Question about Epson Office Equipment & Supplies
I have an epson workforce 500 scanner... It is telling me there is a paper jam when there isn't one...won't let me get past the screen that says "Close the document cover, check for any jammed paper in the document feeder, then press OK"
  • Epson Master
  • 13,433 Answers
Hi
there still must be something inside the machine that its taking as a paper jam. See if you can take it apart without unscrewing screws as much as possible and inspect the paper path with a flashlight. you might be able to feed a thick paper throught the machine, it might remove the jammed paper or object inside. but it might also make the trouble worse.
Here is my Paper jam general Advice Tip
Start by following the steps below to get the paper out from the machine.
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Advanced
If that doesn't help then you would have to start taking apart the machine to find the jammed paper and remove it, its not something a just anyone should do unless you have experience. A service manual would be required as there are alot of small parts in the paper path, also, it will void any warranty that the machine might have.
you may have to take the machine to a repairer to get the jammed paper bits out of the machine, if you don't see paper jammed in the machine it does not mean that there wouldn't be a paper jam somewhere in the unit along the paper path.
Posted on Oct 12, 2010
How to remove paper jammed in epson workforce 500 printer. i dont see the paper in scanner, back feeder and ink cartridge. what shall i do?
Unplug it and open it up until you see the paper. Don't be rough, but use the rollers to help you roll it back out carefully, If any piece is broken off, fish it out... you can't leave any bits in there.
Apr 10, 2015 | Epson WorkForce 500 Series
Hallo am mark,my printer px660 is displaying paper jam when i press ok button it display's close scanner then it says i turn it off when i close.then it displays the same text.how do i go aout it?
It may be obvious but check to see if you have paper or that it is loaded correctly in the tray.
My Epson Workforce gives a paper Jam error when I'm out of paper. Yours may be doing the same.
Feb 09, 2015 | Epson Stylus Photo Px660
Printer will not feed paper
Print paper has to make a 180 degree turn in thr printe- is this thick, stiff paper
Jan 05, 2013 | Epson WorkForce 545 - Multifunction fax /...
Epson workforce 840 printer gets paper jams. Cause and fix?
make sure that at the point where you add the paper for printing that you have the scale for the weight of paper in use
there is a small adjuster there
Sep 07, 2012 | Epson Workforce 840 AllInOne InkJet...
Epson workforce 633 warning paper jam when no paper jammed power wifi and fax auto lights flashing can not get to menu
I had success by turning the printer off and on again with the top pieces up (as if changing the ink). I found this trick also works when I have a scanner error that won't go away. Good luck!
Apr 23, 2012 | Epson WorkForce 633 InkJet Printer
Epson workforce 500 constantly has a paper jam after paper jam each time, ive loaded it about 100 times and its still the same problem and tried everything to make the paper go through fine. It worked a...
hi, sorry for the inconvinience youre having on this printer, but obviously, the printers rollers aren't good, there is a hardware issue on this part and you would need to go to a service center if they can replace the rolllers or better yet call epson to ask for the warranty option, if you bought it w/in 1 yr. they should replace it w/another unit, same model, txn
Feb 10, 2010 | Epson WorkForce 600 All-In-One InkJet...
Epson Workforce 500 paper out...still thinks it's jammed
Couldn't fix the problem, but the Epson people have agreed to send us a new unit when the tech supprt people couldn't provide a solution. We are to send the old one back. I'm glad this happened while the printer was still under warranty. Hope this doesn't happen to someone else, but we're pleased with Epson's reponse.
Apr 09, 2009 | Epson Office Equipment & Supplies
Epson jammed paper
Check for the compatibility of the paper you're using by visiting www.epson.com and selecting your region. Also, I might add that make sure paper is properly loaded.
Dec 24, 2008 | Epson Stylus Multifunction Inkjet Printer/...
234 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
