Question about Precor EFX 546i Elliptical Version 4
I did not physically see the machine working properly prior to this issue, but I was told it was working fine before I took the (handle)bars off and disconnected the electronics to move it through a narrow doorway...and I have no reason to doubt that it was working fine. Upon re-assembly, I'm receiving an ERR30 message AFTER seeing an "ERROR 5 - Stuck Key" message. Upon disassembly, I did not note specifically the CSAFE and LOWER PCA positioning. I do not remember which one the cable was plugged into. I removed the circuit board, but there is nothing on the underside to indicate which is which. Regardless, however, whether the cable is plugged into the CSAFE or LOWER PCA (whichever is which), the ERR30 message appears, so this leads me to believe the "error" is occuring elsewhere. What I believe to be the serial number is 75D18N0033. Another number on the machine that could be the serial is 250Z4A. Any suggestions/help will be greatly appreciated.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 60 Answers
DO NOT PLUG THE DATA CABLE IN TO THE CSAFE PORT. It needs to be plugged into the 'lower board' port. Error 30 is a communication problem - check to see that the cable did not get damaged in the move. Hopefully you did not blow out the upper board by plugging it in incorrectly.
Posted on Jan 10, 2015
How do I repair rear outside door handle?
It's physically broken. Handle assembly needs to be replaced. My brother complained about having to replace it once a year on his Toyota. He also warned not to buy used replacements because they are always "ready to break." He told me he could see the stress cracks in used handle assemblies.
Oct 15, 2015 | 1995 Toyota Hi-Ace
I installed a new Polaris winch on my 570 and it powers out but not in any ideas?
Jeff, The winch direction is controlled by the contactor and (polarity/relay) is switched using the switch/controller on the handle bars. I think you are dealing with one of a few possible situations. Lets narrow them down. 1) The winch motor. Bad in one direction only? this is highly unlikely. The body of the winch is electrically grounded properly or it would not run in the out direction..You may be able to manually reverse polarity to test the motor. If you do not understand this concept, then don't attempt anything that could make a short. 2) The contactor is a relay that has very delicate copper studs. If you over torqued them during the install, they easily break off. The contactor is the most likely issue. Double check the studs and ensure the wiring pattern is correct to and from the contactor. Ensure the wires/nuts washers are not touching the other leg of the contactor/studs - i.e. anything that could make a short. 3) The handle bar switch may be defective or wired wrong. Isolate the switch and make sure it works properly with a volt meter/continuity test.
I have personally experienced broken contactor studs, defective contactors and damaged handlebar switches. It took time to properly isolate and repair the issue.
Chembrew
Jan 07, 2015 | Polaris ATV
2002 yukon denali AC ISSUES
try changing the switch that maybe the simple solution
Jan 03, 2014 | Cars & Trucks
Fiat 500 : Would a coins in the CD player cause the Fiat 500 to blow a fuse
Take the radio out and remove the coins is the first thing i would advise
Feb 14, 2013 | 2012 Fiat 500
MY RADIO SCREEN IS BLANK, RADIO WORKS ,THEY HAVE TOLD ME THAT YOU CAN BRING UP THE NUMBERS IF YOU PUT IT IN DISPLAY MODE AND PUSH VOLUMN UP OR DOWN BUT HOW DO YOU DO THAT IF YOU CAN...
Turn the radio on, press the mode button on the handle bar, press the #4 button on the radio (top right), press the volume down. If it's a software related fade issue, this will return it.
This defect was only possible on early 06 models with 6.8 version software. If it's mid 06 or newer, or if the software has ever been updated, it wont work.
You most likely have a physical defect with the radio. For repair options, contact Iron Cross Audio.
www.ironcrossaudio.com
Feb 11, 2011 | Harley Davidson 426290 AM/FM Radio
Hi, I've got a broken spring bar on my Tissot PRC 200 and would like to replace it. I understand that it has got a lug width of 19mm. Does that mean I should buy a 19mm spring bar, or should it be a...
Two of the spring-bars broke on the clasp of my PRS200, so I took it to an un-named watch repair shop that was closer than the Tissot-authorized store (Leslie Gold Watch Co.) at which I bought the item 5 years prior. After the repair, the clasp kept popping off, so I took it to the Tissot store, and they told me that it was because the ends of the bars didn't fit properly. They replaced the faulty bars for me at no cost, and the watch has been sitting on my wrist fine for the last year-and-a-half.
Dec 15, 2010 | Tissot Watches
Front Loader spin cycle does not work after washing. How do I fix it?
I was having the same problem. When I went to order another pump (I had just changed a few months prior) the lady told me to try changing the door latch...I took her advice and it works perfectly.
Nov 18, 2010 | Frigidaire ATF6000ES Front Load Washer
I have a Dyson DC28 Animal. It worked fine until
lube the little clip that holds the handle upright (get down at the floorlevel and kinda look for whaer it migh be,, i used just a lilsilicine lube and mine is fine now,,was a hard to unlock handle prior to this,, all is good now.
I have a problem myself with mine now, does anyone know a easy way to reset a overload for the beater bar or the "safety shutoff" as i've seen it named before? i can see in the lil clear window that one is tripped, jsut looking for a easy way to reset it without taking too much stuff off,,,
Thanks in advance!
Dec 26, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Apple cinima display problem
have u updated the drivers, i assume u only took the screen in and they linked it up to there macs,
sounds like a driver issue, try an update,
actionman
Feb 26, 2009 | Apple Cinema Display Flat Panel Monitor...
Light comes on. does not process
I borrowed one of these and it didn't work. I had the exact same problem you all are having. The problem? I had the handle pointing to the back instead of the front. Turned the handle around to the front. Presto!! It works..
May 29, 2008 | Wolfgang Puck BFPR0015 Food Processor
Precor EFX 546i Elliptical Version 4 Logo
241 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
