Question about Kyocera KM-1505 Copier
Kyokcers km 16 20 error code c 6 400 - Kyocera KM-1505 Copier
  • 165 Answers
C6400 Zero-cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
Defective PWB. Replace the engine PWB or power source
PWB and check for correct operation.
taken from different kyocera copier but it will be the same sounds terminal
check fuser if looks ok main board if that the case may as well get a new copier
Posted on Nov 13, 2010
What happen when kyocera KM-1505 is bringing error code J98
There's probably a time piece of paper or something blocking a sensor or pressing down on an actuator or something
try checking this then do a good clean of the unit.
Jan 16, 2015 | Kyocera Mita Km 1810 1510 1505 Copier Drum...
Kyocera error c7200
km 6030 machine have a code on screen c7200 so how i solve it
Dec 18, 2013 | Kyocera Km-6030 With Feed, Finisher, Bank,...
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Jan 27, 2011 | Kyocera Copystar CS-5035 Copier
How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Error Code C2500 on a Kyocera KM-2530
a C2500 error code relates to the paper feed area.
It indicates either a faulty paper feed motor, loose plug for the motor or lubrication problem in the feed area.
Hope this helps.
Apr 24, 2009 | Kyocera Office Equipment & Supplies
Getting an error code of C6030
KM-5050 error code displaying C 6030 how can i remove this code WebRepOverall ratingThis site has no rating(not enough votes)
Apr 16, 2009 | Office Equipment & Supplies
05 caravan engine oil is going down have to add between oil changes . i don't see any leaks and it doesn't seem to be burning any either is there a reason for concern . if yes is there anything i can do to...
that is not excessive oil consumption, 10,000 KM is about 6,400 miles, 1.5 Liters is about 1.1 quarts, this is excellent, my brand new Dodge Magnum uses more oil than this.
Apr 02, 2009 | 2005 Dodge Grand Caravan
Error code C0F37 on Kyocera mita KM-C1530
This code is not documented, the firmware must be reloaded and a service tech can only do it ...
Feb 18, 2009 | Kyocera KM-1510 Copier
ERROR CODE C630 ON KYOCERA KM-1510
this is a fuser error meaning that the fuser has overheated. In most cases the thermal fuse or thermostat blows and will need replacing. especially if you get the 630 code, and switch the machine of and back on and get a 610 code.
Oct 13, 2008 | Kyocera KM-1510 Copier
Error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Mar 02, 2008 | Kyocera KM-1505 Copier
Kyocera KM-1505 Copier Logo
171 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
