Jan 14, 2010 | Nokia N73 Cellular Phone
Ringtones fading in by default
You can try going to Sound profiles and choose a profile: "normal" or "outdoor" etc. and make sure that the Call alert type says "Melody" instead of "increasing melody". I have noticed that mine increases the melody for the first 2 seconds even with "melody" setting.
If that does not work, maybe try editing your tones so that the volume is twice as loud at the beginning of the tone. Good Luck!
May 14, 2009 | Samsung SGH-U600
Ringer too quiet
I do apologize for your issue with the quiet ringer. Especially if you have some important calls you are waiting for. Somethings to keep in mind. Everyday, you want to make sure you power down your cellular phone completely for about 10-20 seconds. That way it's refreshed.
Second, check your profile on the phone is on silent,meeting,outdoors,normal,etc? When you highlight either of them you can customize it. Make the volume higher. Also, for testing purposes set only factory made ringtones, which are already on your phone. Test them all out, and see which ones are sufficient. A lot of times if you download ringtones or use MP3's as ringtones, they are not loud enough.
I know this will assist you with your phone and ringers!
Cheers!
Feb 04, 2009 | LG Cell Phones
Ringtone volume problem
do you have it on vibrate along with the ringtone? sometimes they place the vibrate under the speaker so you can barely hear the ringtone if it's on vibrate..
Jun 28, 2008 | Samsung SGH-D600 Cellular Phone
Changing Samsung SGH-L760 Sms Tone
You can change them by going to Profiles (Silence, Normal, Car,...) then edit the one you use as default and you'll see a sms tab. There you can change your tone but you won't be able to use mp3.
Mar 20, 2008 | Cell Phones
LG TU55O vIDEO TELEPHONY
there are some settings in your handset
-menu-profiles-select the current profile-than personalise-than click on tune set up, than u can select your mp3, you can select your tune mode/volume
Oct 13, 2007 | LG CU500 Cellular Phone
Cell Phones Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
