Question about Dehumidifiers
Out of the ground pool-hayward sand filter
I entered "dehumidifiers" because i could not find what i was looking for.
can you still help me?
i have a filter by hayward "powerline" these two numbers appear
sw070 lbl
sw0144 xe2
top mount type
then ip55 also is written,
i have tried for hours and hours and cannot find anything to make me understand how to clean the sand, backwash etc before putting up the pool again this year. i do want to get it wright this year!!
thanks maria
Question-- when filling your pool do you fill above the opening for the sand filter?
Posted on Dec 16, 2008
This one is easy...
You simply fill your pool to the normal level which is at the top of the skimmer.
Now apply the "Shock" treatment to begin clearing the water.
With the pool full, attach the hose for back flushing to the filter 'Outlet" or discharge side and then move the selector handle to the "backwash" position and turn the pump on. It will begin discharging water out of the hose. Run it this way until it begins sucking air.
You have now "backwashed" your filter.
Fill the pool back to the normal level and finish treating water to get the Ph and Chlorine right.
Enjoy swimming.
Posted on Jun 05, 2008
How do you unclog the dehumifier?
Hey friend, thank you for the post!
I understand that your dehumidifier continuously is set at 50-60 and the clean filter light has not stopped. I would like to ask you some additional questions in order to provide you better assistance. First, does the appliance still collect water? Secondly, have you tried to reset the appliance? I look forward to your comment back so that I can further help you. -Matt
Jul 29, 2014 | Frigidaire FDL50R1 Dehumidifier
Shows change filter where is it located?
Hello Ann, this is JK. I understand that you are looking for the location of the filter in a dehumidifier. Generally, you will need to remove the bucket to be able to reach under to remove the filter. Please refer to your owner's manual for more detailed care and cleaning instructions. Hope this helps!
Apr 07, 2014 | Frigidaire Dehumidifiers
Where is the filter on this dehumidifier. Mod# ad75ust
To locate the filter: Shut unit off. Remove "bucket". You should find a "tab" at top of where bucket goes in middle front of unit. Pull down to remove tab of Filter. Clean thoroughly and dry Filter before re installation. Visually inspect the coils and condenser while filter is out ( a flashlight helps). If it looks slightly dusty or like covered in felt, then it would be wise to remove front and rear covers and give the coils and condenser a thorough cleaning.
Sep 26, 2013 | Whirlpool 75-Pint Dehumidifier
My dehumidifier does not seem to be working properly. I can't find the manual to tell me what the settings should be. Would appreciate your help. It is a DeLonghi DE400P. Thanks Shirley
What is the specific problem? Is no water being collected by the dehumidifier or do you have another issue?
Make sure that the dehumidifier is in a room in the operating temperature range (at or above 44 degrees F). Make sure that the room door and windows are closed and that the room is not larger than 2200 square feet. Make sure that the collection bucket not full and is properly seated in the dehumidifier. Check and clean the air filter on the dehumidifier. (Vacuum the filter or rinse under running water three times. Then wait until dry to replace it in the dehumidifier.) Look at the coils of the dehumidifier. If you have ice on the coils, defrost the unit (turn off, unplug and wait for it to melt). If the ice reforms quickly, you may have a leak in the coolant system. Then the unit needs repair.
Next make sure that you have good air flow around the dehumidifier and that the desired humidity set point is lower than the humidity of the room.
Retrevo has the manual available: http://www.retrevo.com/support/Delonghi-DE400P-Heating-Cooling-and-Air-manual/id/19269bh037/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Aug 09, 2011 | DeLonghi Dehumidifiers
Where is air intake filter? unit is icing up Thanks so much
The air intake filter is one of 2 places. In either case, it's behind the front louvers
1. Remove the water collection bucket from it's holder. Look up into the bucket holder, just behind
the front louvers. You should see what looks like a plastic frame. It may have a pull tab handle. In
any event, the is the filter frame. Pull it straight down and out. It can be cleaned with a vacuum or
if it's really dirty, wash it in warm water and dish washing liquid, rinse and allow to completely dry
before reinstalling it. NEVER operate the unit without the filter in place. Doing so, could damage
the unit.
2, Look on the right hand side of the unit's cabinet, just behind the louvers. If you see what appears
to be a op open door, the filter is behind that door. Follow the above directions for cleaning the
filter.
I hope this helps you. Please let be know.
Jul 15, 2011 | Whirlpool Dehumidifier Dehumidifier
How do I get to the air filter in order to clean it ??
To remove the filter. remove the water bucket. Then looh at the top of the water bucket cavity. You will see a small plastic pull type handle. This is the plastic frame for the air intake filter. Pull it down to remove frame and the filter. After washing an rinsing the filter, be sire it's completely dry, before installing it. Be sure you have turned the unit OFF and unplugged it before removing the filter.
http://www.lg.com/us/appliances/dehumidifiers/LG-LHD45EL.jsp
To help you in the future, I have included a link to your Owners Manual. You can download and print it for future reference. Once the link opens look to the right on the page for Dehumidifiers Manual English and click on the link.
Hope this helped you. Please let me know. Thanks.
Jun 16, 2011 | LG LHD45EL Dehumidifier
Every time I plug my dehumidifier in to the ground fault plug the ground fault goes to failsafe. I tried another circuit and the dehumidifier didn"twork. I tested the outlets with aplug tester and they are...
You will find that the compressor is bad and will not start...this kicks out the receptacle.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jul 17, 2010 | Maytag M3DH30B2A Dehumidifier
I have an indoor pool with a DCA2000-OC dehumidifier. For the last few weeks, the windows have been fogging up and there is a tremendous amount of condensation on the ceiling. It is damaging the paint and...
Pool dehumidifiers are similar to an air conditioning unit, but often have a few different bells and whistles that make them a different animal to work on...they are far beyond the scope of even the above average DIY Joe....
You need to call a QUALIFIED service technician that has experience with pool dehumidifers...
heatman101
May 06, 2010 | Dehumidifiers
It runs all the time.. does it have a filter I have to replace or clean and if so where is it?
Can help with the filter location, remove the front water catch basin and look up under front of unit it should have a filter that pulls down from front.
Oct 27, 2009 | Goldstar DH304 Dehumidifier
Dehumidifiers Logo
325 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
