Question about Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum
Roller wheel is not turning and vacuum is difficult to push. Checked roller and have removed all visible hair.
  • 377 Answers
Add some WD40 to the axle of the roller wheel and work it in good. Keep at the wheel until it moves freely. Paul
Posted on Oct 12, 2010
  • pwillitz Oct 13, 2010
    Sorry my efforts did not solve your problem.
    Paul
Problem with Electrolux Vacuum Cleaner, MDL EL8501A. Brush Roller will not turn
try pushing the reset button..its a little red usually located on the right side of the nozzle cover..
May 27, 2014 | Electrolux Versatility Bagless Upright...
Brush bar is not spinning
Common causes of brush roller failure are belt breakage and clogging. If this is a Dyson animal vacuum, you may find the brush roller is so clogged with hair that it cannot rotate. The solution is to remove the brush roller and clean it thoroughly, particularly inside the end caps where hair accumulates. It is unlikely that an entire animal was ingested.
Nov 20, 2013 | Dyson DC28 Animal Vacuum
Red indicator light is red for roller
Sounds like your roller is jammed up with bits of thread and hair... get in there and really look at those ends... pull/cut but remove the bits of hair that's jamming it up.
Dec 29, 2012 | Vacuums
Brush roll won't turn on for the shark NV22L vacuum. the light on the brush roll is dark, not red or green
Atthe bottom of the vacuuam are screws to take off...two of them are near the rear wheel assembly....two of them are behind the front mini wheels (just pry the front mini wheels so that they pop out...they pop back in)
Remove all of the screws. Remove the bottom from the top..they come apart in two pieces. Ceck the belt on the bottom piece. Slide the roller out starting from the end opposite from the motor end. With the roller off, slacken the the belt so that it misses the gear on the motor (you will have to hold it with your hand). Plug in the vacuum. Turn the power on to the roller on position. The motor should work and the green light should be on. If the motor doesn't work, then it is defective. If it does work, turn off, unplug and shoot the gear and the two ends of the roller with WD-40. reassemble. good luck.
Feb 10, 2011 | Shark Helmet NV22L Shark Navigator Upright...
Hair getting stuck in the belt drive area causing beater to skip
Hair,string, tinsel, etc. have always been problems for rollers and belts. You will have to remove the hair. It can often get stuck at the ends of the rollers also and keep the roller from turning. I usually remove the roller and clean it using a screwdriver, knife, etc. to remove the hair. the cleaning can be done while the roller is still on the unit by turning the unit over although this may not offer as much free access to the roller. Of course, removing the roller means removing the belt and if you are not up to this (I don't know how handy you are), I would try to remove the hair with the roller on. If you do this, be careful not to put any nicks in the belt. Good luck!
Mar 13, 2010 | Dyson Vacuums
How do you install the belt on the kirby vacuum?
Step 1:
UNPLUG YOUR KIRBY VACUUM CLEANER. Before you go any further, take your time with this belt change. It's not that difficult, just a little different than most other vacuums. These belts are very easy to find on the internet. kirby-oldstyle1.jpg Step 2:
You should be facing the front of your Kirby vacuum. The height adjustment lever will be on your right. Push the lever all the way down. Lift the light hood with your left hand. Turn theKirby vacuum belt lifter counter-clockwise with your right hand. Unlock the accessory lock. The accessory lock is located under the light hood. Move the lock to the left to disengage it. Remove the front of the vacuum cleaner.
kirby-oldstyle2.jpg kirby-oldstyle2a.jpg Step 3:
Turn the vacuum belt lifter all the way clockwise until the belt drops down. Unlock the roller plate by releasing the two latches on the rear. Pull the roller plate up slightly and then off. kirby-oldstyle3.jpg kirby-oldstyle3a.jpg
Step 4:
Bend one end of the roller bracket just enough to remove the roller. Remove this end of the roller. If you need to replace the roller take it all the way out. Remove any carpet fiber, string, or hair from the roller with a scissor.
kirby-oldstyle4.jpg kirby-oldstyle4a.jpg Step 5:
After you have removed the old belt, slide the new one back on the middle of the roller. If you're Kirby vacuum cleaner has a belt indicator light, the roller will have a magnet built onto one end of it. It's very important to install to install a roller with a magnet on the same side as the indicator light. The roller actually will only fit into the roller plate one way.
kirby-oldstyle4.jpg Step 6:
Place the roller back in the roller bracket. Place the roller bracket back and lock it into place with the 2 latches. Rotate the vacuum cleaner belt lifter counter-clockwise. You should feel the the belt catch. Look inside to make sure the belt is being stretched onto the vacuum belt lifter. Reassemble the machine. After you have reassembled your Kirby, turn the belt lifter cockwise, releasing the vacuum belt onto the vacuum motor shaft. kirby-oldstyle2.jpg
Nov 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Self propel not working, burning smell
Flip the vacuum cleaner over and check the roller brush. Is it full of string and hair? If so, unscrew the four phillips-head screws holding the plate on that covers the roller brush; pull out the brush, and cut off/clean off all the hair and string. Replace everything and try running the vacuum. Alternate solution: perhaps the belt that makes the brush go around is broken. If so, follow the above steps to remove the roller brush, then replace the belt.
Oct 11, 2008 | Hoover Ultra U6430-900 WindTunnel Bagged...
The rollers at the bottom of the sweeper have things stuck around them
You need to start with a pair of scissors and patience. Sit on the floor with the vacuum roller visible and accessible. Snip a string and pull it off. If the roller stops, cut string at that point. Try again. this is time consuming, but necessary. We borrowed a vacuum from a family that had four girls with long blond hair. We had to de-hair the roller before it would work sufficiently on our carpet. Once the hair was off, it worked GREAT! It was so wonderful that we went out and bought a Dyson of our own; now we don't have to remove long blonde hair from the roller to get it to work.
Sep 07, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Roller problem
I have 3 Prontos, one in each part of the house. Two of mine had the rollers stop. I figured out the problem and it fixed both. Take the roller out by turning the plastic screw and popping the plate off. Pull all debris off the wheel that turns. Turn unit on and make sure this wheel is turning freely. Take the brush and look on the end with the square part. Take some pliers and gently pull this square piece off. I had to wiggle it a little, but it pops right off. Clean all debis (mine had several small dust balls and 1 long hair) in the square part and down in where the square part goes. Push the square part back on and put brush back in unit. This fixed both of mine. Hope it helps.
Dec 18, 2007 | Electrolux EL1000A2 Pronto Bagless Stick...
Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum Logo
191 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
