Question about Panasonic PT-AX200U Projector
My Panasonic PT-AX200U projector (6 months out of warranty - 200 hours on projector) is near dead. Plug it in and the standby light comes on. Push the power button on either the projector or the remote, and the green light comes on. But it makes no noise - no fans, no lamp, not even a relay click... nothing. The light stays green forever. I called Panasonic support and they say they don't see this often. Wondering if anyone can tell me if I can test/replace a power supply or main board or fuse.
3 Suggested Answers
Marrie
  • 563 Answers
SOURCE: Panasonic PT L501U Projector
Hi there
Have you replaced the lamp ?
If you haven't - take out the lamp and chech for any irregularity on it - i.e. - discolouration , vein like looking marks ( black or white ) and also if the shape of the shaft is off.
If there is no visible damage it might be a faulty Ballast ( lamp's powersupply ) - especially if you cannot get it out of stanby once it has shut down.
Posted on Apr 17, 2008
heathgr
  • 442 Answers
SOURCE: PT-AX200U Bulb replaced 4 months ago Was on about
carefully take the lamp cover off, and see if there is any glass pieces inside. if all looks Ok, then unscrew the lamp housing and remove the lamp. check for any damage. be careful not to damage the lamp or bump it. These lamps generally contain mercury vapour, so try not to inhale anything if it's broken.
Posted on Apr 11, 2011
My projector comes on and is totally fine but wont show a picture i can switch inputs and go to the menu but all i get is a blue screen help?
HI
YOU NEED TO REPAIR / REPLACE THE MAIN BOARD.
THE SUPPLY TO THE LCD PANEL CIRCUIT BLOCK MAY BE DEAD.
CHECK THE POWER SOURCE TO IT .WNA200 - SHARP CHIP FOR DEAD FUNCTION.
THIS SHOULD CURE THE PROBLEM , ELSE YOU MAY HAVE TO REPLACE THE BOARD!
CHEERS!
Apr 05, 2015 | Panasonic PT-AX200U Projector
Why red light is on ?
Its the most common poblem with the ax 100-200 projector.Many a times only the ballast requires to be replaced.yet on may occasions both mainboard and ballast requires replacement. its best to confirm with a good known working ax200 and replace first the lamp, ballast and the mainboard.panasonic ax 200 lamps also have failed premature as per my experience.
May 04, 2014 | Panasonic PT-AX200U Projector
Panasonic PT-AX200U projector. input display flashes on and off.
It could be your source and not the projector. If it is a laptop then hit function four and change how it shares display. Over all I need more info as to how it is plugged in and what you are trying to view from.
Jan 08, 2013 | Panasonic PT-AX200U Projector
I have a PT-AX200U projector, I have noticed that the picture is diming intermitently
how may hours has your lamp done?
if you have crossed more than 1500 hours , u may need to change the lamp.
the problem could however be that of the signal cable which could be intermittent and causing similar fault.
check if the same problem is seen in all inputs!
Dec 24, 2012 | Panasonic PT-AX200U Projector
Apr 09, 2011 | Panasonic PT-AX200U Projector
Pt-ax200u projector turns off after 1 min of operation. the light turns red then green. After that, the power button does not respond and i have to cycle off the project. If I turn it on, it does the same...
your projector is detecting it is overheating, check that nothing is blocking the vents and that the fans are not clogged. If the vents and fans are dirty clean thema paintbrush and hoover. If they arent then the lamp maybe the culprit
Mar 07, 2011 | Panasonic PT-AX200U Projector
My pt-ax200u runs for about 15 mins then turns off. The replace bulb light is on but otherwise vents are cleaned and and cooling fan is running.
hi,
try one thing reset ur projectors lamp hour and the try
follow the procedure for lamp reset
1. power on the projector
2. press the menue button
select options and then press enter
select lamp rutime
press and hold enter buttonfor 3 seconds
confirmation screen will display and select ok
press power buttonfor turn offfor resetting the duration of the LAMP RUNTIME
confirm theduration of time in lamp run time
Jan 06, 2011 | Panasonic PT-AX200U Projector
HOW DO I REST THE BULB LIFE ON MY Panasonic PT-AX200U
1. Press the MENU button to display the menu.
2. Select the OPTION menu and press the ENTER button.
3. Select LAMP RUNTIME.
4. Press and hold the ENTER button for approximately 3 seconds.
5. The confirmation screen will be displayed and select OK.
6. Press the POWER button to turn off projector for resetting the duration of the LAMP RUNTIME.
7. Confirm the duration of time in LAMP RUNTIME is reset to “0 H”.
Aug 05, 2010 | Panasonic PT-AX200U Projector
The green light comes on and then a minute late it gets yellow ptax100u panasonic
sounds like a problem with the lamp. bad lamp, reached max hrs, too soon to restrike lamp after power lost, etc. are either of the lamp or temp lights showing anything?
http://service.us.panasonic.com/OPERMANPDF/PTAX100U.PDF
Oct 13, 2009 | Panasonic PT-AX200U Projector
Panasonic PT-AX200U Projector Logo
75 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
