Question about Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge
Replacing start rope of the b&s model # 120600
  • 755 Answers
Take off the three-four bolts holding on the starter cover and lift it off the engine. Make sure you dont leave the oil dipper attached too.
Remove its bolt at the cover so it doesnt come out of the engine block and make a mess.
Flip the cover over and you should see the pulley the rope rides in. Pull out the broken end piece of the rope from the inside-center of this pulley. Get a new piece of rope from a power equipment store. Make sure you get enough to cover the length needed to make it all the way out to the handle! Snake into the recoil cover from the outside hole into the pulley *(you align the pulley with the hole in the cover) with small needle nose pliers you can pick the rope through the pulley hole and then tie a knot to secure this end of things. A butane lighter is good to use on the frayed end to "melt lock" it. Nothing crazy now...just melt the tip where you see the frayed material.
Then put the t handle on the other end and tie it off too. Also melt the frayed end before pulling the rope into the t handle.
Now that the rope is in place all you need to do is prewind the pulley. This is done by using a small section of the rope near the pulley to turn it in the direction of starting about 6-8 turns and then carefully release the pulley so it winds the rope onto it. You can do this slowly by keeping tension on the T handle and slowly walking it into the starter cover. Be careful. You dont want to get your fingers caught on anything spinning or pulling here. The rope will be twisted so the person holding tension on the rope can help by untwisting the rope so it can rewind smoothly.
That is about it. You can then pull the rope a few times to make sure you put enough prewind on it so the rope doesnt stop pulling even though you have more rope to pull *(this is to prevent causing the recoil spring binding from insufficient prewinding)
Put the recoil cover back on. Put the t handle back into the fixture on the mower handle. Thats it! Start her up and go cut some grass!
Good luck and be careful!
Posted on Oct 12, 2010
I have a 3hp briggs & stratton//the pull rope pulls freely//it does not engage the engine and turn the engine over
You probably need to replace the starter recoil. This is not a very expensive fix. Just be aware that this problem is usually caused by having to pull the starter rope excessively because of some other starting problem. Once you replace the recoil, keep your engine running properly.
Sep 07, 2014 | Garden
How do you start a homelite model #ut100550 They
its not the spring thats too short its the rope. i would just put a longer rope in it.
Jul 12, 2011 | Homelite Garden
Hi there! I have a used Poulan Weed Eater SV30 Barracuda 32cc Super Blower Mulching Vac w/ reconditioned engine; Engine Family TPW032UB24RA : EM and Serial No 96215N500274-1 I need an Owner's / Repair...
unbolt the cover and there is a pully under it,,,this pully holds the starter rope but its needs to be tenshond up first so it pulls the rope inside when let go,,,the rope is just knoted to the pully
also its a 20 to 1 petrol oil mix,,,for running it on,,,
Aug 21, 2010 | Poulan Garden
Starter rope broke how do i replace it. toro super recycler mower. Removed the plastic engine cover and the recoil mechanism seems to be rivited down and I cant get in there to replace the rope. Please...
You have to remove the whole engine air shroud over the flywheel to gain access to the recoil and rope mechanism. If you need specific help on your exact model engine I need all of engine model type numbers 5 to 6 char then 4 char then 2 char i.e XXXXXX-YYYY-ZZ for B & S Honda numbers are by the engine oil port on the base of the crank case. Thanks for using FixYa, Kelly
Apr 22, 2010 | Toro Lawn Mower With Toro Power Tools
I have a Snapper Briggs & Stratton lawn mower Model Series 126T00 and for some reason it will not start.I drained the gas tank ,put fresh gas in it. I did a caburetor kit and it still will not start....
How about the key way? Its the timing of the motor. Its under the pull rope and the wheel under the pull rope. Might be cut or broke in half.
Mar 21, 2010 | Garden
When I went to start my craftsman model 247.88704 snow thrower, the pull handle rope came out. Can you tell me the best easy to put it back together?
on your pull rope housing youll find 3 to 4 bolts remove the housing inside youll find the place were the rope was tied in [ if it just came untied ] just rember to spin counter clock wise for your tinshion befor replaceing the rope then put back together
Feb 10, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
Starter Rope Rewind Problem
I need to replace rope on my lawnmower starter, are there any tips on this?
Dec 11, 2008 | Toro Lawn Mower With Toro Power Tools
Yard Machines 11A54MC006 21Inch 139cc MTD OHV Gas Powered Side Discharge Logo
130 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
