Question about Propellerhead Reason 3.0 (991010004) for PC, Mac
Midi Trouble with Reason
Midi Keeps Cutting out in Reason.. The Light on my Midi 1x1 Works.. I am wondering if my computer is too slow to handle it. The Midi Light is on and responds to my playing. Just No Midi sound in Reason. I also went ahead and tryed another trigger device, still nothing.
    Novelist:
  • 150 Answers
It is possible that your PC is too slow, but there may
(of course) be other causes
I have experienced a situation with Adobe Audition, causing
recording drop-outs when my PC got too busy.
To test this theory:
1) Shut down all unnecessary applications.
2) Go to the command prompt and disable the internet:
type: IPCONFIG /release.
to restart it later, reboot the machine or type:
IPCONFIG /renew
3) Go to the task manager and stop all unnecessary
processes:
press: control-alt-del at the same time and then
choose the "processes" tab
right click on each process you don't need
and stop the process
4) You should be able to reduce the number of processes
into the low 20's, but you need to keep the following:
a) Your midi application (Reason etc) of course
b) alg.exe
csrss.exe
explorer.exe
lsass.exe
svchost.exe (all of them)
services.exe
smss.exe
system
system idle process
winlogon.exe
5) Now go into the control panel --> administrative tools ->
services and stop all unneeded services
(the system will not let you stop anything essential)
6) Don't worry about stopping tasks and services,
they will all restart to normal when you reboot the
machine.
7) Go back into the task manager and right-click your
midi-application. Increase its priority to HIGH,
but NOT real time, because this may cause windows
to hang.
8) If your midi acquisition improves, then speed is the problem,
otherwise, look elsewhere:
a) re-install audio and midi drivers
b) make sure the mixer and control applets are correctly
configured, i.e make sure the midi is not muted.
e) make sure the midi application is allocated the
max amount of memory, if it has a setting for it.
etc.
9) I am assuming that you are running Windows XP.
If your PC is too slow do NOT use Vista !!!!,
which makes things much worse, at least
by a factor of 4 to 1
Do not install XP service pack 3 either,
its bloated with anti-piracy **** and DRM.
10) Finally, for audio work, I would recommend
a minimum system with:
a) Pentium III 800 MHz or better yet a Pentium IV
at 1.5 GHz or faster.
b) One Gbyte of RAM to make sure your machine is not
disk bound. This is much more important than a fast
CPU.
Disk is approx. 10 million times slower than RAM,
so this can become a very significant bottle neck.
c) Windows XP pro, SP2 (not 3)
d) Depending on your video card, i.e. the amount of
workload it handles for the CPU, you may also reduce
the screen resolution, and disable desktop effects
to speed thing up.
Adobe audition, for example will perform more reliably
on slower CPU's when the GUI window is kept small
in waveform or spectrum display during recording.
Good luck,
Martin
P.S. I use Adobe Audition for most of my recording and
audio processing. System = Core 2 Duo /2.4 Ghz,
4 Gigs of RAM (only 3 Gigs are accessible from 32 bit
windows XP), 1300 Mhz front side bus, 3.5 Terra Bytes
of hard disk, of which 1.5 Terabytes are configured as
RAID-5.
Speed and storage is no longer an issue :)
not even for HD video processing.
Posted on Jun 04, 2008
Slow Internet/Keeps Cutting Out
Hi try to test your internet connection by using a a eithernet cable and directly pluging into you router and computer. If your connection works fine with that connection then try to reset your router back to factory settings and use a new password just in case someone has been bumming off your wifi. also contact your service provider to have them ping your system, they can test the connection from their end.
Feb 02, 2014 | 2wire Computers & Internet
Keep losing midi connection to laptop.
If your just using as a controller don't set the output. You only need to set the input.
Make sure the channel your using is armed as well. The button below mute & solo will be red if it is.
May 02, 2017 | M-Audio Music
I have just bought a second hand Evolution MK-161 MIDI controller music keyboard on ebay. It works fine when I play it through my computer using the virtual organ software 'Hauptwerk' (which is the prime...
You must use some form of MIDI sound generator module connected to get sound... It is a standalone capable MIDI generator, but NOT generating audio.
Mar 01, 2011 | Music
Wont turn on,when i plug to charge in computer ,keeps just having a slow blinking blue light
the inbuilt rechargeable battery life got over.....that is the reason why it works only if u can connect to the pc...it ll take power from the usb port and works....
so u r supposed to get the battery replaced at ur nearest service center.....
dont forget to rate me....
good luck....
Apr 15, 2010 | Creative Labs Zen Touch MP3 Player
No install because problem with the logo no pass
Hi there just because it says it has not passed the windows logo check does not mean it will not work. It only means it has not been tested by microsoft. Set a system restore point first then install it and see if works. If any problems you can always restore your computer back to how it was.
Please dont forget to rate me.........thanks from Scott
Oct 28, 2009 | M-Audio Midiman USB 1x1 MIDI Interface...
I have a CTK-541 Casio. How do I connect it to my computer? I have a Gateway GT 5694.
I have been doing computer-based recording for many years, as well as MIDI implementation both for live music and recording studio situations. I think I can help you with this.
Your keyboard is midi-capable, and this is how you would connect it to your computer. There are various ways you can accomplish this, but I will direct you to the easiest and probably best for your application.
I use an M-Audio MidiSport 1x1, which you can find at my favorite online music store, Musicians Friend. I have dealt with them for years, and they are the best and cheapest. Here's the link to the exact page you need:
http://www.musiciansfriend.com/navigation?q=midi+interface
There is also an option to connect your midi capable keyboard directly to a USB connection. It is also on that same page. Hope this helps. Trust me, it's a LOT easier than it sounds.
Jun 16, 2009 | Casio SA-75 Keyboard
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Jan 18, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Propellerhead Reason 3.0 (991010004) for PC, Mac Logo
324 people viewed this question
Top Propellerhead Computers & Internet Experts
Chris Larocque
Nikki  Mclean
Nikki Mclean
Alun Cox
Are you a Propellerhead Computer and Internet Expert? Answer questions, earn points and help others
