Question about Allen And Heath Xone 92 4-Channel DJ Mixer System
No power to xone 92 replaced the fuse still nothing apparently recent spillage on unit.
CHANNEL MONTIOR LIGHT WILL NOT STOP FLASHING
You've pressed the "solo" button by accident.
Jun 01, 2014 | Allen & Heath Xone:92 DJ Mixer
What is compatible mixer for technics sl-dq33
Take one with a balaced output and well if you want a nice sound then the allen & heath xone 23 http://www.allen-heath.com/ahproducts/xone-23/ is real nice and well build and they have also the c version with build in sound card, but that unit is a lot more expensive . But when it comes to soundquality, this the one. Numark makes perfect tables, especially the x serie , i have a x-5 for scratching but my denon has the best parts for it\'s price , with real good capacitors, only your choice will be the xone. and costs 300 euro, three times more expensive then the numark. and with build in soundcard 200 euro extra. For less you don\'t buy a lot and don\'t take the reloops, those are very old and upgraded four times. Greetings richard
Dec 29, 2013 | Technics Audio Players & Recorders
Allen & heath xone 42 fader problem channel 1
Carbon track on fader 1 is open because of wear or just broken, if you are getting sound then the ground carbon track is out but certainly the problem lies in the pot.
Nov 04, 2013 | Allen & Heath Xone:42 DJ Mixer
Midi problem
i think this problem is related with the power of the mixer, see the guide of that mixer and learn how to connect it on right way.
good luck
Feb 17, 2013 | Computers & Internet
I have an allen and heath Xone 22 Mixer. Its great, except due to the lack of a power switch I pulled the ac adapter/power cord out too many times and now it has a really bad, loose connection. It works,...
Usually the connector that is board mounted is the problem. I would OPEN the unit as there may just be broken solder at the connector inside. If the connector requires replacement, find one at Digikey.com by searching for "power connector coaxial".
Hint: In the future install one of those little lamp switches that are in a little plastic box with knurled knob sticking out the sides. ONLY break ONE wire from the adapter to avoid getting the connections reversed. Since the wires are smaller than lamp cord, tack solder the wires to the piercing points of the switch .
Apr 11, 2011 | Allen & Heath Xone-22 2 Channel Dj Mixer
Mic section, lights and filter section quit working
Sounds like it MIGHT be a power supply problem. Needs service!
Aug 27, 2009 | Allen & Heath Xone:92 DJ Mixer
Loss of power to heater control unit 92 k1500
Replace the fan relay, it is most likley the problem.
Jul 10, 2009 | 1992 Chevrolet C1500
Adding new equipment?
http://www.allen-heath.com/US/dl.asp?file=288
Apr 07, 2008 | Allen And Heath Xone 92 4-Channel DJ Mixer...
Samsung Microwave
You may have a blown internal fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Feb 28, 2008 | Samsung SMH7174BC Microwave Oven
Allen And Heath Xone 92 4-Channel DJ Mixer System Logo
156 people viewed this question
Top Allen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Allen Audio Player and Recorder Expert? Answer questions, earn points and help others
