Question about Health-O-Meter Health O Meter HDM520KD 18 Weight Tracking Scale
I get an "E" every time i step on scale - Health-O-Meter Health O Meter HDM520KD 18 Weight Tracking Scale
Stepping on the scale before the "000.0" causes this error message to appear. If "E" appears, step off the scale and repeat initial RESTART by tapping on the center of the scale. Wait for the scale to indicate 00.0 or something like that THEN step on.
Posted on Dec 13, 2010
  • robertoxx2 Dec 27, 2010
    I am having the same problem. I wait until the 0.0 then step on it barefoot and get E. It works for my husband. What's going on?
Dashes
I have a Health-o-meter but not the same model. Mine still has the instructions pasted (loosely) to the bottom.
The secret is that you must initially press the lower (left or right side) corer for just a second or two. That causes a few dashes and then the scale reads 00.0. Then get on the scale and get your reading.
Alternative behavior:
If you initially press the corner for more than a few seconds it will cycle through User Numbers one through four. If you use that feature it remembers your weight from the last time so you can see the difference.
Apr 15, 2014 | Health-O-Meter Health o meter 844KL...
The scale displays 8888 every time you stand on it. If you go to choose p1 it flashes data. Can seem to get the scale to reset using the instructions and removing batteries does nothing
I have a "Thinner" scale. You have to put a little weight on it to activate, it will show 8888. Don't step on, wait a few seconds and it will change to 0000, then step on.
Jan 05, 2011 | Conair WW81 Weight Watchers Body...
Scale shows "Lo"
just fixed this problem myself. so first i took out the battery then put it back in didn't wait a specific amount of time or anything. i just popped it out blew the inside then put the battery back in. next i switched it to ST from LB stepped on it stepped off it then stepped on it again and it reset. then i put it back to LB and voila it worked again!
Dec 18, 2010 | Taylor 7506 Glass Lithium Digital Bathroom...
This is a new scale. Every time you get on it a new reading?
See if this helps.
Step on gently and stand very still. Step off and press/tap with your foot the center of the scale to reset to 0.0 and step up again and be very still while it reads your weight.
Mine gave a little different weight but after I tried again I had two readings the same and the readings were what I expected. So if in doubt I read twice. If I am very still when I step up mine give same reading.
I hope there is nothing wrong with your new scales.
Happy weighing.
Aug 15, 2010 | Conair Large Digital Display Memory...
I just purchased a Healthometer Weight & Body Fat Monitoring Scale. I successfully setting up my scale, I think? When I turn the scale on and weight for the 0.0 to appear, I get on the scale and it...
These scales use sensors to measure the electrical resistance of the human body to calculate body fat. If you are not stepping on the scale barefoot then that might be the reason why it is timing out. These scales require you to step on it barefoot so it can take a measurement through your feet. And using the height and gender information in combonation with the resistance measurement it can calculate your approximate body fat precentage. If you are stepping on the scale barefoot then make sure that your feet are properly placed into the sensors and avoid any movement. Let me know if you have any questions.
Feb 06, 2010 | Health & Beauty
Nothing will display on the read out
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
My scale keeps giving me an err2 message. How do
1. Take out the battery
2. Put scale on hard surface
3. Stand on scale for five seconds
4. Put battery back in
5. Tap your foot on scale to make 00000 appear
6. When the 00000 disappear tap your foot on scale again and then stand on scale till your weight appears
If this does not work the first time (it has always worked the first time with my scale) the repeat the steps a second time. If the second time does not work call the company because something else is wrong.
Dec 16, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Fluctuating weight on Digital Scale from one minute to the next..
i believe that, like most electronic scales, the first time you get on the scale you must step off to allow it to zero itself. Then step back on to get your correct weight.
Jul 28, 2009 | Conair Thinner Scale by TH304 Glass Body...
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Health-O-Meter Health O Meter HDM520KD 18 Weight Tracking Scale Logo
1,831 people viewed this question
Top Health-O-Meter Health & Beauty Experts
creative_lac
Level 1 Expert
His Example
Level 1 Expert
TheHCGInstitute
TheHCGInstitute
Are you a Health-O-Meter Health and Beauty Expert? Answer questions, earn points and help others
