Question about Kyocera Office Equipment & Supplies
Error person e4 printer kyocera fs -6700 - Kyocera Office Equipment & Supplies
Benimur
  • 6966 Answers
SOURCE: Looking for Kyocera Mita Ecosy FS-1010 Instruction Manual
A downloadable copy of the Kyocera Mita FS-1010 user manual is available here.
Good luck and kind regards.
Thank you for using FIXYA.
Posted on Feb 12, 2008
SOURCE: CLEANING A KYOCERA FS-2000D
Follow the page http://www.fixya.com/support/t1336338-kyocera_fs2000_thin_black_vertical_line
Basically, you remove the cartridge and developer all at once, then remove the waste toner bottle, then push the grey tab in to release the drum cartridge (be very, very careful in removing and putting back in. Any scratches on the drum and you will enjoy black spots permanently on printouts).
On the right side of the grey charger section is a tab you can use to release it. Do this, then put the drum away in a light tight back to prevent damage to it.
The reason why this Kyocera printer doesn't have the primary charger wire cleaner is because it did away with it. It now charges via a black fuzzy looking roller on top which is like the secondary corona charger wire, which then applies it to a roller, which then applies it to the drum. I think this is nice since it should prevent printer quality problems better since there is nowhere for oxidation to really collect. But, OTOH, it does happen anyhow.
I cleaned mine off and the streaks disappeared. I used a non amonia based cleaner to help, since I didn't find any dust on it to begin with. Whatever you choose, do not get your fingers on it, or it will put oil onto the rollers and that will make it worse.
Worked for me.
Posted on May 25, 2009
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
  • 46 Answers
SOURCE: showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
  • 3 Answers
SOURCE: Can you help me with kyocera fs-1030d
If a paper jam occurs while printing, the printer notifies it by the following combination of the four indicators. Remove the
jammed paper . After removal, open and close the top cover once to initialize the jam sensing
Posted on Sep 18, 2009
Kyocera 1020 error codes list
Hi Pandirayaj,
I have this manual for you to see errors in Kyocera FS-1020D. Hope it helps.
Kyocera FS FS 1020D Operation Manual Page 37 Error Messages
Apr 25, 2014 | Kyocera Mita FS-1020D Laser Printer
Kyocera FS-1500 printer shows E4:171911 fault?
do you have manual, try to see troubleshooting section there it might be described.
Apr 26, 2008 | Office Equipment & Supplies
ERROR CODE F186 FOR KYOCERA FS-C5100DN
Guten Tag,
Kyocera FS-C5100 error code 186
was sagt der fehler aus
Aug 06, 2013 | Kyocera FS-C5100DN Color Laser Printer 23...
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
0017745 problem
E4 error belongs to fuser unit ...........
please check ........
1. blown-out thermistor (check it first and repalce it )
2. blown-out heater lamp
3. difective harness between fuser unit and power supply unit
4. defective power supply unit
17745 is your printer page count
Nov 11, 2009 | Kyocera Mita FS 1750 Laser Printer
Getting a E2 error on Kyocera FS-1700+. Any ideas?
this service code belongs to Laser scanner unit (Polygon motor) error
check the connection between scanner unit and engine board .....
Oct 06, 2009 | Office Equipment & Supplies
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
Showing 'error occured call service person c6400'
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
