Question about Eagle Fisheasy 250ds Fishfinder
I need the 4 pins conection diagram: (+) (-) and 2 pins of the transducer. Other question: How do I open my eagle Supra pro I.D. fishfinder? Thanks. Oscar
4 Suggested Answers
SOURCE: I have an older eagle suprapro id with a 4 pin
qxl.no
have one
Eagle Supra Pro
Posted on Feb 20, 2010
  • 35 Answers
SOURCE: How do I install a fishfinder transducer without
Connect the trasnducer on a SS plate bracket behind the transon of the boat.
Posted on Jan 30, 2011
paul4265
  • 592 Answers
SOURCE: I am replacing a Eagle Intellimap gps and eagle
Hi, Charlie!
I checked it out, and it turns out you can use the transducer of off your old 128 model.
Just unplug it from your current model, and plug it back into your EFE 480.
What I like about these newer fish finders is the fact that it also has gps built in to it, along with the maps for all of the USA, and the fact that it has a memory card slot, so that you can download new maps onto a memory card, pop it into the machine, and then it will update the maps !
Sure beats the old days where you had to send the unit in to a tech to have them install map updates.
Som yes, you can use the old one, and it should work with no problems.
Good luck to ya, and catch a big one for me !
Posted on Feb 14, 2011
Wiring diagram for 7 pin plug for Jacob eagle camper van,showing auxiliary on number 2 pin
The 7 pin plugs have a set standard.
trailer-plug-wiring-diagram-7-way-flat-88-au345ecz1cbyexwki4uygiw5-2-0.jpg Pin 2 is used for brakes, pin 4 for aux charging (battery) on your camper
May 07, 2017 | RVs
Can I wire it together?
The impedance match most likely won't. I advice you not to attempt. Replace with matching Eagle model transducer.
Jan 09, 2016 | Eagle Boating
Need to know simple wiring where power output pins are on eagle signal control off-delay timer #81Q2A605
1) Copy following link for general pin timer wiring:
http://waterheatertimer.org/How-to-wire-pin-timers.html
2) Eagle tech support:
http://www.danaherspecialtyproducts.com/Eagle_Signal/Service_and_Support/Customer_Service___Tech_Support/
3) Fixya appears on 1st page of google search for this product, indicates there is no clear information available on the web.
4) Add a comment and describe the wiring diagram that appears on side of device.
Each pin timer has wiring diagram.
The image I found shows 11-pin base, and push button or impulse input connects to terminals 2 and 6. Image is not clear enough to determine more information.
Feb 20, 2013 | Hardware & Accessories
Need pin outs for eagle cuda 168
Coda has flat D 6 pin with center pin grd for 4 wire vs old arrow 6 pin round black one. Flat on bottom, count cw 12345 pins w pin 6 center... 2 pin minus 12 v, 4 pin +12v. For other 4 wire like speed/temp... 1 blue, 3(top) white, 5 pin bot right yellow, 6 center ground for spd/temp. White for speed wheel, rest not known. I used 2wire cable and 4wire cable with 2ft pigtails and 3amp fuse in red wire. I used old radio stereo 2 and 4 pin male female connectors at end of pigtails.
Nov 06, 2012 | Eagle Cuda 242 Fishfinder
Water temp is not working can that be fixed?
Double check you have a good connection from the transducer data cable to the back of the display unit and that the pins are not corroded or anything similar. If the temp has never worked at all, it may be because the transducer you are using doesnt have a temperature sensor onboard and you will need to get one that does have this feature. If it did work previously and you checked the pins/connection (as per above) then the transducer is faulty or has developed a fault. There is no real easy fix and it will most likely be far cheaper just to buy a new transducer than to have the current one repaired by Eagle. I think new trasnducers are about $60-$70.
Mar 30, 2010 | Eagle Fishmark 320 Portable Fishfinder
Sorry but I have the same question. I will try to break in the unit. Then I will letyou know.
Jan 16, 2010 | Eagle Fisheasy 250ds Fishfinder
Sonar does not appear to work - not picking up depths or bottom structure. All other functions look good.
This problem is most likely linked with your transducer.
1. Check your transducer cable and make sure the plug terminals are clean, as well as the plug on the back of the unit.
2. Make sure the transducer cable is plugged in correctly and securely.
3. Make sure the transducer is in the water and mounted according to the directions, parallel to the bottom of the boat
4. Turn the unit on while the boat is in the water, but with the engine OFF.
IF it works when the engine is off, but vanishes when the engine is on, you may be having electrical interference.
IF it works when the engine is running, but vanishes when the boat is moving, it is a turbulence problem. Move the transducer.
IF it does not work at all, try borrowing a new or a "known good" transducer and seeing if it works then. If so, replace the transducer.
Let us know if these work or now.
Oct 15, 2009 | Eagle Fishmark 320 Portable Fishfinder
Diagram of 1983 supra fese box
No problem....here ya go! I would save this to desktop and then open so you can zoom in on the diagram:
Jun 19, 2009 | 1983 Toyota Celica Supra
Need older Raytheon v720/ v820 sounder transducer pinout
Did you find it? i´m triying to get a wiring pinout diagram for a V8010 transducer. Thanks, regards from Spain
Apr 21, 2009 | Televison & Video
Eagle Fisheasy 250ds Fishfinder Logo
202 people viewed this question
Top Eagle Boating Experts
Steve
Steve
ray gallant
Al Toledo
Are you an Eagle Boating Expert? Answer questions, earn points and help others
