Question about Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer
"Unable to print 50" error-won't print or turn off. Already disassembled and re-assembled-still won't print
  • Brother Master
  • 13,433 Answers
It seems like the printer has a mechanical problem, the cartridge carrier is unable to move or something is stuck inside the printer preventing it from functioning properly.
If you open the scanner cover and can not see a obvious problem, not even after looking it over with a flash light carefully, then it might be a jammed peice of paper somewhere along the paper path that we can't see at this time.
Go over these instructions I've posted earlier
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Or you could also try feeding the paper throught the machine yourself, but it might make the problem worse if done with too much force.
Posted on Oct 12, 2010
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
Brother 540cn Printer won't print and displays unable to print 50. The photo capture button also flashes
The error code 50 indicates a paper jam condition. Whether there's actually still paper jammed or not, it's sensors are still indicating a jam. Check again for a bit of paper, or there may be a faulty sensor.
Check out this link: Brother for further information.
Feb 10, 2013 | Office Equipment & Supplies
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
Print unable 50
That error means the purge assembly is stuck, you need to pull the carriage out of the right corner and look inside with a flashlight. Usually a paper wad in there, if not you need a new purge assembly.
Oct 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Unable to print 50
The MFC has a mechanical problem, or a foreign object, such as a clip or ripped paper, is in the MFC.
Turn off the MFC's power switch, and then on again. If the error message continues, leave the MFC for several minutes and try it again.
Apr 12, 2008 | Brother DCP 7010 Multifunction Laser...
Error message print unable 50
the encoder strip which gives the printhead the position is out of place (error 50). You have to open the printer and reinsert the strip:
http://www.fixya.com/support/t211210-brother_mfc845cw
Stick a 1.5 inch tape onto the printhead cover where the strip runs thru. This will prevent this accident in future!
Nov 05, 2007 | Brother IntelliFax-2480C Fax
Brother MultiFunction Center MFC-440CN All-In-One InkJet Printer Logo
106 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
