Question about Nikon Coolpix S210 Digital Camera
It won't take a picture. Everything else seems to be fine and turns on and off without a problem. The battery ran out just before this, and after charging it refused to read the SD card in it and it started to have this problem.
  • stephfleming Oct 12, 2010
    Thanks, I tried, but it doesn't work.
    Actually, I took out the card and tried taking a picture without the flash and it worked. Is it a flash problem? (I'm guessing yes, but what can be done to fix it?)
  • 13,433 Answers
Hi
try removing the sd card and then try taking a picture, does it take it?
Posted on Oct 12, 2010
  • Ekse Oct 12, 2010
    lets see, put the card back in and try taking a picture. if it works the flash might be bad, there is a big capacitor on the flash that might have gone bad and would need to be replaced but I can't say for sure.
    You could also reset the camera to default settings from its menu. see if that helps.
    If the flash is just bad it might not be too much of a repair. I don't know what people would charge for it, you would need to get a repair estimate.
My 1997 Suzuki Bandit600 won't start, the battery
during the battery replacement did you manage to either forget or damage a wire that powers up say your ignition module... ?
Sep 15, 2014 | 1997 Suzuki GSF 600 S Bandit
Why won't it run
have you checked the relay between the battery and the starter?
i had a ltd 2 that suddenly refused to start after trying everything else it turned out to be a little black box(relay) on the fender well between battery and everything else!
May 08, 2013 | Cars & Trucks
2008 escape hybrid won't start when you turn the
I am not familiar with hybrids, but i think when you start, it's starting with the battery, so I think you have a bad connection, check and clean the battery terminals.
Mar 25, 2013 | Cars & Trucks
The air con won't work. How do I fix it, everything seems to be set up fine. I thought all I had to do was turn it on and the air con would turn on, but it won't
Check that the master switch on the external condenser fan housing is turned on, it is a sliding button like switch.
Feb 25, 2013 | Heating & Cooling
Old Pride Rally won't charge or run
The batteries may be too old to take a charge. They are gell cell types and can be had at any battery shop. You can get them on line too, but shipping will be high.
Dec 19, 2012 | Pride Rally 3 Wheel Scooter
I have a 2003 Saturn L-100 that won't turn over. Ran fine earlier in the day and doesn't seem to be the battery because lights come on when we try to start it.
those vehicles are common for starters did two today alone when it wont start try to tap it with a hammer it on the back side of the engine under the intake if it starts replace starter
Oct 29, 2012 | 2002 Saturn L-Series
Dying 1996 Jeep Grand Cherokee Limited
I wouldn't think catalytic converter, without it giving some indication that it was going bad, but without testing it is hard to say.
When it cranks and won't start, check for battery voltage to the coil on the dark green wire, with key ON. If you have power at the coil, it might be a bad coil. If no power to the coil, it could be a Crank Position Sensor or the Cam Position Sensor inside the distributor. If one of those is bad, it can stop the computer from sending power to the coil.
Good luck.
Jul 06, 2012 | Jeep Grand Cherokee Cars & Trucks
Engine won"t turn over(crank)
I ran into this once also, and I remember that I just disconnected the battery for about half an hour.
Try that if you haven't already.
Mar 07, 2009 | 1998 Pontiac Grand Prix
Camera wont turn on
How I fixed my Camera:
> First take your Memory card off, and remove battery
> Now, leave your camera without battery-power
=(wait for while!)
>Then,start your camera WITHOUT Memory-Card.
Note: MiniSD Card with adapter, may crash/freeze camera.
(so use the real "one piece" SD-card, not that Micro-thing!)
>When i removed the old SD card, everything was OK.
I hope this can help many others?
GonaOne from Finland.
Feb 16, 2009 | Samsung Digimax S600 Digital Camera
Nikon Coolpix S210 Digital Camera Logo
106 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
