Question about Fein 9-55-13 Turbo II Bagged Canister Vacuum
I need the orange top cover for my 9.55.13 because mine is cracked. Where can I buy one?
  • 377 Answers
You will probably be able to find it at: http://www.ereplacementparts.com/fein-parts-c-15741.html?osCsid=2cldhjbhfcq03503il7el658t4
Paul
Posted on Oct 12, 2010
  • pwillitz Oct 13, 2010
    Sorry my efforts did not solve your problem.
    Paul
Stuck closed, how to open?
press release on top cover , I had someone use mine 1ce and they pressed "seal" with no bag in machine it did exactly that it stuck closed, tight too !! one touch of release button on top cover and it popped open
Jan 15, 2016 | FoodSaver V3250 Vacuum Sealer Kit
Why does the remote say "Open me" ?
Because the remote is asking you to open the top cover. If you look at the side of the remote you will see an indention for your finger to pull up and flip the top cover open. The screen will turn orange and you will be able to set the time and schedule as needed.
Sep 12, 2011 | iRobot Roomba Scheduler 4230 Bagless...
The scubbers do not spin
Just fixed mine which had same problem. A little clear piece of plastic inside the middle of the handle had cracked. This piece holds the switch in place and is probably made to fail. Make sure you unplug the machine before opening it. If you take off the carrying handle you can get the top half of the machine to come off. Set it aside. Now look into the top of the bottom half and see if your switch housing cracked like mine did. It cracked where it screws down so there was nothing to hold it anymore. (The black switch unplugs, BTW.) If you are creative, this can be fixed by drilling two small holes to affix the switch to the clear part again. We also made a metal plate to hold down our clear piece. Happy fixing! :)
Jun 15, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Motor burned out need a replacement motor. Where can I buy one?
USAVACUUM.COM has all the hoover parts available for the H3000. The part number is 59177074. Follow the link below to your model number.
http://www.usavacuum.com/category-s/85.htm. .
Thanks. Please leave positive feedback.
Mar 13, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
I have a Vacu Queen V3000 and it stopped working in the middle of a job. I verified that I have power at the outlet that it plugs into and then checked motor resistance from the plug and I got about 600...
As a quick test Plug in the vac again and turn on the switch, then try your power head. If the head works you have a motor problem, if the head doesn't you likely have a cord problem.
You seem to be saying it failed while running??? which generally indicates your switch is the suspect.
Check the motor for a worn or sticking carbon brush.
Motor is access by removing the chrome lid and 3 screws under the handle., then removing the paper cone and unscrewing the center screw a t he bottom of the plastic.cone cage...
Dec 12, 2009 | Filter Queen Majestic Canister Vacuum
I fill the hot water tank and it and it pours out of the tank onto the floor less than a year old used to work fine
don-I too have the same issue. I tore mine apart today and still don't know what the issue is...I have a Hoover Dual V...I'll let you know once I find the solution. Like you, mine machine is just at a year old.
Nov 15, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Don´t know how to take my Rainbow apart.
Your model is a bit newer than mine, but on mine, I have to peel off the foam rubber gasket that seals the canister to the top of the vac when you put it together. You will have to replace this gasket once you peel it off. Under the gasket are the screws that hold the top cover on.
Hopefully your model is similar to mine, and this is the answer you need!
Nov 06, 2009 | Rainbow E series Canister Wet/Dry Vacuum
The belt p/n 0100623 broke - need instructions on how to replace it - we have Bissell ProHeat Powersteamer
I just replaced mine last night. 1) take off the top belt cover. 2) take the water and cleaning solution tanks out then lay the unit on the side so the bottom of the cleaner is facing you (water and solution may leak out so you might want to do this on an old towel). 3) On the same side of the machine as the belt cover but on the bottom you'll see an orange piece (at least it is on mine) that is held in with one philips screw. Take the screw out then slide the orange plastic piece out (might need a pliers to help). 4) there is a black cover over the brush belt that has a tab on it. Pull on the tab and the brush roller on that side will come out of its place. 5) You'll see a cogged belt that drives the brushes. Just slip that off the drive on the machine. You don't need to take it out completely - just off the drive. 6) Slip the new belt (p/n 0100623) in and on to drive. It goes "inside" of where the cogged belt goes. 7) Slip the cogged brush belt back on. 8) push the brush roller and black belt cover back into position. 9) slide the orange plastic piece in place (make sure the belt cover is held in place by it) and screw it back on. 10) flip the cleaner so it is on its wheels again. 11) pull the new belt over the metal drive and manually get it kind of centered. Make sure it isn't touching any protruding plastic. 12) plug in the cleaner and quickly turn it on and off while looking at the new belt. You should see it self center. 13) put the top belt cover back on 14) insert water and cleaner tanks. 15) get to work.
It'll take less than 10 minutes to make this fix (less than 5 probably).
Jun 19, 2008 | Bissell Vacuums
Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vax 4100, how to disassemble for repair
To disassemble a canister vax you first remove 2 screws holding the handle cover. One is just above where the power flex enters the handle, the other is at the mid-point of the top, hidden under the label. Both are small crosshead screws. Before doing attempting this, you need to be competent with working on mains electric wiring, as some of this has to be removed to do all this.
Once the handle covers are removed, the next bit is to gently lever off the speed control knob - it's a tight friction fit, then undo the nut holding it to the handle cover panel. After this undo the mains power connections from the multi-block joiner they go into then remove the 2 screws securing the mains wire. Then undo 2 bolts at each end of the handle going downwards into the main body. At this point the handle can be removed as well as the top body plate. You have to fiddle the electrics and switches through the hole in the top body plate to remove it. Now 3 bolts and a small crosshead screw is all that holds the upper motor section to the lower. Remove these and you can separate the 2 halves which gives you acess to the water pump. This is held in by screws founf underneath the plastic ring at the base of the motor body (around where the small reound blue sponge filter goes). This ring is held in by plastic springy clips. Gently lever round it to get it come off.
That's it. Re-assemble is reverse of all this. Don't disconnect the electrics without drawing pictures or photographing to work out which wire goes to where.
Mar 12, 2008 | Vacuums
Fein 9-55-13 Turbo II Bagged Canister Vacuum Logo
204 people viewed this question
Top Fein Vacuums Experts
Bill Boyd
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Fein Vacuum Expert? Answer questions, earn points and help others
