Question about HP Scanjet N8460 Flatbed Scanner
My HP N8460 has no power. It worked just fine 2 nights ago and now nothing at all. I tried another power cord with the same specs from my HP printer and still nothing. I unplugged it, tried another outlet, rebooted my computer and it still will not turn on. It has a manual power switch on the back and it does nothing when I flip it.
jackboy
  • 2985 Answers
SOURCE: No picture image when scanning
This looks like a CCD failure. Can the image be corrected in the PC software Which image editor are you using?
Posted on Jun 14, 2007
SOURCE: HP 5470c scanner
First of all, use a lamp, fan or something to check your electrical outlets. Make sure they are not on a switched circuit, or a power strip that may be turned off. Try unplugging the cord from the scanner and re-inserting it. I don't know if there is a fuse inside the 5470, but I would bet on it. If all else fails and you feel competent to try it, see if you can disassemble the bottom and look for the fuse. Usually sudden problems like this are really something simple (or catastrophic!! :-) Good luck, John
Posted on Jun 04, 2008
  • 14 Answers
SOURCE: HELP! My HP Scanjet5470C worked PERFECTLY - not anymore
u'r scanner have to turn on first for the computer regocnize
try another power outlet, if the scanner turned on, it means the power outlet u used now is poor...
u can check the power adapter first
Posted on Jun 23, 2009
  • 10406 Answers
SOURCE: My HP 3970 scanner will not work. I suspect the
Yes, any "big-box" computer-store should be able to replace your cable, for $5, if you take the "bad" one to them, for comparison.
Posted on Jan 24, 2010
  • 5416 Answers
SOURCE: HP Scanjet 3970 has no power
What is the temperature at the plug/transformer? If it is cool to the touch after being in the live outlet for a while, that is the source of your problem and it needs to be replaced. You will need to match the plug size and shape as well the voltage for an AC/DC transformer. The voltage is usually on the transformer but can be hard to read (highlight it by rubbing chalk over the lettering if the letters are molded into the case).
I hope this helps.
(I do not know if HP sells replacement transformers; Radio Shack often has suitable ones but you do need to match the details.)
Posted on Feb 12, 2010
I can't copy or scan. Printing works fine. When asked to copy , the display says copy in progress but nothing is happening. The same is true when trying to scan the display says scanning in progress but...
Did you try to scan from ADF or Flatbed glass?
Now as its not copying then it can be hardware issue so we can try to reset the printer and for that
1. Unplug the power cord from the back of the printer while the printer is ON
2. Hold and press the # and 6 key at the same time and while holding them plug in the power cord you will say that the printer turns On and there may be reset message on the screen of the printer ..release the buttons
its around 2 minutes process and it will reset your printer
If does not help then please get back to me
Apr 08, 2011 | HP Officejet 5610 All-In-One InkJet...
Hp p/smart c5280 all lights flashing
Is this your problem:
The power light and about all of the left lights are blinking and there is
nothing on the display screen. Trying to turn off the machine does not work and
results in the same error. "Hard" reboots do not work.
Switch the cords if you have another HP Photosmart printer, even if the
latter one is still working.
I thought of this early but then decided to watse three hours of my life I
will never get back,
Do you have another HP printer with a similar looking power cord?
The cords should go into the back of the printer very easily. I have an HP
C5280 and a newer HP C309 and I just moved. Actually, I have three printers
including an HP 7510. The 7510 and the C309 worked just fine when I set them
up, so I figured they both had to be utilizing the proper cords. But I was
sismaken.
I undid the C309 cord and replugged it and noticed it was hard to put into
that machine, despite that it still printed, just as the one I was using on the
C5280 was difficult to plug in. So I made sure the transformers were basically
the same and switched the cords.
Your first tip that something is awry is if it takes any effort to get the
power cord into the machine in the first place.
Hope this works!
Feb 15, 2011 | HP Photosmart C5280 Printer
My PSC 2355 is unresponsive, it will not turn off or on though the screen on the printer is on and says HP Invent.
Step 1
1. Disconnect the power cord from back of printer ( when the printer is on)
2. Wait for 10 seconds and connect it back
3. Once the printer is up, try to turn off and turn on, it should work.
If this does not work,
Step 2
3. While holding the power and cancel button on printer, connect the cord back.
It should work fine.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | HP PSC 2355 All-In-One InkJet Printer
Lost power cord
Specifications:
  • Manufacturer: HP
  • Input: 100-240V, 50/60Hz
  • Output: 32V, 16V
  • You can get more information here:
    http://www.unitedsale.com/product_info.php?products_id=18583
    Please vote me if you like my post.
    May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
    HP LaseJet 4 printer turns off without warning!
    do you have an extra LJ4? if yes try interchanging the power supply
    Apr 06, 2009 | HP LaserJet 4 plus Printer
    My hp ze4300 will not turn on
    Has there been a power surge meanwhile? If so, try unplugging the power cord, press the power button, reconnect power and try booting. Sometimes works.
    Oct 19, 2008 | HP Pavilion ze4300 Notebook
    Canon MP830 power outage while printing
    My MP830 did the same thing today. I thought it was toast. However through a Google search I found the following suggestion.
    Unplug the MP830 for 20 minutes or more. Plug the MP830 back in and hit the power button.
    To might great relief my MP830 powered up and is working just fine.
    Jun 30, 2008 | Canon PIXMA MP830 All-In-One InkJet...
    HP PhotoSmart C4180 All-in-One... Problem:
    Try the resetting the printer to factory defaults.
    Steps:
    1.Turn the Printer OFF, unplug the power cabled from the back of the printer and from the wall outlet.
    2.Then, Press and hold the ON button for 30 -60 seconds
    3.Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold CANCEL and COLOR COPY button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
    Please let me know, the status. GoodLuck cheers!!
    Thank you ...
    Feb 15, 2008 | HP PhotoSmart C4180 All-in-One Color...
    Ink says empty but cartridge is new
    On the phone for an hour with those idiots in India, same exact problem. Here is what you do: 1: Unplug AC cord from back 2: Hold down the # and 6 key, plug in the powe cord and continue to hold the kes for 1 minute. 3. Printer will power off durning this time. Release the keys and plug in the power cord. 4. You may need to press the power button on. This will hard reset the printer. It will go throught the initialaztion process and suck your cartridges but should solve the problem. HP SUCKS!
    Jan 05, 2007 | HP Photosmart 3310 Printer
    Notebook will not power on!!!
    Try removing the battery and just connect the power supply to power it up if you are able and see if any change.
    Nov 28, 2006 | HP Compaq Presario V2000 Notebook
    HP Scanjet N8460 Flatbed Scanner Logo
    181 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
