Question about IBM ThinkPad T23 2647 Notebook
Screen flicker i have a hp dv 2000 notebook. the screen flickers but when i move the lcd display up and down i can find a "sweet" spot then its ok untill i move it again. is this a connection problem or a lcd lamp driver problem? seems like a connection problem. but would a lcd lamp driver problem act like this also?
  • badpla Jun 02, 2008
    ya..thats what i thought. im not having any sound problems yet though. but i will check it out anyways and let ya know. thx for the help.
    Problem Solver:
  • 45 Answers
It is a connection problem. THe cable that connects to the LCD and mainboard is busted.YOu need to take it apart and try to rreposistion the cable or buy a new cable off ebay. the Inverter is fine.You might also notice the sound isn't working that much.
Posted on Jun 01, 2008
How do i fix a flickering screen problem of my HP Compaq 6735s laptop
The flickering could be a sign that your lcd screen is going bad and needs to be replaced. It could also be the video card inside the computer. Isolate the problem by connecting another monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok without flickering, then your video card inside the computer is good, but your lcd screen is bad. If the Borrowed monitor flickers like your lcd screen did, then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Try tapping the back of the lcd screen's lid to see if the flickering stops, increases or decreases. It might be that the lcd cable located at the top on the back of the lcd screen is loose.Isolate the problem by connecting another monitor to the computer. You'll have to take the lcd apart to get to the video cable on the back of it.
May 31, 2012 | HP Compaq 6735s Notebook
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
Screen will flicker a few times at random periods
Change the display resolution in Windows Change the display resolution to the highest resolution using the following actions:
  • In Windows 7 , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows Vista , click Start , click Control Panel , find the Appearance and Personalization area , and click Adjust Screen Resolution . Move the slider bar until the highest resolution for the monitor is set, and click OK .
  • In Windows XP , click Start , click Settings , and then click Control Panel . Double-click the Display icon, and select the Settings tab. Move the slider bar until the highest resolution is set, and click OK .
If the screen is still blurry, the notebook display might need servicing.
Feb 13, 2010 | HP Pavilion dv4000 Notebook
How to adjust screen resolution with external monitor/hp pavillion dv 2000 laptop
1.Right-click on an empty area of your desktop screen
2.Left-click on Properties at the bottom of the drop down list
3.Left-click on Settings in Display Properties window.
4.Left-click on the 1 monitor icon to adjust the screen resolution for the HP dv2000 LCD screen.
Left-click on the 2 monitor icon to adjust the screen resolution for the external monitor.
5.Go down to where you see the heading - Screen Resolution, and the slider underneath the heading.
Left-click right on the slider, hold the mouse button down, and slide to the Right to increase resolution, to the Left to decrease resolution.
Oct 19, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Screen flickering
That really depends on when it flickers, does it flicker when you move the display open or closed or when you press some part of the laptop?
If it happens when you press a part of the laptop, the display cable could be loose, thats unlikely.
I recently had a similiar problem with a toshiba laptop, the screen would flicker when pressed on the bottom left side of the laptop.
I checked the wires and they where fine, in the end I seem to have fixed the issue by pressing on the top cover where the issue happens and at the same time from the bottom from the same spot, what I did on that laptop, there was a cover that I could remove so I could press directly on the mainboard, pressing directly on the mainboard with my fingers and at the same time pressing down from the top seem to have fixed the problem on that laptop.
Sep 11, 2009 | Acer Extensa 5420-5687 Notebook
My hp dv 2000 notebook is not get any dispaly on screen
Defective CCFL backlight may has the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 30, 2009 | HP Computers & Internet
The screen will only display top half......bottom black
Might be the following:
There are some (neon) lights behind the screen glass. If you can see a picture from the top, and on some angle the rest of the picture (in the bottom), that means you don't have a problem with your grapgisc card, driver and display, but a problem with one of the back lights. The lamp is gone or a contact/wire that power the lamp that gives white backlight.
This can not be checked or repaired by yourself. You should find a service.
It should't cost you much, sure not that much as replacement of the LCD Panell.
Check if your warranty period is active.
Regards.
Mar 27, 2009 | HP Pavilion dv9000z Notebook
Hp Laptop screen flicker
I am sure that the issue is related to the cable that connects to the LCD Display or the LCD Backlight.
There should be some connection shortage because of which the LCD flickers few times as stated by dan231.
I Recommend you to get the Notebook examined as soon as possible before something really goes wrong...
Dec 05, 2008 | HP Pavilion dv6000z Notebook
Screen flickers
If light is good and picture flickers, then it is either a bad LCD ribbon cable, or cable not well placed into connector, or a bad LCD display, usually it is the cable.
If picture flickers like light is dimming out and coming back, then it is the LCD lamp, probably in need of replacement.
In some rare case a faulty Video card is causing the problem.
Usually to fix this you need to take apart LCD display and upper laptop plate, to reveal the display cable.
Aug 16, 2008 | HP Pavilion dv1000 Notebook
Hi, i noticed that when I unplugged my HP the screen stopped flickering. I then re-plugged in the power, when to the Nvidia control settings, to PowerMizer, and changed 'ac outlet' to Maximum Power Saving.
Not the world's greatest solution, but hey, working laptop now.
Cheers,
Andy.
Nov 21, 2007 | HP Pavilion zd8000 Notebook
IBM ThinkPad T23 2647 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
