Question about Acer AL1916W 19" LCD Monitor
On/off button flashes, nothing on screen for perhaps 20 minutes... or not at all. I have checked the electrical and computer connections, rebooted computer several times, etc.
  • 11,361 Answers
Does the same with other PC?
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 12, 2010
When rebooting will not proceed past the flashing ANDROID screen. Have tried everything to reset.
remove battery for a while , replace after 3 minutes push volume and power-on button on the same time can help if its a polaroid its possible it will get factory fresh after a few Chinese caracters passing by on your screen. if that factory restore is also available on your device perhaps.
But only replace the battery can be enough.
Apr 08, 2016 | Tablets & eReaders
Tablet frozen on polaroid screen-how can I reboot
Press and hold the power button for about 20 seconds. Let go and wait a couple of minutes for it to reset. You may see the screen flash which is normal.
Mar 17, 2014 | Polaroid Tablets & eReaders
My iphone 3g will not turn on, will not be detected by the computer, and i cannot tell if its even charging
Try holding both buttons, the round one in front of the screen (home button) and the one on top (lock button). Hold both buttons pressed for 10 seconds, the screen will flash and your iPhone will reboot. Connect it to the charging cable and wait for a couple of minutes so the iPhone has enough charge to turn on again.
May 01, 2011 | Apple iPhone 3G
SCREEN WENT BLANK ON MY HP PAVILION LAPTOP. REBOOTED AT LAPTOP BOOTS UP FINE, BUT STILL HAS BLANK SCREEN. AUDIO WORKS, AND CAP LOCK AND NUM LOCK FLASH. dtcorman@comcast.net
HI,
Do a power drain, this may cause by an electrical charge in the motherboard itself,Im Not really sure how it affects the display of the computer but this method usually fix such problem like that, First, removed the battery then unplugged the AC adapter the press and hold the power button or the ON/OFF button for at least 30 seconds then connect the power supply back to your computer then turn it back on, if nothing happens,there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
Hope this will help...Your response is very much appreciated...
Jan 21, 2011 | Computers & Internet
Connected Nikon L11 to Vista laptop. Picture Project software NOT installed. Turned on camera in hope Adobe Bridge could be used to transfer photos to laptop. Nothing happened and suddenly something...
Get a card reader. Use it from now on to transfer your pictures to the computer. Remove the card and battery from the camera...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Apr 03, 2010 | Nikon Coolpix L11 Digital Camera
The In Use / Memory light is flashing but there is no tel line in use or nothing in memory. Any suggestions how to stop it flashing?
Turn off your computer and completely shut down.
Turn off your printer.
Disconnect all cables and electrical cords from your printer.
Make sure the electrical cord is also removed from the wall.
Wait 5 minutes and reconnect the power cord to the printer.
Then connect the printer cable from the computer to the printer.
Turn on your printer
Now reboot your computer (cold boot)
Your printer should now clear itself.
Mar 07, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Power button just flashes will no turn off AND nothing on the screen
On back of the computer is a on off switch for the power supply, or unplug the computer for one minute. Turn the switch back on, or plug the computer back in and try to turn it on.
Apr 20, 2009 | Computers & Internet
Router causing lag after 10-20 min connected.
I know nothing about this type of router. Try pressing the button on the bottom and rebooting your router. Maybe that will help.
Jun 18, 2017 | Zhone 6211-I3-200 Router
Flashing Power Light
When this occurs an inverter, backlight, vga connectiosn, etc could be the cause, my suggestion is connect it to some other device, if you get the same result then your monitor is bad!
Nov 26, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Acer AL1916W 19" LCD Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
