Question about Troy Bilt 5.5hp Self Propelled Mower
Self propel barely moving... any adjustment? - Troy Bilt 5.5hp Self Propelled Mower
  • 755 Answers
Generally other than very slight cable slack cancelling a new belt is your best bet for a slowing driveline.
Posted on Oct 12, 2010
I have a self propelled lawn mower and the the belt that propells the wheels is loose, do I need to replace it or is there a way to tighten the tension.
Cathy, there is a way to adjust belt tension on some models whether it is by the cable or a slotted bracket where the idler wheel is mounted, depends on make and model. If you have your manual check in it for belt adjustment. Could be stretched belt, stretched cable, worn/oil on pulley, seized tensioner, stretched/broken spring on tensioner,etc.
How to replace drive belt on Craftsman 22 Front wheel drive mower
How To Repair Troubleshoot Self Propelled Part Of Lawnmower HD
Fix Self Propelled Craftsman Push Mower
How to adjust drive belt on 6 75 Horsepower self propelled lawn mower...
May 23, 2016 | Garden
How to replace the self propelled
Make sure the cable to the transmission moves freely. If all the cables and lever s move freely than it more than likey is an internal gear needs replacing.
Jul 15, 2014 | Poulan Pro 22" Self Propelled High Wheel...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Self propelled #860. self propell got slower and slower. now barely assists. can I adjust the belt. manuual says bring it in. too far. how do I tighten? thx, bruce
Your self propell is not adjustable. The belt runs over a spring tensioner,you either need a new belt or axle bushings. If you pull the top cover off, you can watch the belt when you engage it. With the engine off, can you move the front wheels up or down or forward or backward? If so the plastic bushings are worn out and this changes the geometry of the drive system, making the belt appear too long.
Hope this was helpfull, Matt
Dec 31, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Self Propel doesn't work on Hoover Wind Tunnel
Your self propel wire could be broken. Lean the vacuum back like you were using it. If you stand in front of the vacuum look down and to your left. When you move the selp propel button you should see a wire move. If not then it's broken.
Oct 06, 2009 | Hoover Self-Propelled WindTunnel Bagless...
My toro self propelled isn't self propelling
It may just be a matter of adjusting the cable. Sometimes they dont get them adjusted just right from the factory,heres what you do. Locate the plastic shroud in front of the push mower that covers the drive unit.Determine which screwdriver or torx bit is needed to remove shroud and remove it. After removal you will see a pulley with belt around it, as you pull the handle back to engage self propel you should see the pulley move into the belt to put tension on the belt. You can do this with it running to see if enough tension is being put on the belt,if not, locate the cable end where the small bracket holds the cable in place. Loosen the cable bracket and move cable until you have correct tension again,hope this helps.
Aug 08, 2009 | Garden
Front ppropelled mower
You dont adjust the belt,you adjust the cable that moves the pulley into the belt. There will be a small single bracket close to the engine side of the mower that holds the cable in place. Simply loosen bracket and move cable until pulley contacts belt enough to engage self propel.
Aug 08, 2009 | Toro Lawn Mower With Toro Power Tools
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
Feb 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Troy Bilt 5.5hp Self Propelled Mower Logo
266 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
